Old 11-14-2017, 04:51 PM #16
cbr900boy's Avatar
cbr900boy cbr900boy is offline
cbr900boy is on a distinguished road
cbr900boy's Avatar
I had the same issue with my 01, even after driving over 200 miles. I ended up replacing the post CAT O2 sensor with a Denso unit and cleared within 50 miles of driving it. Better the o2 sensor than the CAT. BTW I used the Torque app.
cbr900boy is offline   Reply With QuoteReply With Quote
Old 11-15-2017, 12:51 AM #17
GVL's Avatar
GVL GVL is offline
GVL is on a distinguished road
GVL GVL is offline
GVL's Avatar
I can't remember what code it was, but the smog tech told me to just keep driving it "so the computer can get enough data". Mine took about 150 miles before it eventually reset and gave no codes. Wish I could get more technical...
2000 Highlander - 3" OME 883F 890R - ARB F&R Lockers - AOR Bumper - Savage Armor - WARN M8000 - RIGID LED Floods - TRD Wheels - TBU - HID - BFG KM2
GVL is offline   Reply With QuoteReply With Quote
Old 11-20-2017, 06:37 PM #18
Trevsmith17 Trevsmith17 is offline
Trevsmith17 is on a distinguished road
I am in the same boat right now. my 3rd gen wont pass smog due to the readiness monitors incomplete. in need help DESPERATELY , i repaired o2 sensors , my exhaust leak, vacuum problems, cleaned throttle body and MAF and nothing seems to work!!! its very frustrating and ive been back n fourth to the smog center and the same thing keeps popping up that everything is ready EXCEPT FOR -- EVAP, O2, CAT, and 2 others aren't ready. ive driven the drive cycles multiple times now and nothing seems to be working. Ive heard to disconnect the battery to let the ECU but with my luck it wont do anything, im about ready to just pay $300 to 'pass' emissions. somebody please help SOS
Trevsmith17 is offline   Reply With QuoteReply With Quote
Old 11-21-2017, 03:27 PM #19
IBallEngineer's Avatar
IBallEngineer IBallEngineer is offline
IBallEngineer will become famous soon enough IBallEngineer will become famous soon enough
You may have a cat going bad, or maybe you haven't driven it enough. First thing is, if you don't have a scan tool and know what you are looking for, you should have a pro try to solve it for you. Paying someone off won't solve the real problem, and you should solve it for sure. What do you mean when you say you repaired the 02 sensors?
1989 FJ62 5.3 Chevy, FZJ80 Axles, 4.88's with ARB.
2000 2wd runner, 4 cylinders, yes it IS slow.
1999 4WD SR5 Desert Dune 3.4 351K and counting.
2000 4WD sport 3.4 Elocker <--My son's but I still end up paying.
2001 2WD SR5 3.4 <-- My daughter's...see preceding line.
IBallEngineer is offline   Reply With QuoteReply With Quote
Old 08-19-2018, 09:15 PM #20
Cruiser2 Cruiser2 is offline
Real Name: KP
Cruiser2 is on a distinguished road
Real Name: KP
My Son bought a 2001 2wd Limited with 220k. runs strong. passes smog but not the readiness test. we too have followed the test and my Torque tester says that it's still not ready for testing. My 1980 FJ40 was easier! i've been reading all the post and and have tried just about everything just shy of getting my money back from the previous owner of having HIM smog the dam thing. he put a new battery in just before he sold it to us.
Cruiser2 is offline   Reply With QuoteReply With Quote
Old 03-07-2019, 11:55 PM #21
thesabreslicer thesabreslicer is offline
thesabreslicer is on a distinguished road
Hey everyone,
I just recently purchased a 2000 Limited (California) from a friend and my first mistake was not getting it smogged right away. Did some electrical work on it (and in the process disconnected the battery), and when I went to smog it a few days later, it failed because the cat monitor was not ready. I drove it about 850 miles after that, went back to smog, and the cat monitor was still not ready.
After that, I found the Toyota Service Bulletin that described how to run the drive cycle for the cat monitor (linked here) and did it as best as I can 4 times. The cat monitor still refused to set.
So this morning I picked up a replacement O2 sensor and swapped it in. I haven't really driven the car since then but we'll see if that helps finally set the monitor. I'll drive it generally and also do a couple of drive cycles to see if that helps.
Barring that working, does anything else have suggestions for what I can do to get the monitor to set? If you need to know any additional info let me know too. Thanks!
thesabreslicer is offline   Reply With QuoteReply With Quote
Old 03-08-2019, 12:42 AM #22
jremus jremus is offline
jremus is on a distinguished road
You can drive that combo of mph/speed 100 times over, but if you have a bad gas cap the monitors still won't reset.
so... check/replace your gas cap. I don't mean "tighten the hell out of it" i mean, try a different gas cap if yours in 20 years old
jremus is offline   Reply With QuoteReply With Quote
Old 03-08-2019, 01:03 AM #23
My evap monitor is fine, it had no problems becoming ready. Would the gas cap still be preventing the cat monitor from being ready?
Old 03-08-2019, 03:38 AM #24
Hmm, well, I can't give definite yes or no.. But I mention the gas cap cuz my situation wasn't too different sounding last Fall.
I took a trip out of state and my battery died at the airport for that 5 days I was gone (door slightly ajar, overhead light on).
I jumped the car, drove home, thought nothing of it. Went to smog it the a day or so later because that was on my list of stuff to do that week. Failed the test.
Point is.. I was throwing cat and evap codes b/c of the battery dying and resetting my ECU. Was told "just drive a while and the codes will clear, come back and retest.."
Put 300 miles + on it over the next week or so, highway and city. Still couldn't clear it for smog-readiness. The guy even took my gas cap off, looked at it, cranked it wayyy down. then he showed me his book and said "take a picture of this drive pattern, do this exactly" and I did. several times. Still couldn't clear it.
but I had a spare gas cap and figured I should try swapping it out. Ran the drive pattern one more, cleared all my codes first-try.
So... long story aside.. I don't know if it's a "yes it totally works" but there are definitely times it seems to be something that simple.
Old 03-08-2019, 04:10 AM #25
Well I just did another drive cycle (and the first time I drove the car more than a couple miles today) and the cat monitor readied up! So looks like it was just a weird faulty O2 sensor. Thanks for the input though!
Old 03-08-2019, 01:52 PM #26
Nice! hey, any problem solved is a win. right? Glad you got it readied for smog!
Old 03-08-2019, 03:18 PM #27
AntleredRuin AntleredRuin is offline
Real Name: Daniel
AntleredRuin will become famous soon enough
Real Name: Daniel
I was also gonna point to the front O2 sensor.
I live in Texas, which allows 2 'unready' monitors on a pre-2000 vehicle and still pass, but I for the life of me could not net my new Walker Cat to be ready.
I eventually gave up because I got inspected fine, but then later replaced the front O2 sensor for an unrelated issue, and the CAT became ready the next day.
AntleredRuin is offline   Reply With QuoteReply With Quote
Old 04-19-2021, 12:43 PM #28
elykrunner elykrunner is offline
elykrunner is on a distinguished road
Originally Posted by Buckaroo View Post
Have seen your other post on Emissions Monitors not completing. I assume you have looked at the TSB that I referenced earlier in this thread that shows the drive cycles - take careful note of the preconditions. Lots of them for the Evap monitor and the Catalyst monitor won't run if the O2 monitor hasn't previously passed.
Both the Evap and catalyst monitors are two trip DTC's. They set pending codes when they fail the first time which doesn't complete the monitors and doesn't light the CEL...all the preconditions need to be met again and then they need to run/fail a second time to set the DTC (permanent code) and light the CEL. Can your scanner read pending codes? Not all scanners do....If not, you don't have a clear picture on status and all you see is your monitor does not complete. If you clear the code, disconnect the battery or lose voltage to the ECM before the monitor runs/fails a second time, everything starts over again....
Buckaroo
Hi, I am having similar issue with evap and cat not setting. It took 100 miles for the O sensor to come on. I never had a code pop up, so today I tried tripping a code by unplugging the evap sensor, and that didnt work, so I took off the gas cap too. Neither tripped a code. Reading this I would assume it would take 2 drives to make a code appear? Just trying to figure out if my computer is working properly, which I assume it is because the other monitors are ready?
So Far, I replaced the o2 sensors the the throttle position sensor and gas cap with no avail. Last time this happened I replaced the ground from the battery to the body of the car and that fixed it.
elykrunner is offline   Reply With QuoteReply With Quote
Old 04-20-2021, 07:09 AM #29
Buckaroo's Avatar
Buckaroo Buckaroo is offline
Buckaroo will become famous soon enough
Buckaroo's Avatar
Yes, you need two drive cycles to set the permanent code for the evap or cat and light the CEL. If your code reader reads pending codes, you should be able to see if that is set after one drive cycle although the CEL will not light. Also, these monitors do not run continuously. They only run when the preconditions are satisfied - if the monitor did not run, it would not even set a pending code. Attached the TSB I referenced in my original post as I see my previous link is no longer working.
2000 T4R SR5 V6 (Retired) & 2005 T4R Limited V6
2002 & 2017 XLE Camry
2004 Honda Accord
2017 Tundra Limited DC 5.7L TRD 4WD
2024 Honda Pioneer 700-2 Deluxe
Buckaroo is offline   Reply With QuoteReply With Quote
truck wont pass smog need help! 4runneracerunner Classic T4Rs 0 02-24-2014 10:54 PM
truck wont pass smog need help! 4runneracerunner Problems & Warranty Issues 0 02-24-2014 10:53 PM
SMOG - EVAP & Catalytic Converter monitors will not reset MissB Maintenance/Detailing 1 03-20-2013 09:24 PM
need to pass SMOG! dangski 3rd gen T4Rs 4 02-15-2012 09:42 PM
Trying to get a 85 to pass smog (large photo) RDS3030 Classic T4Rs 4 05-22-2011 12:45 AM
