Originally Posted by mtbtim
Hope this helps. Let me know if you have more questions.
Thanks for the info. I am quite impressed with the dirt in my driveway.
I have used the stock bottle jack to lift the front end many times with very minimal sinking.
In April Im moving to a new place that has actual concrete!
My concern is mainly the stock bottle jacks ability to balance the axle when working on the springs.
I feel like it would topple over when I start pulling on the spring and shock.
Are the rear control arms able to keep the axle from shifting forward and backwards too much?
I do have a set of gear wrenches so Im good for the top shock nut.
I will be replacing with OEM stuff, nothing fancy.
I was going to bring a chain wrench to help remove and install the shocks and extra lower shock bolts in case I break those.
I dont suppose you know the maximum length bolt that can fit the lower shock?
I read a thread where someone found their bolts cross threaded and was considering longer bolts since there are more threads than are used on installation.
I even thought about the night before my plane trip back to the states I could break the shock bolts loose just to see if the snap.
That way I would know for sure if I need new bolts or an easy out kit and all that.
Im trying to prepare for anything since resources are limited out here.
Thanks.
__________________________________________________ ________________________
"Island Paradise" 1996 Toyota 4Runner SR5 2WD 235 75r15
