Thread Tools Rating: Thread Rating: 30 votes, 4.83 average. Display Modes
Old 02-03-2023, 04:31 PM #1111
octanejunkie's Avatar
octanejunkie octanejunkie is offline
Real Name: C8H18 Mike
octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of
Originally Posted by infamousRNR View Post
Who likes @eimkeith goodies?
Rear bumper build with Hot Metal Fab!
I caved and bought a 4XI rear bumper with swing out off a local FB group but would have LOVED to have run this bumper!
Sent from my Pixel 4 XL using Tapatalk
1999 Toyota 4Runner SR5 Un-Sported 2WD, V6 Auto ->2WD 4runner Journal Thread
octanejunkie is offline   Reply With QuoteReply With Quote
Old 03-27-2023, 11:34 AM #1112
mtbtim's Avatar
mtbtim mtbtim is offline
Real Name: Tim
mtbtim's Avatar
Real Name: Tim
This video shows you how to remove a pilot bearing with some bread, a bell housing bolt and a hammer. It's a very simple and effective technique.
Old 04-02-2023, 12:34 PM #1113
mtbtim's Avatar
Real Name: Tim
mtbtim's Avatar
Real Name: Tim
Head Gasket Failure Diagnosis
This video shows you one way to confirm a bad head gasket or cracked head by using a cylinder leakage tester with a cooling system pressure tester. This test only works if the suspected failure is related to cylinder pressure leaking into a coolant jacket.
Old 06-10-2023, 11:18 PM #1114
mtbtim's Avatar
Real Name: Tim
mtbtim's Avatar
Real Name: Tim
Engine Head Gasket / Cracked Head Repair (Toyota 3.4L V6 5VZ-FE ) - Part 1
Old 06-13-2023, 02:56 PM #1115
mtbtim's Avatar
Real Name: Tim
mtbtim's Avatar
Real Name: Tim
Engine Head Gasket / Cracked Head Repair (Toyota 3.4L V6 5VZ-FE ) - Part 2
Old 06-20-2023, 01:09 PM #1116
mtbtim's Avatar
Real Name: Tim
mtbtim's Avatar
Real Name: Tim
Engine Head Gasket / Cracked Head Repair (Toyota 3.4L V6 5VZ-FE ) - Part 3
Old 06-26-2023, 07:49 PM #1117
mtbtim's Avatar
Real Name: Tim
mtbtim's Avatar
Real Name: Tim
Engine Head Gasket / Cracked Head Repair (Toyota 3.4L V6 5VZ-FE ) - Part 4
Old 07-05-2023, 11:41 AM #1118
mtbtim's Avatar
Real Name: Tim
mtbtim's Avatar
Real Name: Tim
Engine Head Gasket / Cracked Head Repair (Toyota 3.4L V6 5VZ-FE ) - Part 5
Old 07-05-2023, 12:37 PM #1119
JBurt's Avatar
JBurt JBurt is offline
Real Name: Jeff
JBurt has a spectacular aura about JBurt has a spectacular aura about
JBurt's Avatar
Real Name: Jeff
I just got done doing my valve cover gaskets (they were awful) and adjusting valve shims. Thanks for your videos. They made it way easier than it could have been.
I did wrap the wire harness protector in tape like you mentioned, but it was so brittle after 27 years in the desert that it just crumbled anyways. I used this thread and wrapped the harness in silicone rescue tape, wire loom, and then metal brackets to hold it in place.
I've done headgaskets on old 60's jeeps, fairly straightforward. I'm glad you're doing a video for it, but an at least 5 parter makes me thing it's way more complicated than a 60 year old 4 cylinder!
97 SR5 4runner: 2" OME Lift, rear E-Locker, 231mm Tundra Brakes, 203K, B&M 70264 Tranny Cooler, Duratracs
Build
JBurt is offline   Reply With QuoteReply With Quote
Old 07-05-2023, 08:32 PM #1120
mtbtim's Avatar
Real Name: Tim
mtbtim's Avatar
Real Name: Tim
You're welcome. I'm happy to know our videos helped you out.
This head gasket series is going to be 7 parts. It's not a hard job, just time consuming. We broke it into 7 parts to make it a little more palatable. We like to show every detail possible to enable people to be successful.
Old 07-10-2023, 12:37 AM #1121
mtbtim's Avatar
Real Name: Tim
mtbtim's Avatar
Real Name: Tim
Engine Head Gasket / Cracked Head Repair (Toyota 3.4L V6 5VZ-FE ) - Part 6
Old 07-13-2023, 03:52 PM #1122
Grgg1978's Avatar
Grgg1978 Grgg1978 is offline
Real Name: Greg
Grgg1978 is on a distinguished road
Grgg1978's Avatar
Real Name: Greg
Hi Tim, I did not see a video on replacing the whole A/C system on a 4runner. Was wondering if you had one where the compressor and all components were replaced along with the suction and discharge line? If you don't, would this be something I could do at home as long as the system has been drained, then take it to a shop to have it recharged. Just want to make sure that if I did it at home that I wouldn't mess up the compressor if I drove it, without the air conditioning being turned on, to a shop to have it charged once I completed the install.
Greg Gonzalez-Realtor-Keller Williams Realty Southwest
-Direct- (702)302-3646
-Email- [email protected]
-Website- GregSellsVegas.Com
-99 4runner 3.4 5spd SR5 4x4 locking differential, 231 tundra brake upgrade, breather mod.
Grgg1978 is offline   Reply With QuoteReply With Quote
Old 07-14-2023, 01:26 AM #1123
JBurt's Avatar
Real Name: Jeff
JBurt's Avatar
Real Name: Jeff
You'll be fine with your plan. I did the exact same thing a year ago. If you're really paranoid you can leave the accessory belt off of the compressor and have the shop out it on
Build
Old 07-15-2023, 03:08 AM #1124
mtbtim's Avatar
Real Name: Tim
mtbtim's Avatar
Real Name: Tim
Yes, you can do what you planned. You could invest in a manifold gauge set and a vacuum pump and do the recharging yourself though.
Old 07-16-2023, 10:42 AM #1125
mtbtim's Avatar
Real Name: Tim
mtbtim's Avatar
Real Name: Tim
Engine Head Gasket / Cracked Head Repair (Toyota 3.4L V6 5VZ-FE ) - Part 7
3rd gen 4runner , mods 3rd gen sr5 , 3rd , gen , t4r
Good tech / Maintenance videos bob3dsf General Discussions 0 04-07-2016 03:52 PM
videos conchbuggy17 3rd gen T4Rs 1 10-03-2012 10:47 AM
Anyone need any how-to videos? knightsfs4 4th Gen T4Rs 19 08-07-2011 03:08 AM
New videos 4Funnr 5th gen T4Rs 7 10-31-2009 12:50 AM
Videos BlackIceWAP 3rd gen T4Rs 9 11-21-2005 03:41 AM
