Thread Tools Rating: Thread Rating: 30 votes, 4.83 average. Display Modes
Old 02-08-2020, 03:20 AM #811
Hebrews 6:20 Hebrews 6:20 is offline
Real Name: Andy
Hebrews 6:20 is on a distinguished road
Real Name: Andy
Hebrews 6:20 is offline   Reply With QuoteReply With Quote
Old 02-08-2020, 11:25 AM #812
mtbtim's Avatar
mtbtim mtbtim is offline
Real Name: Tim
mtbtim's Avatar
Real Name: Tim
Originally Posted by Theallsmith View Post
If anyone knows how to embed a youtube vid that might be helpful.
My channel is "TheAllSmith" if you search radiator support you can find it there.
I added your video to the Table of Contents. Thanks for the contribution.
Old 02-16-2020, 10:14 PM #813
Pj Benn Pj Benn is offline
Pj Benn is on a distinguished road
Since I bought my 98 4runner the diagnostic port has had a bridge between wa and wb.I ran a search here couldn’t find anything. Googling seems that it may be clearing code for abs. My rear seals were leakin, probably affecting abs according to the brake and alignment shop I use, but I’ve never seen an abs code. their scanner did not show any abs code either. I want to pull the wire bridge between the two but just wanted some expert advice/reassurance that all it’s doing is clearing code and that I’m not gonna mess anything up removing the wire. Any advice/help?
Pj Benn is offline   Reply With QuoteReply With Quote
Old 02-16-2020, 10:19 PM #814
Taco_Runner Taco_Runner is offline
Real Name: JM
Taco_Runner is on a distinguished road
Real Name: JM
Following
Taco_Runner is offline   Reply With QuoteReply With Quote
Old 03-25-2020, 01:09 PM #815
infamousRNR's Avatar
infamousRNR infamousRNR is offline
infamousRNR is a glorious beacon of light infamousRNR is a glorious beacon of light infamousRNR is a glorious beacon of light infamousRNR is a glorious beacon of light infamousRNR is a glorious beacon of light
New video for you guys, we wanted to highlight @JRZEE2000TR4LTD climate control services. He's been on the forum for a long time just like us, and has a solid track record of successful repairs. If you need your automatic climate control repaired, hit him up & mention "sicmods" in a PM or an email for 10% off!
1998 Desert Dune Toyota 4runner Limited 4x4 w/ factory e-locker
2000 BLACK Toyota 4runner Limited 4x4 w/ factory e-locker Build Thread
2002 Thundercloud Metalic Toyota 4runner Limited 4x4
Build Thread
infamousRNR is offline   Reply With QuoteReply With Quote
Old 04-14-2020, 02:20 PM #816
roger65 roger65 is offline
roger65 is on a distinguished road
Originally Posted by mtbtim View Post
Do you have water dripping from areas of your headliner? Do you have a sunroof in your vehicle? If the answer is Yes to both questions, watch this video to try to isolate where your leak is coming from. It could be because you have clogged sunroof drains that need to cleared.
You can clear your own drains with a little persuasion from weed whacker line or some other type of solid line you can snake in the drains.
**In the video, I say the driver side rear drain travels down the B-Pillar but it actually travels down the C-Pillar and then over the wheel-well.
**Some people have employed the use of compressed air but you need to be careful if you choose this method. If you use too high of air pressure, you could force the drain tube off the fitting and then you'd be forced to pull down your headliner so you can reattach the drain tube.
the sun roof on my daughters 96 wont open to get to drain lines. is there a way to hand crank these open?
roger65 is offline   Reply With QuoteReply With Quote
Old 04-14-2020, 02:37 PM #817
Gull81 Gull81 is offline
Gull81 is on a distinguished road
Thanks for your wonderful videos. Very helpful!
Gull81 is offline   Reply With QuoteReply With Quote
Old 04-14-2020, 04:01 PM #818
mtbtim's Avatar
Real Name: Tim
mtbtim's Avatar
Real Name: Tim
You're very welcome. Happy Wrenching!
Old 04-15-2020, 07:37 AM #819
agoodemail97 agoodemail97 is offline
agoodemail97 is on a distinguished road
What is Best bang for your buck 3 inch lift for my 3rd gen limited? I'm sitting on a really old 3 inch in the rear and a spacer leavening kit be front. I am tired of it hahaha. Anyone pulled the fender Flair's off there limited and bondoed the hole I was tired of all the plastic Bondo tips?
Sent from my Pixel 4 XL using Tapatalk
agoodemail97 is offline   Reply With QuoteReply With Quote
Old 04-15-2020, 02:07 PM #820
mtbtim's Avatar
Real Name: Tim
mtbtim's Avatar
Real Name: Tim
This thread will be a good start for your research:3rd Gen 4Runner Lift Information and FAQ's
Old 04-16-2020, 05:12 PM #821
b3ardroyalty b3ardroyalty is offline
b3ardroyalty is on a distinguished road
how quickly should my 97 take to start when turning the key?
Sent from my SM-N960U using Tapatalk
b3ardroyalty is offline   Reply With QuoteReply With Quote
Old 04-17-2020, 11:21 PM #822
I have a 97 as well. Cold start, usually 2-3 turns I think. Hot, almost no time.
Old 04-18-2020, 09:48 AM #823
mtbtim's Avatar
Real Name: Tim
mtbtim's Avatar
Real Name: Tim
You might have a bit of a fuel delivery issue. It's possible you are losing fuel pressure somewhere in your fuel lines and the extended crank time is your fuel pump getting the fuel pressure up to run your engine. I'd get under your rig and inside your engine compartment and look at your fuel line connections.
It also might mean that your fuel filter is clogged and the fuel pump is having a harder time bringing up the fuel pressure. If you haven't replaced your filter yet, I recommend you do so.
Old 04-22-2020, 02:06 PM #824
beklemmung's Avatar
beklemmung beklemmung is offline
Real Name: Levi
beklemmung is on a distinguished road
beklemmung's Avatar
Real Name: Levi
Hey Dudes,
@infamousRNR and I have a double feature for you. If you were looking for a video tutorial to do the whole job on your own so you don't get bent over at a shop or have to pay a machine shop to do the press work for you, we got you covered. We have a video for ABS Rearends and Non-ABS Rearends.
Hey Tim, I'm probably an idiot, but I'm not seeing a pinned comment for the ABS video regarding reusing the retainers and skid control rings. Am I missing something, or is there no such pinned comment?
1997 3.4L 4WD auto SR5, nearly 200k miles, pretty much all stock
beklemmung is offline   Reply With QuoteReply With Quote
Old 04-22-2020, 03:06 PM #825
mtbtim's Avatar
Real Name: Tim
mtbtim's Avatar
Real Name: Tim
I just checked and the comment I pinned is there. My comment should be the first one you see as you scroll down under the video description.
3rd gen 4runner , mods 3rd gen sr5 , 3rd , gen , t4r
Good tech / Maintenance videos bob3dsf General Discussions 0 04-07-2016 03:52 PM
videos conchbuggy17 3rd gen T4Rs 1 10-03-2012 10:47 AM
Anyone need any how-to videos? knightsfs4 4th Gen T4Rs 19 08-07-2011 03:08 AM
New videos 4Funnr 5th gen T4Rs 7 10-31-2009 12:50 AM
Videos BlackIceWAP 3rd gen T4Rs 9 11-21-2005 03:41 AM
