Thread Tools Rating: Thread Rating: 30 votes, 4.83 average. Display Modes
Old 05-17-2021, 10:07 AM #991
Mike's4Runner Mike's4Runner is offline
Mike's4Runner is on a distinguished road
I made it to the forums Tim! Looking forward to doing a whole bunch of these services using your videos..
Thanks again for taking the time to do all this work, it helps a lot!!
Mike's4Runner is offline   Reply With QuoteReply With Quote
Old 05-18-2021, 11:56 AM #992
weekendclimber's Avatar
weekendclimber weekendclimber is offline
Real Name: Scott
weekendclimber is just really nice weekendclimber is just really nice weekendclimber is just really nice weekendclimber is just really nice
Real Name: Scott
Originally Posted by Bud4me0007 View Post
Thanks for the pic. So the bent piece is suppose be straight? Is it possible if you could take a pic of the piece behind your tire so I can see the it looks like. And again thanks for the picture.
Sorry for the late follow up. Here's a look across the back from the drinker's side (near) to the driver's side:
weekendclimber is offline   Reply With QuoteReply With Quote
Old 05-18-2021, 07:27 PM #993
BootlegDoritos BootlegDoritos is offline
BootlegDoritos is on a distinguished road
Hello, David here, coming to the forum for advise and future pointers for maintenance and projects, unsure if this is a good place to post. Currently I am in the middle of an issue with a 2002 4runner. I took it to a toyota dealer to do timing belt kit and when they returned it it developed a ticking ONLY in gear. It is either only in low RPM or you just cant hear it after a certain RPM. Took it back within 20 miles, they said the master level technician took a look at it and said everything is fine and there is nothing mechanically wrong with the vehicle and wouldnt stress too much on it. they said what it could be is exhaust pulse but verified there was no exhaust leak and manifold was bolted correctly and gaskets were good. I wouldnt stress too much on it but it only has 95K miles on it and has been perfect for the 1 1/2 years ive had it. The tick sounds like it comes from the front center of the waterpump/thermo when scoping with a stethoscope. Technician verified it wasnt valve lifters, trans, or arching from coils/plugs. Genuinely at a loss now as the vehicle has never made this noise before they worked on it and strangely enough only activates in gear rev/drive. Everything is stock and the car just received its first major service in my hands.
BootlegDoritos is offline   Reply With QuoteReply With Quote
Old 05-19-2021, 08:01 AM #994
SLIVER1970 SLIVER1970 is offline
SLIVER1970 is on a distinguished road
Ladies and gentlemen, about a month ago, I was driving my 2000 4Runner limited. When I took off from a red light, there was an audible pop and the engine died. I coasted to the nearest parking spot. The engine wouldn't start. It will turn over but not start. Everything is going through my mind from timing belt slip to fuel sending unit... HELP!!.. lol
You can email me directly at [email protected]
Any help is extremely welcomed.
Thanking you in advance.
SLIVER1970 is offline   Reply With QuoteReply With Quote
Old 05-19-2021, 09:08 AM #995
mtbtim's Avatar
mtbtim mtbtim is offline
Real Name: Tim
mtbtim's Avatar
Real Name: Tim
Your timing belt probably snapped. Compress and slide back the upper radiator hose clamp, remove the bolts that hold the upper timing cover on and take a look. I'm guessing you're going to find that the belt is broken.
Old 05-19-2021, 11:36 AM #996
Bad Luck Bad Luck is offline
Real Name: Patrick
Real Name: Patrick
I agree with mtbtim that sounds like the timing belt broke off
Old 05-21-2021, 12:01 PM #997
Baybrebel Baybrebel is offline
Baybrebel is on a distinguished road
Fuel pump wiring diagram
I had a 2000 4runner that had sit for a couple months bc my wife got a new car had to replace the starter and spark plugs but it ran great for about 45 minutes then I put fuel in it and it died right when I left the gas station. I have checked fuses and relays and I can't find anything wrong with it up there I just tested the wiring harness that plugs into the pump and it wasn't getting power. Any ideas? Up for anything need to get it running Thanks in advance.
Baybrebel is offline   Reply With QuoteReply With Quote
Old 05-21-2021, 03:50 PM #998
Skulking Skulking is offline
Skulking is a jewel in the rough Skulking is a jewel in the rough Skulking is a jewel in the rough
I assume when you say pump, you are referring to the fuel pump? The fuel pump won't have power until you start cranking, were you cranking when you checked for power?
Can you give any more details of the specific problem, like it cranks but won't start?
Skulking is offline   Reply With QuoteReply With Quote
Old 05-23-2021, 08:25 PM #999
Yea sorry fuel pump and no I did not I will have to test it while I crank it and it will crank but it won't run I took power from the battery to rhe plug and the fuel pump turned on so I just assumed it wasn't getting power. The fuel pump doesn't run when the key is turned to acc.
Sent from my SM-N975U1 using Tapatalk
Old 05-30-2021, 11:22 PM #1000
1999_4Runner_Noob 1999_4Runner_Noob is offline
1999_4Runner_Noob is on a distinguished road
Can someone help me out? I just joined and don't have permission to post a new thread. I want to get my dad new headlight bulbs for Father's Day. His current headlights are awful. They are an ugly yellow that don't provide enough light to see at all during the night. What is the best plug and play bulb to get? Preferably one that produces a whiter light.
1999_4Runner_Noob is offline   Reply With QuoteReply With Quote
Old 06-21-2021, 10:08 PM #1001
infamousRNR's Avatar
infamousRNR infamousRNR is offline
infamousRNR is a glorious beacon of light infamousRNR is a glorious beacon of light infamousRNR is a glorious beacon of light infamousRNR is a glorious beacon of light infamousRNR is a glorious beacon of light infamousRNR is a glorious beacon of light
New video!
Freel Good Performance Outboard Shock Relocation Kit
1998 Desert Dune Toyota 4runner Limited 4x4 w/ factory e-locker
2000 BLACK Toyota 4runner Limited 4x4 w/ factory e-locker Build Thread
2002 Thundercloud Metalic Toyota 4runner Limited 4x4
Build Thread
infamousRNR is offline   Reply With QuoteReply With Quote
Old 07-08-2021, 01:43 PM #1002
DJ Khalid voice**
And another one!
JBAOffRoad Upper control arm installation! enjoy!
Build Thread
Old 07-12-2021, 05:07 AM #1003
WinAcer WinAcer is offline
WinAcer is on a distinguished road
Engine noise only on cold start
Hello,
I’m new here looking for help on this issue I have. I have 2000 4Runner 2.7L 4 cylinder 2WD and this noise happens only on cold starts the goes away. Please let me know what you think this could be.
Thank you
2000 4Runner 2.7 4 cylinder engine noise - YouTube
WinAcer is offline   Reply With QuoteReply With Quote
Old 07-12-2021, 04:27 PM #1004
mtbtim's Avatar
Real Name: Tim
mtbtim's Avatar
Real Name: Tim
Originally Posted by WinAcer View Post
Hello,
Thank you
It could be a pulley but it's hard to say. Get yourself a mechanic's stethoscope and have someone start and stop the engine for you you while you listen to different pulleys and areas of the engine so you can narrow down the location and possible causes.
Old 08-01-2021, 06:31 PM #1005
mtbtim's Avatar
Real Name: Tim
mtbtim's Avatar
Real Name: Tim
CS144 Alternator + Big 3 Wiring Upgrade
If you're getting into wheeling or overlanding and you're starting to add more things that cause a draw on your electrical charging system, there's a couple mods you might want to consider. One is the CS144 Alternator Upgrade and the other is the Big 3 wiring Upgrade. And, lucky for you, this video shows you how to accomplish both.
3rd gen 4runner , mods 3rd gen sr5 , 3rd , gen , t4r
Good tech / Maintenance videos bob3dsf General Discussions 0 04-07-2016 03:52 PM
videos conchbuggy17 3rd gen T4Rs 1 10-03-2012 10:47 AM
Anyone need any how-to videos? knightsfs4 4th Gen T4Rs 19 08-07-2011 03:08 AM
New videos 4Funnr 5th gen T4Rs 7 10-31-2009 12:50 AM
Videos BlackIceWAP 3rd gen T4Rs 9 11-21-2005 03:41 AM
