Originally Posted by habanero
Today I measured my stock original sway bar and endlink rods with calipers to be:
1. Sway bar midpoint diameter was 1.042 inches (roughly 26.5mm)
2. Endlink bar midpoint diameter was 0.395 inches (roughly 10.0mm)
I called both companies to get sizes, and I was disappointed that they both seemed to be wholly unaware of the mismatched size problem.
1. Energy Suspensions 8.5118{R,G} kit: 888-913-6374 (the problem is apparently the swaybar body bushing size at 27mm is too big by 1mm)
2. Prothane #18-1115 kit: 888-776-8426 (the problem is apparently the endlink bushing size, at 0.600 inches is huge with roughly 5.5mm of slop!)
Domenic at Prothane told me the bushings should be undersized by 20 thousandths of an inch (0.5mm) for a proper fit.
Given that and the diameter of my positively stock OEM sway bar and endlinks, the size of the bushings should be:
1. Sway bar body bushings should be 26mm (1.024 inches)
2. Endlink rod bushings should be 9.5mm (0.375 inches or 3/8-inch)
I'm still confused about what sizes are actually shipped in the two kits, but it seems that the right sizes can only be obtained by getting
1. The 26mm (1.024 inch) swaybar body bushing from Prothane
2. The 9.5mm (3/8th-inch) endlink rod bushings from Energy Suspensions
Since it's unfair to have to purchase both kits just to get one fit, does anyone suggest a DIFFERENT kit manufacturer who has the part sizes right?
Lots more detail in this thread:
Found this greasy rubber part under my 4Runner (makes noise now)
