Old 03-20-2016, 08:58 PM #1
99LTD's Avatar
99LTD 99LTD is offline
99LTD is on a distinguished road
99LTD's Avatar
99 Rear Hatch Lock "Frozen"
Noticed the other day when trying to unlock my car from the rear hatch that the lock is wont turn either way. The key goes in fine but feels like I have the wrong key when I turn it. Doesn't budge and I don't want to turn it too hard and risk breaking something.
I tried my spare key which is still brand new thinking maybe the grooves on my main key were becoming worn and it did the same thing.
This is a recent thing as I use the rear lock fairly often for both unlocking and rolling down rear window.
Anyone else ever run into this?
Thanks in advance. Great forum by the way. I'm not a frequent poster but definitely a frequent lurker.
99LTD is offline   Reply With QuoteReply With Quote
Old 03-20-2016, 09:10 PM #2
ChildrenOfBodom's Avatar
ChildrenOfBodom ChildrenOfBodom is offline
Moderator
Real Name: James
ChildrenOfBodom is a glorious beacon of light ChildrenOfBodom is a glorious beacon of light ChildrenOfBodom is a glorious beacon of light ChildrenOfBodom is a glorious beacon of light ChildrenOfBodom is a glorious beacon of light
Moderator
Real Name: James
I don't know of any good methods to free it up, but good call on not turning it too hard. Those rear license plate/lock surrounds are weak, often times, the portion of plastic holding the lock in place will break.
Good luck though.
IG: @jimharb | YouTube | '99 Limited 2WD |
'99 4Runner - 2.7L 3RZ-FE - TRD S/C - 4WD Conversion + R150F 5-Speed Swap - Imperial Jade Mica on Oak
'87 4Runner Turbo - 2.4L 22R-TE - CT-26 Supra Turbo - W56 5-Speed Swap - Red on Red
'90 4Runner 2-Door - 3.0L 3VZ-E - Auto to R150F 5-Speed Swap - Red on Gray
'94 Supra Turbo Targa - 3.0L 2JZ-GTE - Marlin Crawler R154 - Imperial Jade Mica on Black
'89 Supra Turbo Targa - 3.0L 7M-GTE - Marlin Crawler R154 - White Package on Blue
'89 Pickup DLX 2WD - 2.4L 22R-E - W55 5-Speed - White on Blue
ChildrenOfBodom is offline   Reply With QuoteReply With Quote
Old 03-20-2016, 09:53 PM #3
MyHigh's Avatar
MyHigh MyHigh is offline
Real Name: Tim
MyHigh is on a distinguished road
MyHigh's Avatar
Real Name: Tim
It could very well be your key!
So the rear lock gets used maybe less then 5% of the time while the key is getting used every day. The ignition and driver door as well get used more often to boot. Go get a new key cut ( not a copy of your key in hand) and see if that helps, if not then it's time to dig a little deeper. But cheap and easy first.
'99 5-speed, URD short shifter, Tundra Bilstien/881, 5100/891, TT diff drop, SS Panhard Bar, Studt drop links, Projectors, E-Locked, 231 TBU, Highlander
MyHigh is offline   Reply With QuoteReply With Quote
Old 03-20-2016, 10:31 PM #4
RPS99SHO's Avatar
RPS99SHO RPS99SHO is offline
RPS99SHO will become famous soon enough
RPS99SHO's Avatar
When I bought mine the hatch lock was just about seized. A liberal soaking of WD40 freed it right up.
RPS99SHO is offline   Reply With QuoteReply With Quote
Old 03-20-2016, 10:39 PM #5
pluton's Avatar
pluton pluton is offline
Real Name: Keith
pluton has a spectacular aura about pluton has a spectacular aura about pluton has a spectacular aura about
pluton's Avatar
Real Name: Keith
WD-40/PBBlaster/etc followed by a real lubricant like Triflow. Can't hurt.
pluton is offline   Reply With QuoteReply With Quote
Old 03-20-2016, 11:14 PM #6
The Count The Count is offline
The Count is on a distinguished road
Liquid graphite is the correct lubricant for lock cylinders. Try it, it works wonders.
The Count is offline   Reply With QuoteReply With Quote
Old 03-21-2016, 05:45 PM #7
99LTD's Avatar
99LTD's Avatar
Liquid graphite is a great thought. Will give that a try.
I haven't used that stuff since I was a kid and put it on the wheels of my pinewood derby car in Boy Scouts. Thing won every race.
Old 03-24-2016, 11:57 AM #8
99LTD's Avatar
99LTD's Avatar
$6 bottle of liquid graphite 'Lock-ease' from Amazon did the trick. Thanks all.
Old 03-24-2016, 12:07 PM #9
thegipper's Avatar
thegipper thegipper is offline
thegipper is a jewel in the rough thegipper is a jewel in the rough thegipper is a jewel in the rough
thegipper's Avatar
A solution of 50% ATF (whatever cheap stuff you can find) and 50% acetone is the best penetrating oil you can buy (make yourself). If that doesn't free up anything frozen in there, nothing will...
thegipper is offline   Reply With QuoteReply With Quote
Correct location for rear hatch "Toyota" emblem? bugman-74 3rd gen T4Rs 3 03-10-2015 12:02 AM
Replaced frozen caliper, now a frozen "pin"? dwulffusa 4th Gen T4Rs 1 09-01-2013 06:47 PM
WTB: OME 906 Coils & "SR5" + "4wd" Rear Hatch Badges slampe Want to Buy/Trade 0 08-14-2011 09:00 PM
"Electronic rear hatch locking system" LongBallLarry 5th gen T4Rs 12 07-16-2010 04:32 PM
