Thread Tools Rating: Thread Rating: 30 votes, 4.83 average. Display Modes
Old 01-19-2020, 01:42 PM #796
mtbtim's Avatar
mtbtim mtbtim is offline
Real Name: Tim
mtbtim's Avatar
Real Name: Tim
Originally Posted by Pj Benn View Post
I really like to be fully prepared before I start on something. This thread/forum and the YouTube videos have been a huge help.
Even though it’s an easy job I knew I was fully prepared to change front diff gear oil this morning. I knew it was gonna be tough to crack the 10mm plugs. Sure enough I rounded out the drain plug. Luckily from the videos I knew to have an extractor ready. Started extracting and rounded that right out and slightly bent my new cheap breaker bar lol. Started working in the next size up extractor before I ran out of time. Oh well at least I knew what to expect going into and bought a spare plug.
Probably gonna have to pay a shop to extract the plug.
Dude, I was hoping our video on the subject would prevent this from happening. You really should have used some heat and maybe smacked the plug a couple times with a hammer. Before just going to town with another extractor, heat up around that plug for a good amount of time. What gets stuck is the bond of that copper washer to the plug. With the right amount of heat, you will get it out. If the extractor doesn't work, try the hammer and chisel technique we talk about in the video.
Old 01-19-2020, 01:54 PM #797
Brian.'s Avatar
Brian. Brian. is offline
Brian. is a name known to all Brian. is a name known to all Brian. is a name known to all Brian. is a name known to all Brian. is a name known to all Brian. is a name known to all
Brian.'s Avatar
Another "trick" is to hold as much force as possible (without the tool jumping out of the fastener and rounding it off in the first place) for as long as possible. From a strictly Technical point of view the following is False, but in practice it's true:
Torque is Cumulative, or torque = pressure(force) x time
That boils down to you being able to loosen stuck fasteners by just applying as much force as You, or the Fastener, can manage and continue to apply that force for as long as you have the strength to do so. This works on any fastener, so for any of you motorcyclists who've buggered up the chocolate-head screws that hold the top of the master cylinder on, that is the Exact thing where I was shown this tip and it works beautifully.
I don't even own an impact because this technique works with the hand-tools I already own and has proven to be so effective that I simply haven't found a reason to shell out the cash for more tools (air or electric gun, impact sockets/extensions/wobbles, etc...) If nothing else, it's a handy trick for hard-to-reach spots where that stuff simply won't fit.
Add in heat and shocking the threads as needed, and Bob will be your uncle 999 times out of 1,000.
Brian. is offline   Reply With QuoteReply With Quote
Old 01-19-2020, 07:00 PM #798
Pj Benn Pj Benn is offline
Pj Benn is on a distinguished road
I was sure I seen a video with you talking about the problem. I watched the 30k service video before starting and figured I had got confused with another post/video since it looked easy in that video. I tried hammering a bit but with a rubber mallet (so I didn’t wake the neighbors since it was before sunrise). Doubt that did anything. Pb blaster did nothing either. I thought about grabbing my torch but decided it would take way more to heat the diff up. Will try again tomorrow morning hopefully the mapp gas Burnzomatic is hot enough. can’t believe I missed that vid this morning. Thanks
Pj Benn is offline   Reply With QuoteReply With Quote
Old 01-20-2020, 02:03 PM #799
I tried 2x. Completely broke my 18in 3/8 breaker bar and gave up. Transfer case oil was easy so I tried 1 last time. Used up the rest of the mapp gas drove up the curb for more room for leverage and used an adapter on my 2ft 1/2 breaker. Stepped on it head a crack and felt give. Figured I broke the adapter or something. Checked and seen plug finally broke free! Thanks for the help and encouragement. Saved me $ from paying a shop to remove
Old 01-20-2020, 03:38 PM #800
mtbtim's Avatar
Real Name: Tim
mtbtim's Avatar
Real Name: Tim
Good job persevering and getting that damn plug out. Don't torque it to the FSM spec. Just use your best judgement and get it snug with a 3/8" ratchet. You will thank yourself the next time you have to remove it.
Old 01-20-2020, 03:47 PM #801
weekendclimber's Avatar
weekendclimber weekendclimber is offline
Real Name: Scott
weekendclimber is just really nice weekendclimber is just really nice weekendclimber is just really nice weekendclimber is just really nice
Real Name: Scott
^^^This. I had to remove another stuck plug (2nd time in a year) recently that I had tightened per the Toyota specs on a new diff from ECGS. Even with a brand new diff, with clean surfaces, and torque properly, it was stuck. After getting it out, I didn't have a replacement plug (it was a month before I was able to get back under there and put an new plug in), so just tightened the stripped one back in with the extractor I used to get it out. I bet that extractor only put, maybe, 10 ft/lbs on it. When I pulled it a month later, it was on there tight! I think maybe 20 ft/lbs on that thing is more than enough to keep it from going anywhere.
weekendclimber is offline   Reply With QuoteReply With Quote
Old 01-25-2020, 03:38 PM #802
kcferguson1 kcferguson1 is offline
kcferguson1 is on a distinguished road
What is this part?
what is this part?
This little black plastic thing broke out...important?
also seems to be leaking a bit of oil?
3rd Gen T4R DIY Maintenance, Repair and Modification Videos-img_0958-4-jpg
kcferguson1 is offline   Reply With QuoteReply With Quote
Old 01-25-2020, 04:53 PM #803
mtbtim's Avatar
Real Name: Tim
mtbtim's Avatar
Real Name: Tim
Originally Posted by kcferguson1 View Post
what is this part?
That's a breather for the starter motor. What it's purpose is, I'm not 100% sure. I'm guessing it's to give some air flow so moisture doesn't build up inside. The starter motor only runs for a very short time so I doubt it's to let pressure escape that builds up from the heat that's generated but I could be wrong.
Old 01-28-2020, 11:23 PM #804
fourfive's Avatar
fourfive fourfive is offline
fourfive is a jewel in the rough fourfive is a jewel in the rough fourfive is a jewel in the rough fourfive is a jewel in the rough
fourfive's Avatar
what is this part?
If it is the black plastic thing that attaches to the starter, I recently broke mine too when I was replacing my transmission. If I remember correctly I think there are 2 of them attached to the starter. I super glued it back on. Haven't checked to see if it stayed glued on.
1. Black 2002 SR5 4x4 5vz: Front Toytec Ultimate coilovers/eibach 600#, SPC UCA, durobumps Rear Bil5100/Superflex, SS adjustable panhard, PCK, durobumps Body Lift 2" 4crawler Tires 315/75/16 BFG KO2 Wheels SCS F5 Matte black 16x8 3.5bs Armor Custom bolt on rock sliders (no frame drilling)
2. Black 2001 SR5 4x4 5vz: stock
3. Black 2018 TRD Pro (wife’s): Armor Custom bolt on rock sliders (U-bolts)
fourfive is offline   Reply With QuoteReply With Quote
Old 02-04-2020, 04:44 PM #805
Hebrews 6:20 Hebrews 6:20 is offline
Real Name: Andy
Hebrews 6:20 is on a distinguished road
Real Name: Andy
I created a video to troubleshoot the rear defogger. I made it pretty thorough and included testing the defroster switch, location of the wiring harness points to test and other useful info.
Hebrews 6:20 is offline   Reply With QuoteReply With Quote
Old 02-05-2020, 04:17 PM #806
mtbtim's Avatar
Real Name: Tim
mtbtim's Avatar
Real Name: Tim
I added your video to the table of contents. Thanks for the contribution.
Old 02-07-2020, 06:42 PM #807
Theallsmith Theallsmith is offline
Theallsmith is on a distinguished road
1999 SR5 "not so regular" radiator support replacement
YouTube
I hope the link works in this. I did a video on how I did my rad support. You will see me remove it and place the new one in place but no welding in the video. I am an absolute beginner with bodywork so go easy on me! Figured this may help others!
Theallsmith is offline   Reply With QuoteReply With Quote
Old 02-07-2020, 07:39 PM #808
eddielasvegas eddielasvegas is offline
Real Name: Eddie
eddielasvegas has a spectacular aura about eddielasvegas has a spectacular aura about
Real Name: Eddie
Says video unavailable.
Eddie
Originally Posted by Theallsmith View Post
YouTube
2001 T4R SR5 - 180k miles and counting.
eddielasvegas is offline   Reply With QuoteReply With Quote
Old 02-07-2020, 08:31 PM #809
Eddie
If anyone knows how to embed a youtube vid that might be helpful.
My channel is "TheAllSmith" if you search radiator support you can find it there.
Old 02-08-2020, 03:19 AM #810
Real Name: Andy
Real Name: Andy
go to your youtube video on it's page, then right click the video. Choose "copy embed code" then post that here
3rd gen 4runner , mods 3rd gen sr5 , 3rd , gen , t4r
Good tech / Maintenance videos bob3dsf General Discussions 0 04-07-2016 03:52 PM
videos conchbuggy17 3rd gen T4Rs 1 10-03-2012 10:47 AM
Anyone need any how-to videos? knightsfs4 4th Gen T4Rs 19 08-07-2011 03:08 AM
New videos 4Funnr 5th gen T4Rs 7 10-31-2009 12:50 AM
Videos BlackIceWAP 3rd gen T4Rs 9 11-21-2005 03:41 AM
