Mods
Firewall Tub
Honestly this kinda wasn't that bad but also kinda was terrible.
Total Time - 10 hours
Things you need.
-Tall Jack Stands
-Floor Jack
-Wrench and Socket Set
-Pliers/Vice Grips
-Welder
-Grinder
-8-10 Cutoff wheels (I went through 8)
-Flap Disk
-Marker
-Gasket Maker (I used the ultra black stuff that comes in a pressurized can)
-Self Etching Primer
-Rubberized Undercoating
-BFH (Big F*Cking Hammer)
-Some Will Power
Also read this amazing write up by Brandon at Coastal Offroad
Clearnencing 35's at Ride Height
First thing is to jack it up, I placed tall jack stands on the cross member and then pulled my coilovers. Then using a floor jack you can jack up your tire and check for where you rub at full bump.
This was sitting at full bump no turning.
While turning. See where I trimmed out the firewall.
Here are both cuts.
I did not have to cut much with the SPC uppers and the alignment I have.
Now to patch it up. I used the worst possible thing to do this with but I used a flux core with .35 wire... not great. It was not easy.
I used cardboard to make the shape and cut it out of 16 Guage steel. Patched it up
Done and flap disked my popcorn
Same process on the otherside
I really failed to take pictures being it was 90 degress and we had been spending so much time cutting welding and repeating.
Next step is to seal it up using the gasket maker.
Do all the welds
Inside and out
Once dry to touch paint with primer inside and out
Then paint on undercoating
I wish I took more pictures but I sucked and it sucked. I proceeded to go wheeling literally 30 min after finishing and not front end rubbing to report.
I also hammered my pinch weld A LOT, most of it was done by hammering and the chop was just the extra mile I needed. I resealed the entire pinch weld because I split it with the hammer. Overall not a terrible job just really takes it out of you and if you use a nice welder it would be so much easier.
Thanks for the help
derpiful
and
TCMach
your moral support/help welding the holes I couldn't fill was much needed. Hayden I also apprciate your reasurrance that anything that got messed up could be fixed with gasket maker XD
Now to wheel the piss out of it and replace everything constantaly!
00' SR5 SPORT - 35's - Weekend Toy
@a.flemster on the gram.
Owner of
Sherpa Equipment Co.
Build Thread
