Originally Posted by Kanoe
Have you checked to see if the heat valve in the coolant line is operating? Might be you knocked the end of the control cable off under the dash.
Pop the hood and make sure the valve is opening and closing as you switch from cold to heat. The valve is located under the hood on the firewall in one of the 2 coolant lines that go through the firewall. If hot coolant is indeed flowing you should be able to feel it in the lines.
Good place to start.
I'll check there in the morning thanks!
