Old 04-08-2016, 07:31 PM #16
meRockboost meRockboost is offline
Real Name: Rock
meRockboost is on a distinguished road
Real Name: Rock
The PO had it stock, you're right though, either way it works and works the way I want it to
2021 Nightshade (wifey’s). 1998 Limited-locked, lifted, armored, sold. 2015 SR5, stock and sold. 2002 Sport edition, sold.
meRockboost is offline   Reply With QuoteReply With Quote
Old 09-06-2019, 12:50 AM #17
Cwarrenm Cwarrenm is offline
Cwarrenm is on a distinguished road
Hey guys, I'm reviving this old thread because I have yet to find an answer after searching/reading through several threads on the topic. My ADD isn't engaging correctly and thanks to all the information i've gleaned here I was able to identify that the issue is Vacuum.
I've tested the VSV's, the actuator, the check valve, and T-case. All are working normally, but the system isn't getting any Vacuum from it's source. I traced the lines to a round thingy on the back side of the intake near the firewall and put a vacuum gauge on it with the engine running. There's no vacuum coming from it. What is it? I can't find it in any diagram of the engine's Vacuum, or 4wd components. It looks like there's another hose that comes out of the bottom and maybe runs to the gas tank but it's really hard to see back there.
I plugged the vacuum line with the check valve in it into another port on the intake that did have a measurable vacuum on it and tested the 4x4 system. Everything worked, however this is not a permanent solution. Does anyone know what the round thing is on the back of the intake that seemingly has no vacuum? I'm not pulling any codes and the engine is running normally.
I've included a picture of the part in question. Please help! Thanks!
4wd troubleshooting-img_0473-jpg
Cwarrenm is offline   Reply With QuoteReply With Quote
Old 09-06-2019, 01:15 AM #18
heat's Avatar
heat heat is offline
heat will become famous soon enough heat will become famous soon enough
heat's Avatar
vacuum hose diagram should be on the underside of the hood...
that looks like the fuel pressure regulator. Vacuum goes to it, not from it.
'02 Limited 4x4 AT - Stock ~181k miles
Thundercloud aka metallic dirt
heat is offline   Reply With QuoteReply With Quote
Old 09-06-2019, 09:08 AM #19
Bad Luck Bad Luck is offline
Real Name: Patrick
Real Name: Patrick
Fuel pressure regulator. Doesn't produce vacuum. It needs vacuum. You have vacuum lines mixed up somewhere.
Old 09-06-2019, 10:52 PM #20
Alright, this is helpful. My vacuum line runs from the VSV to a metal tube at the front of the intake. The metal tube runs all the way to the back of the intake between the upper and lower sections of the intake. At this point a rubber vacuum line connects it to what you guys are telling me is the fuel pressure regulator. I found a vacuum diagram but I don't see the VSV's on it anywhere. Where should the line from the VSV's plug into if not this tube? My 4runner is a 98, auto transmission with the J-shift T-case. Here are more pictures for clarification. Thanks for the help guys.
4wd troubleshooting-img_0474-jpg  4wd troubleshooting-img_0478-jpg
Old 09-07-2019, 09:08 AM #21
Real Name: Patrick
Real Name: Patrick
@Cwarrenm See the hose to the right of the one you have circled on the upper intake manifold? Switch those 2 hoses. Your VSV vacuum line should connect to the upper intake manifold. and the fuel pressure regulator should connect to the intake silencer resonator (the boxy section of your intake tube between the throttle body and your engine air filter box.)
Old 09-08-2019, 09:52 AM #22
Hey Bad Luck, thanks! That was exactly what I needed to know. I'm not sure how or when those lines got switched around but I'm glad it was a simple fix
Old 09-09-2019, 10:45 AM #23
Real Name: Patrick
Real Name: Patrick
You're welcome bud. I'm glad it worked out for you. Mine got accidentally switched when I did my valve cover gaskets. Oops!
Old 09-16-2019, 03:41 PM #24
denlion81 denlion81 is offline
denlion81 is on a distinguished road
Originally Posted by TheDurk View Post
Unfortunately, I can't be sure which hole is correct for which switch from the manuals I have for '98. I just have the EWD.
Hi, sorry to bring up this old post. I am new member and have some issues with 4WD and troubleshooting it too. May I pm you with a question or ask it here? It is somewhat related to this post. Thanks
denlion81 is offline   Reply With QuoteReply With Quote
Old 09-16-2019, 05:32 PM #25
Real Name: Patrick
Real Name: Patrick
What's your question?
Old 09-16-2019, 10:04 PM #26
Hi, I was trying to ask TheDurk, since he was recommended as a person who knows a lot about 4WD on 4TR. But let't try it:
I need a help in part identification/fitment confirmation. Looks like my TC actuator is dead and I need a replacement. I have used ToyotaPartsDirect ws to identify it and looks like I need 3641035040. But it costs about 1.5K new (which is insane for couple gears and electric motor), so I have decided to find an used one. The issue is that ebay doesn't seem to have one, but few of 3641035051. They look identical on pictures, but I was not able to confirm if they are interchangeable or not. Could anyone help with that? Or may be point me to some direction? Thanks.
Old 09-16-2019, 10:17 PM #27
Real Name: Patrick
Real Name: Patrick
The problem with trying to replace the transfer case shift actuator is you have to disassemble the transfer case almost entirely to replace it then you have to reassemble it and correctly orient the transfer case actuator so it functions properly. What most people do is buy a used VF3AM (multi mode) transfer case. I suggest checking car-part.com and lkqonline.com
You’ll need to find one for your year range. 96-98, 99-00, or 01-02. These are 3 different versions of multimode that are not interchangeable. For more info on this: T-case Differences (all years of 3rd gens).. transfer case, AWD, multi-mode
The other and more complicated option is to swap your transfer case to a j shift transfer case and never have to worry about another transfer case actuator again because it’s gone forever. Pretty involved if you want to do it correctly though. Driveshafts are different lengths, wiring needs to change, etc.
PS- Don’t just assume only one person has the answer to your question. There’s a lot of knowledgable folks here willing to help that know far more than I do.
Old 09-16-2019, 10:44 PM #28
The problem with trying to replace the transfer case shift actuator is you have to disassemble the transfer case almost entirely ...
Sorry, but that is not true. There are three different type of actuators (as far as I know, or may be more). I have external one with squared plug. You can take it off without even touching TC. I have just done it couple hours ago.
Anyway, the question was if those two parts are interchangeable or not. But thanks for the links - will take a look at them. It is always good to have more knowledge.
Old 09-17-2019, 08:47 AM #29
Real Name: Patrick
Real Name: Patrick
I'll be sure to let my toyota FSM know that it is wrong. The transfer case actuator assembly has a shift fork (or 2 depending) attached to the shaft. You can try swapping just the motor, but it's very difficult to time it correctly and there isn't a timing procedure for just the motor in my FSM. Good luck with that.
Old 09-17-2019, 09:20 AM #30
Sure. Thanks. Just a reminder (second time actually) that original question from me was on interchangeability of the parts with different #'s, not on how to replace actuator on TC ;)
Thanks again and good luck to you too )))
Troubleshooting help arduckhntr 3rd gen T4Rs 5 10-28-2014 08:44 AM
AC Troubleshooting chadsy 3rd gen T4Rs 3 03-17-2013 05:39 PM
TroubleShooting Help Please! TwoLeftShoes Classic T4Rs 2 12-13-2011 12:05 AM
Help troubleshooting rlsmithtech 3rd gen T4Rs 5 12-03-2011 07:41 AM
