05-04-2020, 11:05 PM
#706
Congrats on wrapping up at CSU
@ Flemster
, and on getting out. Dying to get out to the desert myself for some banging around and biking. Nice new rig (def. beastly) and will look for you pulling your runner along I70! Soon enough...
Did you follow anything in particular for your storage drawer?
2001 T4R SR5 3.4L straight up stock (for now)
05-06-2020, 12:25 AM
#707
Real Name: Alex Fleming
@ Flemster
We designed them at Sherpa Equipment Co. It is our Sherpa PAK System.
Drawer Systems — Sherpa Equipment Company
00' SR5 SPORT - 35's - Weekend Toy
@a.flemster on the gram.
Owner of Sherpa Equipment Co.
Build Thread
07-09-2020, 11:41 AM
#708
Some fun stuff going on a week before a trip as per usual.
Ripped the whole front end down to do some maintenance and add some fun parts.
The runner finally has a garage to live in.
So naturally,
Time to give these a revive.
Some
@ eimkeith
goodies from Opt Offroad
https://optoffroad.com/collections/eimkeith
These are LCA Reinforcement Kit
Install is straight forward if you can weld. The fitment on his parts is second to none.
I also put new Whiteline bushings in the lowers.
Next is new spherical bearings in my Kings and 333Fab Cam deletes so I don't have to worry about my alignment shifting anymore. Should be all good to go up front soon.
Build Thread
07-09-2020, 01:16 PM
#709
The LCA braces look awesome.
Also adding "comfy couch right in the garage" to my envy list ;)
07-09-2020, 01:27 PM
#710
More like peed on tore up dog couch, but its a comfy sitter when you're tired and drinking a beer during a project haha. Soon to be replaced with a free99 not so ratchet couch.
Build Thread
07-09-2020, 01:31 PM
#711
Also need to add a projector, screen, and a few game systems for maximum effect.
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
07-09-2020, 04:46 PM
#712
I wouldn't get anything done in said garage hahaha.
Build Thread
07-09-2020, 06:22 PM
#713
official vendor
official vendor
Kegerator with a good beer helps everything. You'll even save money on beer too!
Mike
07-09-2020, 06:37 PM
#714
Mike
Ah yes, a good friend used to have a house with a 6-car garage, lift, triple kegerator, pool and spa. We even got work done sometimes! (where my 4WD swap was performed)
07-09-2020, 08:38 PM
#715
official vendor
official vendor
Sounds like the freind that we all need!
Mike
10-11-2020, 02:25 PM
#716
Found some time to work on some recent upgrades.
I finally installed a switch panel, it's no Switch Pro or SPOD but it'll do for what I need.
It's an Amazon cheapo something or other. Linked here Amazon.com: 8 Gang Switch Panel, YCHOW-TECH Circuit Control On-Off Led Car Switch Panel Relay System Box Waterproof Fuse Relay Box Wiring Harness Label Stickers for Car Truck Marine Boat ATV Utv: Automotive
Comes with the switch panel, mounting hardware, a fuse block to run all the wires through, and a 60amp circuit breaker. It's not bad for the price and everything seems to be of really nice quality.
I also picked up a bunch of 14awg wire, connectors, braided sleeve, and some plugs to make everything consistent and neat under the hood.
Just screwed it into the fuse box and mounted the breaker on the wheel well.
I then mounted the switch panel on the dash.
And, here is a hint of things to come...
Got all my lights back on and wired up as well.
Build Thread
10-11-2020, 03:18 PM
#717
Real Name: Roman Schnobrich
I've got a similar Switchpro knockoff from Amazon, it looks identical other than the LEDs being blue. I'm a huge fan! Glad I wasn't the only one to just put it on top of the fuse box, man these engine bays are lacking any extra room for fun.
2000 SR5 Midtravel Cookie Cutter Build
https://www.instagram.com/roamin.creative/
10-11-2020, 06:26 PM
#718
There is just no space haha. Thought about making a nice mount but honestly, it would have made it more of a pain to get to the fuse box.
Build Thread
10-11-2020, 06:47 PM
#719
It's Angle Iron for the length pieces, all the cross bars are 80/20 and the fairing is cut out of 1/8 inch aluminium as well as the thick side pieces that follow the roof line. Then everything is bolted together with Grade 5 hardware!
I love the rack. My 2000 came with no rails. So gotta figure that out.
Thanks
10-13-2020, 07:02 PM
#720
Build Thread
