Tell us about your aftermarket front bumper installation.
After installing my own Shrockworks front bumper, I began to wonder how some of the different bumpers varied in installation.
It seems that most that I have read about involve cutting the flanges off the front portion of the frame and a bit of welding, while others make it sound as if they just bolt on.
I know it doesn't happen often, but do people trade out one aftermarket bumper for another? Does cutting the flanges off the front portion of the frame negate being able to use bumpers that rely on using that hardware?
I have been considering another design that does not have full hoops that are as close to the grill and body. I was wondering if most aftermarket bumpers have you remove these flanges, thus, being able to swap out one bumper for another.
So...
What aftermarket bumper did you go with and why?
What modifications did you have to do to install your bumper? Cutting? Welding?
How did installation go?
Did you have it powder coated, did you rattle can it, bed liner, or use another finish option? How is it holding up?
Are you happy with your bumper, or would you go with something else next time?
My 4xinnovations bumper bolted up, no modification needed. Getting the holes perfectly aligned required some use of a jack but other then that pretty easy.
Trevor's 2002 4Runner 4x4 Sport Edition. Front: TRD Tundra Coils on 5100's, Rear: 7.5 Wrap LC Springs, LC shocks. Corbeau Baja RS Seats, 255/85/16 ST Maxx, Toytec Diff Drop, 4xInnovations Sliders, Spidertrax Wheel Spacers, Aussie Locker (rear), Toytec 2" body lift, 231mm Tundra brakes, AEM UEGO, 4xInnovations front bumper.
the ones where cutting is required will be stronger, the flange on the front of the frame is a joke. of the aftermarket mounts my favorite is the addicted offroad. that being said the mount I made for my bumper is nice because i can put the bumper on then bolt it up afterwards without using jacks or two people.
I mounted my Addicted Offroad bumper yesterday. I didn't realize I would be cutting the front flanges off and drilling two holes in the frame, but it wasn't a big deal. However it would've been good information to have. Unfortunately, the upper-forward holes of the bracket didn't line up with the existing holes in the top of the frame. Since I had already cut off the stock bumper mounts I had no choice but to mount the bumper bracket using only the existing weld nuts that the stock recovery points attach to. If I had removed any more of the frame to line up the bracket with the hole, the lower attachments points of the bracket wouldn't have lined up with the weld nuts in the frame any longer. The bracket and bumper is solid on the frame but is certainly temporary. I'll have to work with Scott at Addicted to get this figured out. Overall my experience was a little frustrating and disappointing. I like the look and build quality of the bumper. But to get to the point of no return and be forced to continue with a less than secure solution doesn't leave me feeling all warm and fuzzy with Addicted at the moment.
1993 Toyota Pickup, V6, ARB, Warn, a lot of LC Engineering Goodies, 130K Original Miles (Current ride)
2000 4Runner Limited (Sold to a friend )
I had a shit show of a front bumper. It mounted using all factory points. Weak mounting system. Bolted to the bottom using 1/8" "strap" brackets where the tow hooks are. Then 10 gauge brackets on the vertical supports off the frame rail. It left it where the OEM bumper could be re-installed rather simply. It looked decent, but was very weak after doing some homework and considering why one puts armor on to begin with.
Now I have an addicted bumper. I ground the material off around the frame end caps so it's still nice and sealed up. Painted it, then the bumper is a one man show. Just pick it up and set it on the frame rails. Very nice mounting system.
If one were to return to stock, you'd have to hit up a junkyard, cut the ends of the frame off, and weld them back onto the end of your frame rails. A lot of screwing around, but if you ever hit something, the way I figure, the stock bumper would have collapsed and destroyed the front end. At least with the aftermarket stuff, it's much more rigid and should handle a lot more without trashing the front of your truck.
I've got a '96 4Runner I bought about 4 years ago. I've finally ordered a new valence bar (the gray piece on the front) and I got out on it today to take the old one off and found that my actual bumper is in the way of the bolts on the outer edges of the valence. Do I need to take my entire bumper off just to change to valence?
The Shrockworks front bumper is one stout piece of metal. Installation is definitely is not a one man job unless you are a fan of pulleys, leavers, and good old Roman engineering. My installation was a bit of a handful.
We cut off the frame flanges, welded in the new endcaps, had to do a bit of grinding to get the frame mounts to seat flush with the frame. But when it came time to mounting the bumper to the frame, it was a no go. The mounting brackets did not have enough room to allow the bumper to sit between the two guide rails. We used various devices to try to spread the mounting bracketso enough to mount the bumper. We finally got it sorted, but it was not easy. Now I am kinda wishing that I went with the Pre Runner center only guard tube. The Pre Runner tube is angled enough away so as to let you work on the front without taking the FB off, which seems like a huge PITA.
I might look at switching my FB out for another option that is not as formal fitting.
Sounds like my Shrockworks install experience. The mounting brackets were not anywhere near useable. Thankfully, my buddy has a CNC machine. We had to notch the brackets a good 1/2" x 3" to get them to work.
Also had the same issue trying to wedge the bumper in between the brackets, it took plenty of floor jacks and a heavy dose of dead blow hammering. It still is not exactly where I want it.
But... It is such a great looking bumper.
'99 Millenium Silver SR5. Auto, Shrockworks front bumper, Engo winch, Tundra 231mm, Toytec Ultimate lift, Light Racing UCAs, Tundra wheels, 285/70/17" Duratracs, B&M trans cooler, Whitson Metalworks short roof rack.
I got the Savage hybrid. The installation was very easy. No cutting or drilling required and all the holes lined up perfectly. That's one of the main reason got, since I'm not very mechanical and it looks nice and quality built.
'97 Limited 285 75 r16 stock suspension Savage front and rear bumpers
That Savage bumper looks good on your rig. To me, the Savage looks very similar to the CBI front bumper. They both look a bit more aggressive than your average bumper, but very clean looking. So you just had to grind off the flanges then bolt it up?
Yep then bolt on the brackets and then hang the bumper on then and bolt it to the brackets. It's a one person job.
I though only the 00-02 require the cutting/welding/drilli g and not the 96-99?
That savage bumper looks sweet. I've been wanting it forever. If you can mount a winch and use the bumper and it mounts to stock location. It's pretty strong.
97 3.4 JDM/5 Speed swap/eLocker Swap/ICON CDC all around/+more.....
