01-25-2024, 07:50 AM
#1156
Real Name: BubeadedoIJ
Are you replacing the bolts as a preventive measure, and have you considered the torque specifications for the specific bolts you mentioned?
03-14-2024, 05:06 PM
#1157
Real Name: Tim
Real Name: Tim
Solo Motorsports LCA Install
If you're looking for a Lower Control Arm upgrade, Solo Motorsports makes a set worth considering.
VIDEO
03-14-2024, 05:09 PM
#1158
Real Name: Tim
Real Name: Tim
Brake Booster Replacement
If your brake booster has failed, this video will show you how to swap it out.
VIDEO
03-14-2024, 05:12 PM
#1159
Real Name: Tim
Real Name: Tim
333 Fabrications HD Billet Steering Rack Clamp Install
VIDEO
03-14-2024, 05:16 PM
#1160
Real Name: Tim
Real Name: Tim
Rear Hatch Window / Glass Replacement
If your rear hatch glass broke by some accident or some a-hole broke it for you, this video will show you how to replace the glass.
VIDEO
03-14-2024, 06:30 PM
#1161
Real Name: Jeff
Real Name: Jeff
4 videos in an update! Nice work Tim.
97 SR5 4runner: 2" OME Lift, rear E-Locker, 231mm Tundra Brakes, 203K, B&M 70264 Tranny Cooler, Duratracs
Build
03-14-2024, 07:46 PM
#1162
Real Name: Tim
Real Name: Tim
Originally Posted by
JBurt
I've been slacking on the updates. It's nice a couple people noticed.
03-15-2024, 02:07 PM
#1163
mtbtim
Lots of people appreciate the work you do! It is also great that it is out there in places other than the forum for people to find.
'99 4Runner SR5 Auto -
4WD swapped
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
03-15-2024, 02:16 PM
#1164
Real Name: Tim
Real Name: Tim
phattyduck
Yeah, because who knows how much longer this site is going to last. It's getting pretty quiet on here. Thanks!
03-15-2024, 02:19 PM
#1165
Real Name: Tim
Real Name: Tim
Rear Dome Light Repair
Hey Dudes,
If you're rear dome light has stopped working, it may very well be a problem with the switch in the hatch lock mechanism. The switch inside the lock is what tells the dome light to turn on and off based on the position of the lock.
This video shows you how to remove the locking mechanism from the rear hatch and separate the halves of the mechanism so you can access the switch to make the repair.
VIDEO
04-09-2024, 07:26 PM
#1166
Real Name: Tim
Real Name: Tim
Iconic Fab Transmission Cooler Mount
If you want to install an external transmission cooler, you should check out the custom bracket Iconic Fabrications makes to simplify the install.
VIDEO
04-17-2024, 12:40 PM
#1167
Real Name: Tim
Real Name: Tim
In this video, we show you how to replace the Uniball Joints on your set of Aftermarket Front Upper Control Arms.
VIDEO
