Old 07-29-2016, 05:39 PM #16
Clayton74 Clayton74 is offline
Clayton74 is on a distinguished road
Originally Posted by bugman-74 View Post
Here is an option for washer bottle relocation I have one of these on my rig, and it works perfect.
That's a really slick kit. I'll probably do something similar with my own parts and pieces.
1996 3.4 Auto SR5 E Locked & Aussie Locked 35x12.5x16 Boggers 3" Toytec Lift 10K Smittybilt X2O Herculined Interior Lots of Custom Sawzall Work
Clayton74 is offline   Reply With QuoteReply With Quote
Old 07-31-2016, 01:23 PM #17
Kurtis's Avatar
Kurtis Kurtis is offline
Kurtis is on a distinguished road
Kurtis's Avatar
Originally Posted by jmsdad View Post
Look what I found cleaning up my photobucket account. I had this saved way back then. I haven't try this mod as I live in a enhanced biennial smog check area. I know some have successfully done the charcoal delete. Let's see if you can use this...
I've done exactly this and have been using it for the last year or so. Yep, IO get a CEL from it. No it won't pass smog but it's also a trailer queen. It's not like I am driving it 300 miles a week. I didn't have room in the engine bay for it to stay. I needed a tire to go there instead.
My Junk
Kurtis is offline   Reply With QuoteReply With Quote
Old 04-03-2017, 11:25 PM #18
Stocky3 Stocky3 is offline
Stocky3 is on a distinguished road
I deleted mine and drive it every day with no cel. Find the diagram for the 3.4l swap in a 3.0 truck and use that vacuum layout for the 3.0 charcoal canister only leave out the canister. Works fine on my 96.
Stocky3 is offline   Reply With QuoteReply With Quote
Old 04-04-2017, 04:08 AM #19
HiluxSurf SSR-G's Avatar
HiluxSurf SSR-G HiluxSurf SSR-G is offline
HiluxSurf SSR-G will become famous soon enough HiluxSurf SSR-G will become famous soon enough
why not relocate it to the back near where the spare tire is, just like in the 2001-2002 4Runners?
HiluxSurf SSR-G is offline   Reply With QuoteReply With Quote
Old 12-08-2017, 02:45 PM #20
connor981332's Avatar
connor981332 connor981332 is offline
Real Name: Connor
connor981332 is on a distinguished road
Real Name: Connor
Does anyone know what the cheapest online retailer is for purchasing an EVAP canister for a 4th gen?
If you are the smartest person in the room -you're in the wrong room.
2008 SR5 V6 4WD; 153,000 Miles
connor981332 is offline   Reply With QuoteReply With Quote
Old 03-10-2018, 01:33 PM #21
AssBurns's Avatar
AssBurns AssBurns is offline
Real Name: Steven
AssBurns will become famous soon enough
AssBurns's Avatar
Real Name: Steven
I've had my EVAP/ Charcoal Canister bypassed for some time now and just barely bulled the Charcoal Canister out so I thought I'd share how I did it. The way I bypassed it is much easier and simpler than the ways mentioned above. No tee fittings, no breather tube and still vents to your intake rather than directly to the atmosphere. Gotta keep the hippies happy Honestly, it's just a better idea in my opinion so that fuel vapors are not just dumping out into your engine bay or outside of your vehicle. You will smell unburnt fuel sometimes out your exhaust but better than fresh gas fumes all the time.
There are only a few lines that need to be changed with this method. Basically all you need to do is locate your Fuel Tank Vent Line and unplug it from the Charcoal Canister. Locate your Vapor Purge Valve and unplug the lower hose that connects to the Charcoal Canister. Now plug the Fuel Tank Vent Line directly to the Vapor Purge Valve. Then locate the hose that runs from your Air Box to your Charcoal Canister. Pull the hose and cap the tube coming out of the Air Box. That's it! Now just unplug the pressure sensor and unbolt the Charcoal Canister to pull it all out. Easy peasy! This can easily be done without any modifications in just a few minutes, so everything can easily be put back into place when you need to pass SMOG or Inspection.
Hope this helps anyone that is looking to gain some room in the engine bay.
Charcoal Canister / EVAP System Delete?-img_8106-jpg  Charcoal Canister / EVAP System Delete?-img_8104-jpg  Charcoal Canister / EVAP System Delete?-img_8107-jpg  Charcoal Canister / EVAP System Delete?-img_8108-jpg
The BeerRunner - http://www.toyota-4runner.org/3rd-ge...ld-thread.html
AssBurns is offline   Reply With QuoteReply With Quote
Old 03-26-2018, 12:13 AM #22
73Duster440's Avatar
73Duster440 73Duster440 is offline
73Duster440 is on a distinguished road
Thank you sir. I owe ya one. Just completed this earlier today how you have it and no CEL
Ended up mounting it on the firewall just above the booster to keep it out of the way and to keep it tidy. Almost look like its factory.
Now I have room to mount my fuse box and have all the relays hidden underneath.
Charcoal Canister / EVAP System Delete?-img_8169-jpg
1973 Duster #'s Matching 340
1973 Duster 440 Swap
1998 4Runner 3.4 Auto
73Duster440 is offline   Reply With QuoteReply With Quote
Old 07-31-2019, 12:09 PM #23
FoCoNemo's Avatar
FoCoNemo FoCoNemo is offline
Real Name: Wes
FoCoNemo is on a distinguished road
FoCoNemo's Avatar
Real Name: Wes
Do you know of someone who has done this? I've looked all over and can't find a thread about it. I have a 96 and want to move mine to the back. Thanks!
'96 4Runner SR5: 350K, 5 Spd, rear elocker, 3" Toytec Boss front coilovers, LC80 8.5wrap springs in rear, SPC UCAs, SPC balljoints, 2" BL, 285/85/R16 Dick Cepek Extreme Country, DC-2 16" wheels, armor underneath, and lots of small upgrades.
FoCoNemo is offline   Reply With QuoteReply With Quote
Old 08-02-2019, 04:52 PM #24
Hopeless Diamond's Avatar
Hopeless Diamond Hopeless Diamond is offline
Hopeless Diamond has a spectacular aura about Hopeless Diamond has a spectacular aura about Hopeless Diamond has a spectacular aura about
Well, no joy. Tried Assburns method and after a couple of days I got a CEL (I'm assuming it's not something else but haven't checked yet). Gonna keep playing around with it, and if I can't find a way may just pull the CEL bulb and check codes every month or so
Hopeless Diamond is offline   Reply With QuoteReply With Quote
Old 08-03-2019, 06:41 AM #25
I don't know if anyone has done it. perhaps the system used in the 2001-2002 4Runners can be made to work in the 1996-2000 4Runners
Old 08-03-2019, 07:12 AM #26
sleepydad's Avatar
Real Name: Andy ಠ_ಠ
sleepydad's Avatar
Real Name: Andy ಠ_ಠ
I removed my evap in my 97 last fall and drove it around all winter, no codes. I have been looking for a decent evap from an 01,02 so I can see what’s involved. At some point I will try it. Living in the rust belt once the trucks go to salvage they are so corroded back there you would need a grinder, torch and TNT to get anything out.
Old 08-08-2019, 11:54 AM #27
SnowroxKT SnowroxKT is offline
Real Name: Kyle
SnowroxKT is on a distinguished road
Real Name: Kyle
This is exactly what I did on my 1995 3RZ-FE Tacoma. The system on my Tacoma seems slightly less complicated, but I took the charcoal canister out and hooked up the tank vent line to the purge valve which still goes to the intake. So far no CEL. About to leave on a remote hunting trip with the truck, so if no issues pop up I'll leave it this way.
SnowroxKT is offline   Reply With QuoteReply With Quote
Old 08-08-2019, 06:36 PM #28
You guys sure your CEL bulb isn't burned out LOL.
Took about 2 or 3 days, then the first code I got was for the Pressure sensor (P0450 I think). I had unplugged it so figured maybe there was some logic in the ECU that needed to see it there, whether there was any pressure to sense or not. Another few days, then the code was for incorrect purge flow (P0441). Put it all back and will noodle on this some more..
Old 08-08-2019, 11:03 PM #29
AssBurns's Avatar
Real Name: Steven
AssBurns's Avatar
Real Name: Steven
Hahah yes and no. Yes my bulb was burnt out but no the codes did not show up. I have a reader that I usually leave in the OBDII port and check it somewhat often. I don’t think I’ve gotten any of those codes ever. I did get a code at one point but it went away and never came back. I think it was unrelated to this modification.
Old 08-08-2019, 11:43 PM #30
Real Name: Kyle
Real Name: Kyle
Having some misfires occasionally now. Not sure if related but I'll undo this for now.
97 4Runner evap charcoal canister chloe Want to Buy/Trade 0 10-22-2014 10:50 PM
Charcoal canister delete KidVermicious Classic T4Rs 1 06-27-2014 02:23 PM
WTB charcoal canister EVAP jreask Want to Buy/Trade 1 06-23-2014 12:38 AM
likely EVAP Charcoal Canister problem shamrock94 3rd gen T4Rs 0 07-14-2013 02:20 PM
Evap Canister '02 sr5 3.4 v6 DzastrousRunR 3rd gen T4Rs 15 05-17-2013 03:51 PM
