Thread Tools Rating: Thread Rating: 30 votes, 4.83 average. Display Modes
Old 02-10-2021, 03:28 AM #946
eddielasvegas eddielasvegas is offline
Real Name: Eddie
eddielasvegas has a spectacular aura about eddielasvegas has a spectacular aura about
Real Name: Eddie
Is this simply the Techstream cable available on Amazon and eBay for between $30 and $70? It's used in conjunction with a laptop.
Thanks,
Eddie
Originally Posted by Bad Luck View Post
You don't need to program anything for 2001-2002, but you can use toyota techstream to activate the abs motor for a power bleed of the abs system.
2001 T4R SR5 - 180k miles and counting.
eddielasvegas is offline   Reply With QuoteReply With Quote
Old 02-10-2021, 11:08 AM #947
Bad Luck Bad Luck is offline
Real Name: Patrick
Real Name: Patrick
Thanks,
Eddie
That's the one. Mine came from China with poorly written instructions. I had to install and remove it a couple times before I installed it correctly and it worked for me. If you have an older laptop with windows 7 or older that would probably work best. It doesn't like windows 8 or newer OS
Old 02-12-2021, 04:28 AM #948
shawnathan9's Avatar
shawnathan9 shawnathan9 is offline
Real Name: Shawn
shawnathan9 will become famous soon enough
Real Name: Shawn
Originally Posted by thatgirl View Post
Hi all, I have a 1997 SR5 V6 3.4L automatic with 245k miles on her. About a month ago the engine was running rough and a little shaky at stops. Read a P0304 cylinder 4 misfire code. Next day I couldn't get it to start. I replaced the spark plugs, wires, ignition coils, and nothing.... I replaced the cylinder 4 fuel injector yesterday and shes up and running.
The engine still has a bit of a shake (not nearly as bad), but I want to stay on top of it. I let it idle for a while and drove it around some with no change. Any ideas what else could cause that rumble?
Check the simple things first:
  • Clean/replace your Air filter, if necessary.
  • Clean the MAF sensor.
  • Clean the throttle body.
  • Check your vacuum hoses.
  • Test your alternator
  • Check your belts and tensioners to make sure things are snug and not lose or over tightened.
1996 Toyota 4Runner Limited 4WD E-locker; Desert Dune/Silver (K84)
shawnathan9 is offline   Reply With QuoteReply With Quote
Old 02-12-2021, 04:05 PM #949
infamousRNR's Avatar
infamousRNR infamousRNR is offline
infamousRNR is a glorious beacon of light infamousRNR is a glorious beacon of light infamousRNR is a glorious beacon of light infamousRNR is a glorious beacon of light infamousRNR is a glorious beacon of light infamousRNR is a glorious beacon of light
Borla muffler install
1998 Desert Dune Toyota 4runner Limited 4x4 w/ factory e-locker
2000 BLACK Toyota 4runner Limited 4x4 w/ factory e-locker Build Thread
2002 Thundercloud Metalic Toyota 4runner Limited 4x4
Build Thread
infamousRNR is offline   Reply With QuoteReply With Quote
Old 02-16-2021, 03:07 PM #950
Endlessblockades's Avatar
Real Name: Blair
Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold
Real Name: Blair
Nice - on those wet City Streets!
Old 02-18-2021, 11:06 AM #951
SamZap! SamZap! is offline
SamZap! is on a distinguished road
1999 4Runner 3.4 2wd driveshaft vibration.
Hello!
I have a 99 4Runner I purchased it about two weeks ago it’s the 4Runner I always wanted but it has vibration. I took it to a mechanic and they told me that the driveshaft and I joints were good but they were installed wrong. They fixed it but it still has slight vibration not as bad as when I first got the truck. Should I just replace the whole driveshaft start new or what should I do? Please any comments help I do not want to think I made a bad purchase. That is the only thing I feel is wrong with it and it’s the 4Runner I always wanted lol.
SamZap! is offline   Reply With QuoteReply With Quote
Old 02-18-2021, 01:03 PM #952
weekendclimber's Avatar
weekendclimber weekendclimber is offline
Real Name: Scott
weekendclimber is just really nice weekendclimber is just really nice weekendclimber is just really nice weekendclimber is just really nice
Real Name: Scott
Originally Posted by SamZap! View Post
Hello!
Go get your tires balanced and maybe have the alignment checked as well. That could also cause vibrations. Does it happen at all speeds, or is it more pronounced at particular speeds?
weekendclimber is offline   Reply With QuoteReply With Quote
Old 02-18-2021, 01:51 PM #953
It only vibrates above 50mph not as bad as before but I can still feel it . I’ll take it this weekend to check all that out I hope that’s all it is lol.
Old 02-19-2021, 02:27 AM #954
Real Name: Shawn
Real Name: Shawn
Like weekendclimber stated, you should check to see if your wheels are balanced; maybe a wheel weight fell off?
Also, you should get a friend to turn y our steering wheel while you check your steering rack and pinion bushings to see if there's play. If so, replace those because that could also be an issue.
In a worse off scenario, you might have some bad wheel bearings
Old 02-20-2021, 10:20 PM #955
RoxToy00 RoxToy00 is offline
RoxToy00 is on a distinguished road
ok, i appreciate the research and development and manufacturing and parts specing/sourcing that goes into OEM parts. BUT WHY IN THE HELL do Toyota parts cost so much more than aftermarket parts??? Just priced parts for a tune-up on my 2000 4runner 3.4 V6 (plugs, wires, coil packs), and figured may as well replace the injectors while i was at it, as I would have to make the same tear-down for injector replacement that has to be done for a tune-up (appears the original injectors were still in service ay 240K miles, bless 'em). But $560 !!!???
I did some research/checking (semi-retired attorney, computer research has made me a lot of money) and found NEW injectors, spec dual electro plugs, 3 coil packs and wires, and the throttle body and plenum gaskets (necessary replacements when you take the fuel injection system apart to get to the coil packs and plugs), all for less than $200 delivered to my door, on Ebay.
Yes, I would rather buy from the dealer. Yes, I would love to have that close relationship with people I would like to depend on to maintain my daily transportation. Yes. I have bought a few beers for dealer service managers and dealer techs in my past years. And I have learned, and I am sure the reader knows, to build a $30K car from the parts sourced from the dealership parts department would cost $100K. A real pity, and an open secret.
I cut my teeth wrenching on '60s and '70s muscle and "fun" cars. After watching Timmy the Tool Man and a few other videos, I see nothing to prevent me from tuning up this little fuel-injected V6, but dealer parts prices are OUTRAGEOUS. I understand "Toyota reliability" that is engineered into, and expected from, the branded parts. But when shop managers tell me they regularly use Ebay parts to cut overhead, why should I pay dealer service prices for something I can do myself, with the same Ebay parts??
RoxToy00 is offline   Reply With QuoteReply With Quote
Old 02-21-2021, 01:19 PM #956
s0kalT4R619 s0kalT4R619 is offline
s0kalT4R619 is on a distinguished road
I need some help, I've looked everywhere and I can't find it. So i have no abs relay but there is a wire jumping it. Would that cause me to have no cruse control if there is no relay on my 2k 4r with 289k on the clock? Thanks for the help everyone!!
s0kalT4R619 is offline   Reply With QuoteReply With Quote
Old 02-22-2021, 01:08 PM #957
Real Name: Patrick
Real Name: Patrick
I would never trust ebay for a toyota part required to run correctly. Many have and it's caused them nothing but troubles trying to diagnose a problem they caused by using ebay knock offs. They end up having to use toyota OEM parts or remanufactured parts. Lots of threads on here about it. Especially ebay/amazon injectors.
There's no reason to replace fuel injectors or coil packs unless they have failed. They aren't a regular wear item like spark plugs and there are many 4Runners with original injectors and coil packs that are still running great. If it ain't broke then don't fix it.
Old 02-26-2021, 07:10 PM #958
Havok702 Havok702 is offline
Havok702 is on a distinguished road
I usually use Meguiars for trim. Works pretty good if you get the professional formula.
Havok702 is offline   Reply With QuoteReply With Quote
Old 03-12-2021, 01:22 AM #959
calum calum is offline
calum is on a distinguished road
3rd gen radio
Does anyone know a good factory Toyota headunit that would bolt right into the factory slot? I have a 98 base and all it has is a tape player and a regular radio. The screen broke recently so I figured now would be a good time to replace it with one from the same era, just with a CD and tape player as opposed to just a tape player.
calum is offline   Reply With QuoteReply With Quote
Old 03-12-2021, 11:40 AM #960
Rugski26 Rugski26 is offline
Rugski26 is on a distinguished road
Does anyone have a manual ECU they are willing to part ways with? Thanks!!
Sent from my SM-N986U using Tapatalk
Rugski26 is offline   Reply With QuoteReply With Quote
3rd gen 4runner , mods 3rd gen sr5 , 3rd , gen , t4r
Good tech / Maintenance videos bob3dsf General Discussions 0 04-07-2016 03:52 PM
videos conchbuggy17 3rd gen T4Rs 1 10-03-2012 10:47 AM
Anyone need any how-to videos? knightsfs4 4th Gen T4Rs 19 08-07-2011 03:08 AM
New videos 4Funnr 5th gen T4Rs 7 10-31-2009 12:50 AM
Videos BlackIceWAP 3rd gen T4Rs 9 11-21-2005 03:41 AM
