Thread Tools Rating: Thread Rating: 30 votes, 4.83 average. Display Modes
Old 04-26-2022, 09:34 PM #1066
Hits831 Hits831 is offline
Hits831 is on a distinguished road
1997 4runner front door
Quick question I need a front door for my 1997 4runner and I found a front door but it's a 1998 4runner, will there be an issue installing the 1998 door to the 1997 4runner ????
Hits831 is offline   Reply With QuoteReply With Quote
Old 04-26-2022, 09:54 PM #1067
Mark_BC's Avatar
Mark_BC Mark_BC is offline
Real Name: Just call me the Grease Monkey
Mark_BC has a spectacular aura about Mark_BC has a spectacular aura about
Mark_BC's Avatar
Will you move over the inside panel and window switches? If so, then probably not. There are differences between Limited and SR5 and base models. 97 and 98 are pretty much the same electrically.
My Snow and Sand build thread
Mark_BC's 2000 Limited Salvage Build
Determined to keep them from becoming parts trucks. Yes, even the one I just picked up as a parts truck...
Mark_BC is offline   Reply With QuoteReply With Quote
Old 05-11-2022, 06:54 PM #1068
mtbtim's Avatar
mtbtim mtbtim is offline
Real Name: Tim
mtbtim's Avatar
Real Name: Tim
Knock Sensor and Knock Sensor Wiring Harness Replacement
Old 05-21-2022, 12:11 AM #1069
infamousRNR's Avatar
infamousRNR infamousRNR is offline
infamousRNR is a glorious beacon of light infamousRNR is a glorious beacon of light infamousRNR is a glorious beacon of light infamousRNR is a glorious beacon of light infamousRNR is a glorious beacon of light infamousRNR is a glorious beacon of light
ARCWORXS Shock Relocation Kit
1998 Desert Dune Toyota 4runner Limited 4x4 w/ factory e-locker
2000 BLACK Toyota 4runner Limited 4x4 w/ factory e-locker Build Thread
2002 Thundercloud Metalic Toyota 4runner Limited 4x4
Build Thread
infamousRNR is offline   Reply With QuoteReply With Quote
Old 06-03-2022, 08:00 AM #1070
jharri7140 jharri7140 is offline
jharri7140 is on a distinguished road
These are super helpful thank you for all the information.
jharri7140 is offline   Reply With QuoteReply With Quote
Old 07-19-2022, 06:22 PM #1071
eternalize eternalize is offline
eternalize is on a distinguished road
Angry 3rd gen - CV Axle replacement issue
Howdy everyone,
I am just now having an issue while replacing one of my cv axles on my 1999 4runner. I’ve installed the new cv axle that’s from autozone as youtube videos have instructed but am running into the issue of the inside end of the half shaft having around 2-4mm of linear wiggle. I’ve tried hammering it in more to no avail, only leading to slight mushrooming of the other end because i’ve hammered so much (luckily i was still able to screw on the castle nut with no cross threading).
Is this wiggle normal? Or should I try to reinstall it or replace it?
Here is a youtube video link: 3rd gen toyota 4runner cv axle issue - YouTube
Cheers, let’s hope I can fix this soon and get home!!
eternalize is offline   Reply With QuoteReply With Quote
Old 07-19-2022, 06:23 PM #1072
Howdy everyone,
Old 07-19-2022, 08:15 PM #1073
Spiker Engineering's Avatar
Spiker Engineering Spiker Engineering is offline
official vendor
Spiker Engineering has much to be proud of Spiker Engineering has much to be proud of Spiker Engineering has much to be proud of Spiker Engineering has much to be proud of Spiker Engineering has much to be proud of Spiker Engineering has much to be proud of Spiker Engineering has much to be proud of Spiker Engineering has much to be proud of
official vendor
Originally Posted by eternalize View Post
Howdy everyone,
Some play is expected - did you try pulling it out by hand after installing it? Typically if you can't pull it out by hand, the c-clip is seated and you are good to go.
High Lift Hood Struts | Ultragauge/Scangauge Mounts | Phone Mounts
Custom 3rd Gen 4Runner products | 100% designed, fabricated, and assembled in the USA
https://spikerengineering.com
Spiker Engineering is offline   Reply With QuoteReply With Quote
Old 07-31-2022, 11:22 AM #1074
mfzoom mfzoom is offline
mfzoom is on a distinguished road
I have had to do this many times
Originally Posted by mtbtim View Post
Do you have water dripping from areas of your headliner? Do you have a sunroof in your vehicle? If the answer is Yes to both questions, watch this video to try to isolate where your leak is coming from. It could be because you have clogged sunroof drains that need to cleared.
You can clear your own drains with a little persuasion from weed whacker line or some other type of solid line you can snake in the drains.
**In the video, I say the driver side rear drain travels down the B-Pillar but it actually travels down the C-Pillar and then over the wheel-well.
**Some people have employed the use of compressed air but you need to be careful if you choose this method. If you use too high of air pressure, you could force the drain tube off the fitting and then you'd be forced to pull down your headliner so you can reattach the drain tube.
mfzoom is offline   Reply With QuoteReply With Quote
Old 07-31-2022, 11:28 AM #1075
Great video
If you're in the market for an aftermarket bumper for your 3rd Gen 4runner, and you were considering buying an ARB bumper, we have a video you can use for the install. Even if you choose another brand of aftermarket bumper, the video does still have some value because we show you how to get your stock bumper off.
Enjoy the Show!
Old 07-31-2022, 12:38 PM #1076
Bad Luck Bad Luck is offline
Real Name: Patrick
Real Name: Patrick
Originally Posted by mfzoom View Post
Great video
You are clearly spamming for posts. If you have an actual problem or question you can ask it in this thread: The 3rd Gen All Questions Allowed Thread or use this to search for an answer: https://www.google.com/search?q=site...&client=safari
Old 08-29-2022, 12:28 PM #1077
mtbtim's Avatar
Real Name: Tim
mtbtim's Avatar
Real Name: Tim
ECGS Toyota 8" Rear Differential Regear / Rebuild
t
Old 08-29-2022, 12:46 PM #1078
TonyB66's Avatar
TonyB66 TonyB66 is offline
Real Name: Tony (no surprise)
TonyB66 is a glorious beacon of light TonyB66 is a glorious beacon of light TonyB66 is a glorious beacon of light TonyB66 is a glorious beacon of light TonyB66 is a glorious beacon of light TonyB66 is a glorious beacon of light
TonyB66's Avatar
t
Just 8 minutes in, and this is very helpful. Thanks!
2000 Limited, E-locker
Maintenance/Build Thread
TonyB66 is offline   Reply With QuoteReply With Quote
Old 08-29-2022, 01:48 PM #1079
octanejunkie's Avatar
octanejunkie octanejunkie is offline
Real Name: C8H18 Mike
octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of
t
So now I know where my 7.5 clamshell came from!
Great vid, Tim. Thanks!
Sent from my Pixel 4 XL using Tapatalk
1999 Toyota 4Runner SR5 Un-Sported 2WD, V6 Auto ->2WD 4runner Journal Thread
octanejunkie is offline   Reply With QuoteReply With Quote
Old 09-07-2022, 02:22 PM #1080
mtbtim's Avatar
Real Name: Tim
mtbtim's Avatar
Real Name: Tim
ECGS Toyota 7.5" Front Differential Regear w/ Eaton E-Locker Install
t
3rd gen 4runner , mods 3rd gen sr5 , 3rd , gen , t4r
Good tech / Maintenance videos bob3dsf General Discussions 0 04-07-2016 03:52 PM
videos conchbuggy17 3rd gen T4Rs 1 10-03-2012 10:47 AM
Anyone need any how-to videos? knightsfs4 4th Gen T4Rs 19 08-07-2011 03:08 AM
New videos 4Funnr 5th gen T4Rs 7 10-31-2009 12:50 AM
Videos BlackIceWAP 3rd gen T4Rs 9 11-21-2005 03:41 AM
