Thread Tools Rating: Thread Rating: 6 votes, 5.00 average. Display Modes
Old 03-09-2016, 01:00 AM #1
Flemster's Avatar
Flemster Flemster is offline
Real Name: Alex Fleming
Flemster is just really nice Flemster is just really nice Flemster is just really nice Flemster is just really nice
Flemster's Avatar
Flemster's 2000 SR5 Sport
2000 TOYOTA 4RUNNER 4x4 SR5 SPORT EDITION
SILVER
3.4L V6 5VZ-lFE
4-Speed A340lF Automatic Transmission
4x4
4.30:1 Differential Gears w/ E-locker
an offroader who happens to own a rooftop tent.
Most recent pictures as of Feb, 2020:
9A0A2834
9A0A1379
IMG_0674
UPGRADES & MODIFICATIONS
Suspension:
Front:~0.5" lift
King Extended Travel
600lbs Coils
SPC Upper Control Arms (Set at F for clearance)
Plastics Guy Front Duro Bumps
Rear:~2.5" lift
-OME 861's
-4th Gen Extended Travel Bilstein 5100's
-Plastics Guy 5.25" Duro Bumps
Wheels & Tires:
-Stealth Custom Series F5's in Gloss Black - 16x8
-315/75/16 TreadWright Guard Dog M/T (firewall chop for clearance)
Load range "D"
Engine & Performance Upgrades:
-Deckplate Mod
-Airaid Intake Elbow
-OEM filter
-Transmission Cooler
-PVC Washer Fluid Reservoir
-Trail Gear Bomb Proof Motor Mounts
Undercarriage / Drive Train Upgrades:
**Front End**
-Tundra 231mm Brakes (13WL) (power stop rotors)
-4.30 gear Ratio (Planning on 5.29)
-1.25 Hubcentric Spidertrax Wheel Spacers
-Toytec Poly Steering Rack Bushings
**Rear End**
-Factory E-locker: 4.30 gear Ratio
Electrical Modifications:
-Rats nest for lights and winch
Interior Upgrades:
-Sherpa Equipment Co. PAK System Drawers
-Transmission Temp Gauge (A-Pillar)
-Oil Pressure Gauge (A-Pillar)
-Scan Gauge Mounted behind the steering wheel
Stereo/ CB/ HAM:
-Kenwood Double Din Touch Screen
-Esky EC170-06 Backup Camera
-Pioneer Premium speakers
**CB Radio
-Midland MXT275 in the ashtray
Exterior Upgrades:
-Matterhorn Roofrack from Sherpa Equipment Co./URL]
-Tepui Explorer Series Ayer 2
-20% Tint all around
**Exterior Lighting**
-Custom Retrofits from SRQ Fabrications
- D2S 2.0 35W Ballast and 5500k Bulbs. Apollo 1.0 Shroud w/ 90mm Switchback Halo
-LED Tail Lights (Black) (Eagle Eyes)
-LED Front Turn signal under the headlight
-Element Canons as Fogs
-X6S Slim Series 2D Amber White 38" Single Row
-12" Extreme Led Dual Row
-Two Amber Stackerz from Extreme Led on Flasher Relay as Chase Lights
**Armor**
-Low Range Offroad E-Locker Skid
-Custom Rear Lower Control Arm Mount Skids
Stock Lower Control Arms with Angle Iron welded on as skid/strength
-Lil' Skips Gas Tank Skid
-Addicted Offroad Sliders
-Addicted Offroad Tube Front Bumper
- SmittyBilt X2O with Cable
- Factor 55 Pro-Link (Blue)
-4x Innovations Rear Bumper with Swing Out and High Lift Mount
(Powder coated Textured Semi Gloss)
-4x Innovation Front Diff and Transmission Skid
Ill try and keep this thread as Updated as possible and keep the images coming!!
00' SR5 SPORT - 35's - Weekend Toy
@a.flemster on the gram.
Owner of Sherpa Equipment Co.
Build Thread
Flemster is offline   Reply With QuoteReply With Quote
Old 03-09-2016, 01:15 AM #2
Flemster's Avatar
Flemster's Avatar
Eagle Eyes Tail Lights
Decided to replace my stock taillights for the black finish Eagle Eyes LED Taillights from Ebay
96-00 Toyota 4Runner SR5 Base Limited Black LED Tail Lights Lamps 1 Pair | eBay
First I uninstalled the old tail lights, You have to take out the rear piece of trim inside the back with the 5 screws. Then the one around the dome light for the rear. Then I just popped the side panels out enough to fit my hands in to unplug the lights and unscrew the ground. The ground bolt is 10mm. (Be careful with the plastic pins, they break very easily. I would recommend using a body panel clip tool or a putty knife)
Here are the old Taillights, I did not get a picture of the New ones before I put them on the car because UPS showed up at 8 and it was dark outside.
I got the new lights Installed and everything buttoned up again in about 20min, the whole project took about 40 minutes MAX. Remember to reattach the ground wires, and check to make sure everything is working before closing it all up again. Here is the finished product, I love the way they look and they are much brighter.
[IMG][/IMG]
Old 03-09-2016, 01:24 AM #3
Flemster's Avatar
Flemster's Avatar
Rear Cargo Box with Drawers
REAR CARGO DRAWER SYSTEM
Used my lacking woodworking skills and came up with this in the end!
Got all the information from this thread and just did my own measurements for my needs
Rear Cargo Drawer Build - Toyota FJ Cruiser Forum
Old 03-09-2016, 01:45 AM #4
Flemster's Avatar
Flemster's Avatar
Day Trip Yankee Hill (3/6/16)
Yankee Hill
Had some fun with some local Toyota buddies!
My friend is a "pretty boy" and likes to pose!
Old 03-09-2016, 01:54 AM #5
Flemster's Avatar
Flemster's Avatar
Interior Shot
Para-cord Wrap
Garmin GPS
A-Pillar Gauge Cluster
- Oil Pressure
- Trans Temp
Old 03-09-2016, 12:40 PM #6
Tinigunner11's Avatar
Tinigunner11 Tinigunner11 is offline
Real Name: Austin
Tinigunner11 will become famous soon enough
Real Name: Austin
It's about time man! Glad to see you have a build thread. I've been following you on Instagram for a while now, you do nice work! Keep it up! Subbed for sure!
Tinigunner11 is offline   Reply With QuoteReply With Quote
Old 03-09-2016, 01:30 PM #7
GSPRunner's Avatar
GSPRunner GSPRunner is offline
GSPRunner is on a distinguished road
GSPRunner's Avatar
Is it cool if I jack more of your pics and use them on my Instagram? I won't give you any photo cred of course.
2000 4Runner Limited 4WD Built. Totaled
2014 4Runner Trail Premium Not Built.
2017 Tacoma DBLCB TRD OR
The Builds
GSPRunner is offline   Reply With QuoteReply With Quote
Old 03-09-2016, 01:35 PM #8
Flemster's Avatar
Flemster's Avatar
Yes please!! Be my "Savior" if you will Flemster's 2000 SR5 SportFlemster's 2000 SR5 Sport That guy needs his paged taken down ASAP! He blocked me and @Limbwalker _
Build Thread
Old 03-09-2016, 01:44 PM #9
derpiful's Avatar
derpiful derpiful is offline
Real Name: Hayden
derpiful will become famous soon enough derpiful will become famous soon enough
derpiful's Avatar
Real Name: Hayden
Glad to see you finally have one of these, welcome to the build thread club!
Yeah, that account/guy is so dumb. I really wish Instagram would actually do something about it.
derpiful is offline   Reply With QuoteReply With Quote
Old 03-09-2016, 01:49 PM #10
zoombyu86 zoombyu86 is offline
zoombyu86 is on a distinguished road
Great looking truck! Do you have any flat, pavement pictures?
zoombyu86 is offline   Reply With QuoteReply With Quote
Old 03-12-2016, 02:11 AM #11
Flemster's Avatar
Flemster's Avatar
Some More pics of the Runner
Update
Taken after I put on my 1.25 Spidertrax Wheel Spacers from @Bijan
Photo that @Bijan snapped of me on Yankee Hill, Love this one!
Some flat ground pics!
Super Excited to get this bumper in a few Weeks from 4xInnovations with swing out and plan to make a quick little mount for rotopax next to the tire!!
Repainting my front bumper after some harsh winter driving, it was much needed. Ill get it all back together in the morning!
Old 03-12-2016, 02:28 AM #12
Flemster's Avatar
Flemster's Avatar
Upper Shock mount!
Did the custom upper shock mounts that was posted in Ripcords Thread, came out nice and love not using those silly Bilstien 5125 adapters anymore!
Link to thread for instructions, very easy if you have the necessary tools!
Rear upper shock mount?
Old 03-12-2016, 02:44 AM #13
IsaiahC's Avatar
IsaiahC IsaiahC is offline
IsaiahC is on a distinguished road
IsaiahC's Avatar
Nice sway bar disconnect
'96 4runner Limited - Automatic 4wd with factory E-locker - LT265/75r16 BF Goodrich KO2's - Toytech/Eibach front coils and LC 8 wraps with Bilstein 5100s all around - SPC UCAs - AOR Plate Front Bumper - 4xinnovations Rear Swingout Bumper - HD-SKO Sliders
IsaiahC is offline   Reply With QuoteReply With Quote
Old 03-12-2016, 03:10 AM #14
Flemster's Avatar
Flemster's Avatar
Havnt ran rear sway bars in 2 years and took the front off a few weeks ago and it's not going backFlemster's 2000 SR5 Sport Much better articulation without!
Build Thread
Old 03-14-2016, 05:36 PM #15
Flemster's Avatar
Flemster's Avatar
Trail Day!
Trail Run
Hit Hackett Gulch yesterday with some very cool people!
[IMG][/IMG]
@Limbwalker _
https://farm2.staticflickr.com/1672/...2b55ff51_h.jpg
Justin's T4R
@JohnyWaldorf
colorado , retrofits , sport , sr5 , t4r3
DAE Denim's 2000 Sport HappyHooligan 3rd gen T4Rs 44 01-01-2019 01:34 AM
My 2000 sport. ski4runner 3rd gen T4Rs 39 04-05-2016 04:45 PM
should i trade my 2000 sr5 sport for a 03-06 v8 sport? BillIam 4th Gen T4Rs 7 07-05-2013 11:39 PM
New to Me 2000 Sport highcountry 3rd gen T4Rs 8 05-25-2012 12:42 AM
Picked up a 2000 Sr5 Sport... stro908 3rd gen T4Rs 2 11-30-2010 01:15 PM
