Thread Tools Rating: Thread Rating: 30 votes, 4.83 average. Display Modes
Old 04-09-2021, 04:30 PM #976
Bad Luck Bad Luck is offline
Real Name: Patrick
Real Name: Patrick
Originally Posted by Havoc_runner View Post
Hello, I just purchases a 1997 4runner and would like some recommendations on what kind of preventive maintenance I should do first?
Lower ball joints and radiator if mileage and condition are unknown. Pull back the top timing cover and look at your timing belt to see if you need to replace that or not. If you need a timing belt make sure to get all the pulleys/tensioners required, a water pump, and a new thermostat. It would be a good idea to flush the cooling system before radiator and/or water pump replacement. It's quite likely that your valve cover gaskets are leaking as well. If they are make sure to do the camseals and half moons when you do the valve covers. A new fuel filter is pretty cheap. Check your spark plugs and wires too.
Here's a helpful tool to search the 3rd gen section for whatever you may be looking for: site:toyota-4Runner.org/3rd-gen-t4rs/ - Google Search
Old 04-09-2021, 05:01 PM #977
spartacus's Avatar
spartacus's Avatar
plugs denso dual électrode k16tr11 or ngk dual electrode BKR5EkB-11(were like 4 bucks at auto zone) or Toyota 90919-91192 , ngk wires NGK (4412) RC-TE66 Spark Plug Wire Set around 30 bucks on Amazon.
Clean maf and replace air filter if dirty
PCV valve Toyota 12204-62010
Old 04-24-2021, 09:45 AM #978
Exonetics Exonetics is offline
Exonetics is on a distinguished road
It's time to build! 3d Gen 4runner
Hello 3d Gen 4Runners!
I am finally getting around to working on my SR5. I am the second owner of this 4runner, that spent its entire life in the desert of New Mexico. I have spent the last three years either in the Middle East (Iraq, Syria, Kuwait) or where I have lived in Germany. My sister has kept it garaged in her house the whole time.
I can't wait to get to this project. Before I left I had timing belt/water pump/etc. done. I think where I will start will be to get underneath and start looking for all the rubber pieces that may have been dried out from spending all those years in the dessert - any suggestions on where to get replacement parts? I will to plugs and wires right away, and do a fluids (oil and cooling; thoughts on doing transmission flush?).
I will post another picture, but the clear coat had gotten really bad (I bought it this way). I love the forrest green (does anyone know the actual name or paint color of this?), and want to restore it. I do not think it actually needs paint but likely a clear coat restoration.
Before I do the paint, what would you suggest that I do first to the exterior. I do not see a whole lot of snorkels, but I do like the look of it (and the utility, though I am not sure how much water crossing/heavy dusted trails I will be attempting).
Next, as I mention snorkels, I want to improve the airflow. Suggestions on breathers, and exhaust? Is it worth it to get a header down exhaust? How about the intake - how can I improve this?
Major mods - I have a ski boat and I am looking at small tow behind campers. I haven't driven the 4runner in years, but I recall it having decent power. However, I just got back from Germany where I was driving a 550hp Audi S6, with the Lamborghini 5.2L V10 on the unrestricted highways (autobahn). Getting in the 4runner for the first time is going to feel like I am got shrunk in Mario Cart. With johnny law and speed limits in America, this is probably a good thing. I do want the power to get 4 people and the boat ahead of a truck from a highway on-ramp though. What can I do for power?!
I bought new tires before I left, though I cannot recall what they were. I am not really looking to lift it, but would like to have a level stable ride. What can you tell me about improving the handling?
I recall the headlights being deplorable. I think I remember holding my cell phone light to navigate in the dark. Has anyone done a HID or LED headlight swap? Does just buying a new stock setup help (after 22 years..)? I think I have a rock chip in the left headlight that actually exposes the headlight chamber to the elements. What else helps improve lighting? Suggestions on mounting aux lights? I've always liked the idea of having a switchboard to toggle a bunch of lights. I thought with the color of the car, some super yellow lights might be cool (go Pack, go - Wisconsin native here).
I took this beast camping and anchored a hammock to the crossbars on the roof rack. It was strong enough that even my girlfriend at the time and I could sit in the hammock no problem. My fat ass friend took a 30ft running start to jump into the hammock and the crossbars exploded off gloriously. Watching him hit the ground as hard as he did was almost worth it, but finding new crossbars and anchors has proven to be harder than I thought! Before deploying I went to about half a dozen junk yards looking for bars (after seeing they had 4runners in stock) and they had ALL been removed already (and not hidden away with the junk yards for excessive markups). Any ideas to get these replaced? The rails are fine, and I would consider rack - potentially something that could support a rooftop tent setup, do these exist?
I am thinking about anywhere between $5k and $7k worth of mods to get rolling. My sisters and I are buying a lake house, and I want this to eventually become the old reliable at the lake-house. I have stage IV cancer at 34 years old and am not sure how long I will be around - but I hope that this ride gets another 20 years and 100k miles.
Thanks for reading! If you have any input, please let me know .
3rd Gen T4R DIY Maintenance, Repair and Modification Videos-img_0074-jpg  3rd Gen T4R DIY Maintenance, Repair and Modification Videos-img_1700-jpg
Exonetics is offline   Reply With QuoteReply With Quote
Old 04-26-2021, 11:44 AM #979
Thoughts on Superchargers? Where is a good place to get them?
Old 04-26-2021, 10:02 PM #980
JBurt's Avatar
JBurt JBurt is offline
Real Name: Jeff
JBurt has a spectacular aura about JBurt has a spectacular aura about
JBurt's Avatar
Real Name: Jeff
Toyota 5VZ-FE 3.4L V6 Supercharger System
97 SR5 4runner: 2" OME Lift, rear E-Locker, 231mm Tundra Brakes, 203K, B&M 70264 Tranny Cooler, Duratracs
Build
JBurt is offline   Reply With QuoteReply With Quote
Old 04-28-2021, 12:23 PM #981
JZiggy's Avatar
JZiggy JZiggy is offline
JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future
JZiggy's Avatar
My best suggestion is to look up some of the build threads of folks on the forum and read through... all of these questions (superchargers, suspension options, roof racks, retrofit headlights) are addressed in practical terms with good feedback on their effectiveness. All of this is possible! And there is no end to the fun modification to be done
JZiggy is offline   Reply With QuoteReply With Quote
Old 04-28-2021, 03:27 PM #982
THANKS!! Somehow getting Stage IV cancer as an active duty single military member has given me time and some disposable income to just throw at what I believe could be a gem! Low miles, always dealer serviced from the purchasing dealership, and kept in a cool desert!
Old 05-04-2021, 10:43 AM #983
mtbtim's Avatar
mtbtim mtbtim is offline
Real Name: Tim
mtbtim's Avatar
Real Name: Tim
Yota1 Performance ARB Air Compressor Bracket Install
This video shows you how to install a Yota1 ARB Air Compressor Bracket into the passenger side of your engine compartment.
Old 05-04-2021, 09:47 PM #984
Endlessblockades's Avatar
Real Name: Blair
Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold
Real Name: Blair
Hang in there, man!!
258K - Y2K/E - Clock still works
Old 05-11-2021, 01:19 AM #985
Havoc_runner Havoc_runner is offline
Havoc_runner is on a distinguished road
I'm going to do my lower ball joint replacement this weekend is there anything you recommend changing while im doing that job? new to the group and 4x4 vehicles? Thanks
Havoc_runner is offline   Reply With QuoteReply With Quote
Old 05-11-2021, 01:28 AM #986
Skulking Skulking is offline
Skulking is a jewel in the rough Skulking is a jewel in the rough Skulking is a jewel in the rough
Replace the LBJ's, and replace the bolts for the LBJ's at the same time. OEM only for both. There is plenty of other stuff in that area that can be worked on, but nothing that is a huge deal to work on later if you don't do it while you have the LBJ's off. This thread has good info on the different bolts and torque values depending on your year.
Skulking is offline   Reply With QuoteReply With Quote
Old 05-13-2021, 02:43 PM #987
Bud4me0007's Avatar
Bud4me0007 Bud4me0007 is offline
Real Name: Troy
Bud4me0007 is on a distinguished road
Bud4me0007's Avatar
Real Name: Troy
Dose any one know how the lift jack is supposed to mount. I have a 4xinnovation rear bumper. The pice on the left is bent. Is it supposed to be like that. 3rd Gen T4R DIY Maintenance, Repair and Modification Videos-20210513_144014-jpg
Sent from my SM-G981U1 using Tapatalk
2001 4unner SR5 3.4
3in lift Bilstien shocks
OME springs
265/70/16 Falken wildpeak at3w
4xinnovations rear bumper
Bud4me0007 is offline   Reply With QuoteReply With Quote
Old 05-13-2021, 05:29 PM #988
weekendclimber's Avatar
weekendclimber weekendclimber is offline
Real Name: Scott
weekendclimber is just really nice weekendclimber is just really nice weekendclimber is just really nice weekendclimber is just really nice
Real Name: Scott
Originally Posted by Bud4me0007 View Post
Dose any one know how the lift jack is supposed to mount. I have a 4xinnovation rear bumper. The pice on the left is bent. Is it supposed to be like that. Attachment 381882
That is not supposed to be like that. Probably bent in shipping.
Not the best picture, but give you and idea:
weekendclimber is offline   Reply With QuoteReply With Quote
Old 05-14-2021, 04:19 PM #989
Bud4me0007's Avatar
Real Name: Troy
Bud4me0007's Avatar
Real Name: Troy
Thanks for the pic. So the bent piece is suppose be straight? Is it possible if you could take a pic of the piece behind your tire so I can see the it looks like. And again thanks for the picture.
2001 4unner SR5 3.4
OME springs
Old 05-14-2021, 06:44 PM #990
Real Name: Scott
Real Name: Scott
I'll get one for you later this afternoon if someone else doesn't see this and beat me to it :-)
3rd gen 4runner , mods 3rd gen sr5 , 3rd , gen , t4r
Good tech / Maintenance videos bob3dsf General Discussions 0 04-07-2016 03:52 PM
videos conchbuggy17 3rd gen T4Rs 1 10-03-2012 10:47 AM
Anyone need any how-to videos? knightsfs4 4th Gen T4Rs 19 08-07-2011 03:08 AM
New videos 4Funnr 5th gen T4Rs 7 10-31-2009 12:50 AM
Videos BlackIceWAP 3rd gen T4Rs 9 11-21-2005 03:41 AM
