12-14-2016, 12:25 PM
#181
Originally Posted by Tucson4runner
Hey
@ mtbtim
sorry for the late response but here's a picture of that leaking seal I have. Seems to far in to be the cv boot. What do you think?
Sent from my SM-G930V using Tapatalk
That's the seal I was going to do a video on coming up. Unfortunately, I bought a commuter car (01' Honda Accord) and working on replacing the clutch right now. If you know how to get the CV out, then it's pretty easy from there. You just need something to pull the seal with, even a flat blade screwdriver could work just don't score/scratch the metal where the seal goes. I made a video of how to replace the CV axle in our trucks, take a look earlier in this thread.
2015 T4R TRD Pro in super white, Morimoto 4300K HID kit, Auer Engineering / Toyota LED DRL/Fogs 2-in-1's, TRD drop in air filter, WeatherTech front and back liners.
2002 T4R SR5 4WD Onyx Black Sport Edition w/Leather. Gone but not forgotten.
12-14-2016, 12:31 PM
#182
Sweet I'll have to get in there when I get a chance. I just don't want to have it all disassembled and get stuck because I've never done this before. If no video pops up by the time I get to it I'll try it. Thanks guys!
work in progress
12-14-2016, 04:25 PM
#183
The two DIY ways I have used to get rid of softness in the brake pedal after any brake job is to either:
1. Bleed the brakes while the engine is running. It makes you work quickly.
2. Take the 4runner out and try to activate the ABS a couple of times. Then come back and bleed the brakes again.
12-15-2016, 12:21 AM
#184
Great TBU video
If you take off the brake line c-clip to the spindle it makes installing the brake line into the caliper 10x easier.
For next time haha.
2012 TRD Tacoma wheels
Grey wire mod
Toytec ultimate lift w/super flex rear coils
1.25 spidertrax coming soon
12-15-2016, 12:25 AM
#185
Real Name: Tim
Real Name: Tim
Originally Posted by MarkamisPrime
Great TBU video
For next time haha.
Now you tell me! It was a pain to get those threads started.
12-28-2016, 06:25 PM
#186
@ mtbtim
I noticed in your valve cover gasket video you didn't replace the 2 cam plugs in the front. I didn't either when I was helping a friend change out his valve cover gaskets because the timing plate/cover was in the way. Was that the case for you also?
1. Black 2002 SR5 4x4 5vz: Front Toytec Ultimate coilovers/eibach 600#, SPC UCA, durobumps Rear Bil5100/Superflex, SS adjustable panhard, PCK, durobumps Body Lift 2" 4crawler Tires 315/75/16 BFG KO2 Wheels SCS F5 Matte black 16x8 3.5bs Armor Custom bolt on rock sliders (no frame drilling)
2. Black 2001 SR5 4x4 5vz: stock
3. Black 2018 TRD Pro (wife’s): Armor Custom bolt on rock sliders (U-bolts)
12-28-2016, 06:34 PM
#187
Real Name: Tim
Real Name: Tim
Originally Posted by fourfive
@ mtbtim
As far as I know, there isn't cam plugs in the front. I don't remember seeing any reference in the FSM about cam plugs on the fronts of the heads. You have camshaft seals you might want to replace when doing a Timing Belt job. You'd have to remove the camshaft pulleys, use a seal puller or other DIY technique and then drive in a new one with a seal driver or some other MacGyver way.
12-28-2016, 07:46 PM
#188
@ mtbtim
hey bud, did you have any excessive squeaking when you installed the new poly bushings in your steering rack? I had a shop put them on with a new rack and for about a month now it has not stopped squeaking. Sounds like a flock of geese are stuck under my runner.
work in progress
12-28-2016, 07:47 PM
#189
I thought I saw something in the front that looked identical to the plugs in the rear but I may be mistaken.
I also noticed you listed 4 plugs in the parts list at the beginning of your video, is that correct? I only used 2 plugs in the rear which is the other reason why I thought there were 2 plugs in the front.
12-28-2016, 07:57 PM
#190
I've heard if poly bushings aren't properly torqued squeaking can become more apparent. I put a little grease on my steering rack bushings and torqued them to FSM specs and they haven't squeaked since I installed them about a year ago....I actually haven't experienced squeaking in any of the poly bushings I've installed so far. I've read that some don't grease the steering rack bushings because there's not supposed to be any movement there. If you haven't already, make sure the steering rack bushing bolts are properly torqued.
12-28-2016, 10:38 PM
#191
I'll check the torque on them and see if that fixes it. Thanks!
work in progress
12-28-2016, 11:49 PM
#192
Real Name: Tim
Real Name: Tim
Listing 4 cam plugs was a mistake on our part. I made a correction in the video description but in order to correct it in the actual video, we'd have to delete the original video and upload another one with the correction and then we'd lose all the comments and questions.
12-29-2016, 12:01 AM
#193
Real Name: Tim
Real Name: Tim
@ mtbtim
The shop probably shoved them in without any lubrication. Sorry, couldn't resist. Mine don't squeak. I do here a little creaking sometimes but I think that is coming from the poly sway bar bushings rather that the steering rack.
I lubricated all my poly bushings with some Mission Automotive Silicone Paste.
https://www.amazon.com/Dielectric-Gr...silicone+paste
To fix it, you might have to unbolt the steering rack, pull out the bushings, lube em up really good and then reinsert.
12-29-2016, 12:11 AM
#194
Real Name: Tim
Real Name: Tim
That's interesting some say not to grease the steering rack bushings. I gather all the people that subscribe to that belief all have very squeaky steering racks. The kits even come with lubrication for the bushings and tell you to lubricate them. The steering rack is going to have some movement regardless. That's what the bushings allow for. When the bushings wear out, you then get excessive movement which you don't want. So, would you rather have movement with noise or without noise? I like the no noise option.
12-29-2016, 06:41 AM
#195
Cool, good to know I didn't miss anything then. Was a very solid video.
Thread Tools |
Display Modes |
Rate This Thread |
Linear Mode
