Thread Tools Rating: Thread Rating: 30 votes, 4.83 average. Display Modes
Old 03-26-2019, 09:31 PM #601
mtbtim's Avatar
mtbtim mtbtim is offline
Real Name: Tim
mtbtim's Avatar
Real Name: Tim
Originally Posted by pbain View Post
I used your videos to do a valve cover job recently and ran into issues with fuel injectors which your videos also helped with. Thank you!
Glad our videos are helping you out. Happy Wrenching Brother!
Old 03-27-2019, 09:51 AM #602
sakoluvr sakoluvr is offline
sakoluvr is on a distinguished road
Tim, I love the step by step approach not to mention part numbers. Keep up the good work.
sakoluvr is offline   Reply With QuoteReply With Quote
Old 04-02-2019, 11:42 PM #603
mtbtim's Avatar
Real Name: Tim
mtbtim's Avatar
Real Name: Tim
Tranfer Case Output Shaft Seal Replacement
If you found you have a leak at the back of your transfer case, it might be due to a worn output shaft seal. This video will show you how to replace it.
Old 04-10-2019, 01:52 PM #604
firefaux firefaux is offline
firefaux is on a distinguished road
I don't see brake booster listed. I plan to use this vid on my next fix for my 3rd gen T4R.
YouTube
firefaux is offline   Reply With QuoteReply With Quote
Old 04-10-2019, 07:51 PM #605
mtbtim's Avatar
Real Name: Tim
mtbtim's Avatar
Real Name: Tim
YouTube
It looks like Ahmed needs to invest in some more tools. Do yourself a favor and don't use vice grips to loosen the brake lines on the master cylinder. The appropriate tool for this is a flare nut wrench also known as a line wrench.
Old 04-16-2019, 10:04 PM #606
#4runners #4runners is offline
Real Name: Matt
#4runners is on a distinguished road
Real Name: Matt
Wish I knew about this before I changed my valve cover gasket haha.
#4runners is offline   Reply With QuoteReply With Quote
Old 04-20-2019, 06:52 PM #607
ztphillips93 ztphillips93 is offline
ztphillips93 is on a distinguished road
can anyone help me? im doing the timing job and stripped the rear bolt to the timing belt tensioner. I have DOUCED the bolt in pb, used a bolt extractor, it just keeps slipping.
ztphillips93 is offline   Reply With QuoteReply With Quote
Old 04-24-2019, 08:23 AM #608
Ken-Cade Ken-Cade is offline
Ken-Cade is on a distinguished road
Originally Posted by mtbtim View Post
Hey Dudes,
If you were looking for a comprehensive tutorial on how to do a rear brake job on your 3rd Gen, we've got it right here.
Here's the video and Enjoy the Show!
Hi Timmy,
GREAT VIDEO!! We will definitely use this as a go-by when we replace the shoes on our '98... Unfortunately I didn't see this video till after I ordered aftermarket shoes (which did not come with the C-clips).. So I'm looking up Toyota part numbers, so that I can order those separately, and I'm finding two different numbers:
90213-07010 - Washer, C (For Rear Brake) T=1.6
90213-06013 - Washer, C (For Rear Brake)
Both show a need quantity of two and a package quantity of one. I was hoping you could maybe shed some light on which ones I should order.
Thanks in advance, and apologies if this question has already been addressed.
Ken-Cade is offline   Reply With QuoteReply With Quote
Old 04-24-2019, 12:52 PM #609
mtbtim's Avatar
Real Name: Tim
mtbtim's Avatar
Real Name: Tim
Originally Posted by Ken-Cade View Post
Hi Timmy,
I've never tried to source those c-clips separately. I bought Toyota OEM shoes for my 98 rig and it comes with the necessary clips.
Old 04-24-2019, 04:03 PM #610
Ahh I see, well thanks all the same... By the way I truly appreciate the excellent and detailed video library you have produced!! You've been a huge help to us already!
Old 04-25-2019, 08:39 PM #611
mtbtim's Avatar
Real Name: Tim
mtbtim's Avatar
Real Name: Tim
Good to hear. Thanks!
Old 04-25-2019, 11:39 PM #612
John1992 John1992 is offline
John1992 is on a distinguished road
I recently bought a 2002 4Runner SR5 and all windows, including rear and sunroof does not work. The door locks on the switches work. Also, the speedometer, and horn does not work at all. Can someone please guide me to the right path. I just put in a new master switch and still no luck.
John1992 is offline   Reply With QuoteReply With Quote
Old 04-26-2019, 12:45 AM #613
mtbtim's Avatar
Real Name: Tim
mtbtim's Avatar
Real Name: Tim
Sounds like there's some major electrical issues with this rig you bought. Quite possibly it's the reason it was sold. You can start easy by checking fuses but something tells me blown fuses isn't going to be your problem. I'd start looking for signs there was an electrical fire.
Did you ask the previous owner what was up with all these electrical issues?
Old 04-26-2019, 05:49 PM #614
Thank you for your response. After removing the panels from around the steering wheel and stereo console, I found a lot of wire that were cut off and taped. The rear window switch is not even connected. I could not even find the wire connection that goes to the rear window switch. Does anyone have a diagram to show which wire goes where?
Old 04-26-2019, 05:51 PM #615
3rd gen 4runner , mods 3rd gen sr5 , 3rd , gen , t4r
Good tech / Maintenance videos bob3dsf General Discussions 0 04-07-2016 03:52 PM
videos conchbuggy17 3rd gen T4Rs 1 10-03-2012 10:47 AM
Anyone need any how-to videos? knightsfs4 4th Gen T4Rs 19 08-07-2011 03:08 AM
New videos 4Funnr 5th gen T4Rs 7 10-31-2009 12:50 AM
Videos BlackIceWAP 3rd gen T4Rs 9 11-21-2005 03:41 AM
