Originally Posted by mtbtim
Dude, I was hoping our video on the subject would prevent this from happening. You really should have used some heat and maybe smacked the plug a couple times with a hammer.
Another "trick" is to hold as much force as possible (without the tool jumping out of the fastener and rounding it off in the first place) for as long as possible. From a strictly Technical point of view the following is False, but in practice it's true:
Torque is Cumulative, or torque = pressure(force) x time
That boils down to you being able to loosen stuck fasteners by just applying as much force as You, or the Fastener, can manage and continue to apply that force for as long as you have the strength to do so. This works on any fastener, so for any of you motorcyclists who've buggered up the chocolate-head screws that hold the top of the master cylinder on, that is the Exact thing where I was shown this tip and it works beautifully.
I don't even own an impact because this technique works with the hand-tools I already own and has proven to be so effective that I simply haven't found a reason to shell out the cash for more tools (air or electric gun, impact sockets/extensions/wobbles, etc...) If nothing else, it's a handy trick for hard-to-reach spots where that stuff simply won't fit.
Add in heat and shocking the threads as needed, and Bob will be your uncle 999 times out of 1,000.
'99 Limited 4x4, Millenium Silver ~
Maintenance Thread
