06-12-2020, 06:39 PM
#16
Originally Posted by GGFerrier
Tell me about this A/C control upgrade I see here.
06-12-2020, 06:44 PM
#17
Originally Posted by Denis_Ruso
Just did my install. Found a great deal on Jet.com for the Pioneer SPH - DA120. They're offering 30$ off and no tax if you create an account. So I got mine for 384$ out the door and it was delivered in 3 days.
Install was very simple and seems to have pretty good functionality so far.
Where did you run the usb port for the carplay?
06-13-2020, 10:09 AM
#18
Real Name: Patrick
Real Name: Patrick
I'm assuming you are referring to the auto climate control. Factory option in Limited trims. Not easy to swap over into a manual climate control system.
08-23-2020, 12:17 PM
#19
Better late than never.
I drilled a small hole in the plastic under the ashtray area. Then popped the cable through it.
Insta: @Ruso_Denis
Build: http://www.toyota-4runner.org/3rd-ge...ld-thread.html
1997 Toyota 4Runner Limited 4WD, Rear Diff Lock, 3" Toytec Lift, Diff Drop, CBI Hybrid Front Armor, ARB Air Compressor, HID Spotlights, 32" Tires
08-23-2020, 04:48 PM
#20
Originally Posted by gshadow325
let start with
pioneer
-updates. virtually NONE compared to 2 or 3 from kenwood thruout the year
-nex units just go into boot loop
-app radio just stops reading the ipod
kenwood
-dual core linux for 2016 units
-excelon are 2 year warranty, pioneer ONE, you sol when they crash in the 13th month lol
-they got widgets for 2016
-maestro intergration is AWESOME and it works unlike pioneer
-maestro will work with my built in radar system. k40 intergration.
alpine
-not the best GIU
-not the best gui
not the best gui
i have kenwood in all my cars hehehe
This is good info to know. Just when you think that all the CarPlay head units are about the same.
12-29-2020, 01:57 PM
#21
First post to the forum!!
My son and I just finished a head unit upgrade in his 2001 SR5. Santa delivered a Sony XAV-AX3000 with Apple CarPlay and Android Auto. So far, we’re really impressed. This was a very exciting upgrade for a high school student who doesn’t own any CDs, and wouldn’t know what to do if you handed him a cassette tape.
Parts used: - Sony XAV-AX3000 (On Sale at Best Buy for $280 + tax)
- Metra 70-1761 wire harness ($4.79 from Amazon)
- Single Port 3ft USB 3.0 Male to Female AUX Car Mount Flush Cable ($9.90 from Amazon)
- Metra 40-UV43 Male to Female Motorola Antenna Cable ($5.83 on Amazon)
- Scosche MDAB 1988-Up GM Micro/Delco Antenna Adapter Tip ($6.69 on Amazon)
Installation was fairly straightforward, but it had a few challenges: - Wire harness prep… We soldered and shrink-wrapped all the wires in the harness – no crimp connectors. This took a while, but it resulted in a very solid and tidy bundle of wires. We chose to connect the parking brake wire to ground instead of wiring it to the actual E-brake handle. Normally this “feature” would prevent you from viewing pictures or videos from a USB stick unless you had the parking brake on. Grounding the wire as we did defeated this protection. It was just easier, and we didn’t think watching USB movies is something we really needed anyway.
- USB extension… The Sony manual warns against extending the USB port, but we extended it by 3 ft anyway. We wanted a clean look, so we chose to replace the cigarette lighter and keep the two lower sockets for other accessories. There were two challenges: We had difficulty getting the original cigarette socket and bulb out of the dash bezel. It just wasn’t clear how to get that thing out without completely destroying it. Eventually we got it. Second, the USB mount from Amazon was a slightly bigger than the hole through the bezel, so I had to grind down the inner circular edge with a belt sander. This was tricky, but we managed to get it to drop into the hole and mount flush against the metal bezel. We also painted the metal bezel before installing the locking nut behind it. In the end I wish we had found a USB panel mount what was small enough to fit inside the white plastic ring of the original cigarette lighter. It looks clean the way it is, but the USB port is difficult to see at night. It would have been really cool to have a lighted ring around the USB port.
- Microphone… It was difficult to decide where to put the included microphone. The microphone comes with a clip intended for a visor, or something else. We opted to clip it to the handle on the A-pillar. The mic is very sensitive. You could probably mount it *behind* the dash and it would still work. We could have tucked it away somewhere less conspicuous, but we left it on the handle for now. From the head unit the wire runs underneath the carpet behind the pedals and up to the handle.
We plan to add a backup camera at some point, so we routed additional wires from the head unit under the driver’s carpet to make them easier to tap into later: ACC Power and Ground (to power the camera), Reverse In, and Camera RCA In. Note that some people power their cameras with the reverse light circuit. However, running the ACC Power back to the camera seems like a better way to go. The Sony HU has a backup camera soft button, so you can view the camera without putting the car in reverse. You couldn’t do that if your camera was hard-wired to the reverse lights. Anyway, that’s a project for another day…
This purchase was mainly inspired by my desire for my son to keep both hands on the wheel. With Apple CarPlay it seems like you should be able to plug in your cell phone (before you start driving) and then PUT IT DOWN. There’s really no reason to mount the phone anywhere else on the dash or windshield. The other inspiration was the burned-out backlight in the original radio. At night the radio was completely dark, and I’ve read that repairing them nearly impossible.
I hope this was helpful. I spent a lot of time researching this forum prior to this purchase. I really appreciate all of helpful contributions on this thread, as well as many others.
02-04-2021, 10:49 PM
#22
Follow up...
I have discovered one glaring shortcoming on this Sony head unit. I cannot turn it off! It turns out that you can mute any given sound source, and even blank the screen, but you cannot power off the unit. Because of this, you cannot retract the antenna while the car is on. So, drive-thru car washes are off the table until I can install a kill switch.
Apparently this affects several models in the XAV series as other customers are complaining about it too:
Customer Community
Customer Community
If I had known this I probably would have passed on these Sony units. Has anyone else had to deal with this? Has anyone put a kill switch in line with the ACC wire to their radio?
Cheers,
Scott
05-23-2022, 11:43 PM
#23
Bumping an old post. I also used the same exact flush mounted USB in the cig lighter hole but it didn't provide enough data/power for Carplay to work efficiently. Did you have any issues at all with the radios performance?
05-24-2022, 10:58 PM
#24
Frankly, I don't find myself using the USB connector that often. I just can't train myself to take my phone out of my pocket and plug it in every time I jump into the car. Yet, when I do take the time to connect it, I haven't noticed any issues with Android Auto when I try. Honestly, I haven't been impressed with this Sony. I can't turn it OFF, so I can't drive through a car wash because the antenna won't go down unless I turn the ignition off. Personally, I would hold out for a model that offers all wireless Carplay/Android auto - one that will turn OFF.
Hope that helps...
Regards,
Scott
05-25-2022, 03:55 PM
#25
Hope that helps...
Regards,
Scott
Another thought - there is likely to be an antenna trigger wire on the radio. You could add an additional switch to break/connect this wire and place the switch in a free port on the dash. You'd likely always leave the antenna down but if you wanted to use the radio then click the switch.
I had to do this on an older, different car. Works well.
Jason
05-25-2022, 05:47 PM
#26
CD player
This does look really nice. My wife wants a CD player though as she has a collection of music CD's. So we have been browsing Crutchfield also. Anyone have a CD player? They have some double-dins but also some single dins that they include a little shelf with. Thinking about the Alpine but just not sure. We have the original radio. Both the CD player and the cassette stopped working years ago. Now the volume button barely works. Me, I'd be OK with just an AM radio, but my wife wants to have a CD player so, we're going to be getting a CD player.
05-25-2022, 11:12 PM
#27
Real Name: Mark KN6TZI
I got the Alpine 172BT a little over a year ago for $120 from Crutchfield because of my CD collection and I love it. Added an antenna switch after the car wash had its way with my antenna. Been washing by hand since then. Glad I bought it when I did!
'96 T4R SR5 | 4WD | Auto | 199 TBU | 268k+
05-26-2022, 04:57 AM
#28
Antenna switch
Why did you need to add an antenna switch? Does it not normally come with that? I remember replacing my antenna a few years ago.
05-26-2022, 05:00 AM
#29
What is the thing plugged in to your cigarette lighter that says 12.4?
05-26-2022, 05:21 AM
#30
Real Name: Howard J. Turkstra
I don’t see a USB port, but it looks similar to a voltage meter/USB port combo that I have.
2004 Limited V8 4WD 183k miles. Stratosphere Mica paint, Stone interior. Too many mods to list here.
