Old 03-31-2016, 10:31 AM #46
nissanh nissanh is offline
Sliding under a lifted car/truck is a RISK. If you plan to go under that man made stuff, expect the worst. Be ready. Place the maximum number of supports you can find. If that falls, that is the end of the life. You will miss everything in your life. So be ready for worst and be prepared.
Old 03-31-2016, 11:23 AM #47
mtbtim's Avatar
mtbtim mtbtim is offline
Real Name: Tim
mtbtim's Avatar
Real Name: Tim
Since the jack he was using is intact, it must not have been the lock wasn't fully engaged like he surmised. Once the weight of the truck is on a jack stand that is properly placed on a frame member, axle or wherever, short of an earth quake, I don't see there being a huge concern working under the truck. But, redundancy is good and placing removed tires underneath or keeping the hydraulic jack in place is a good idea. I think most accidents are due to people working under a vehicle with just a hydraulic jack for support, like the one that comes with the truck and fits under the back seat.
Accidents happen and I'm glad Ol' Shooter wasn't flattened.
Old 07-02-2020, 09:47 PM #48
numbbrrr numbbrrr is offline
numbbrrr is on a distinguished road
WHERE to lift using farm jack?
I have a 5th Gen 4runner that I lifted a good 4-5 inches. I took the plastic off where the running boards were but never put rail sliders. I can't use a bottle jack anymore. WHERE can I put the farm jack to lift up my 4runner if I need to change a tire in an emergency?
numbbrrr is offline   Reply With QuoteReply With Quote
Old 07-02-2020, 11:33 PM #49
ArmArak's Avatar
ArmArak ArmArak is offline
ArmArak will become famous soon enough ArmArak will become famous soon enough
ArmArak's Avatar
I bet it was made in either USA, Germany, or Japan.
ArmArak is offline   Reply With QuoteReply With Quote
Old 07-02-2020, 11:52 PM #50
HiluxSurf SSR-G's Avatar
HiluxSurf SSR-G HiluxSurf SSR-G is offline
HiluxSurf SSR-G will become famous soon enough HiluxSurf SSR-G will become famous soon enough
none. unless you have steel bumper(s) and sliders
you'll need to bring a block of wood, maybe two, to compensate for the lift
HiluxSurf SSR-G is offline   Reply With QuoteReply With Quote
Old 07-05-2020, 02:47 AM #51
T4R2014's Avatar
T4R2014 T4R2014 is offline
T4R2014 is a splendid one to behold T4R2014 is a splendid one to behold T4R2014 is a splendid one to behold T4R2014 is a splendid one to behold T4R2014 is a splendid one to behold T4R2014 is a splendid one to behold
T4R2014's Avatar
Should still be fine on the rear axle tube. I use a regular floor jack on the front LCA but I'm not sure I want the bottle jack there.
Old 07-05-2020, 03:01 PM #52
Mark_BC's Avatar
Mark_BC Mark_BC is offline
Real Name: Just call me the Grease Monkey
Mark_BC has a spectacular aura about Mark_BC has a spectacular aura about
Mark_BC's Avatar
I put the bottle jack between those 3 round bolt heads under the LCA and it seems to work fine.
My Snow and Sand build thread
Mark_BC's 2000 Limited Salvage Build
Determined to keep them from becoming parts trucks. Yes, even the one I just picked up as a parts truck...
Mark_BC is offline   Reply With QuoteReply With Quote
Old 07-05-2020, 08:00 PM #53
absalom's Avatar
absalom absalom is offline
Real Name: Jordan
absalom has a spectacular aura about absalom has a spectacular aura about
absalom's Avatar
Real Name: Jordan
All the comments defending Harbor Freight jack stands in this thread aged like milk ...
absalom is offline   Reply With QuoteReply With Quote
Old 07-06-2020, 01:59 PM #54
The factory emergency jack will work just fine under either the rear axle or the front control arm. For emergecy use, of course. At home, floor jack under rear diff and jack stands on the outer ends of the axle along with the jacking point in the front/center and jack stands under the frame rails behind the front tires.
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
Old 07-25-2020, 02:29 PM #55
Thank you
I will keep the bottle jack. In the meantime I had ordered a bottle jack with a extended jack stand that is factory welded onto the bottle jack. It extends the height, sort of a 2 in 1.
jacking
Jack Stand Safety Question MyFirstRunner General Discussions 22 02-03-2015 12:34 PM
Jack Stand + Safety HOJeepster Maintenance/Detailing 8 07-30-2014 10:00 PM
Floor Jack and Jack Stand tonnage.. me_rikey Engines / Suspension / Wheels / Tires / Audio / Accessories 1 06-11-2012 09:51 AM
Jack Stand Paranoia & Lift Questions ArcticEd 5th gen T4Rs 14 03-02-2012 10:42 AM
Best Jack and Stand for 4runner bryantn 4th Gen T4Rs 3 09-05-2010 10:42 AM
