Old 05-05-2016, 10:43 AM #1
Bt08231 Bt08231 is offline
Bt08231 is on a distinguished road
Intermittent starting
So my 98 will start sometimes and then sometimes it will just click. Battery tested good, alternator tested good. We found a 75% broken ground at the battery and knew that probably had something to do with it. Had that fixed and it started fine when I picked it up, drove 20 miles and now it's just clicking again. Starter was rebuilt professionally with Toyota parts 2 years ago as well.
Where do I look next??
Bt08231 is offline   Reply With QuoteReply With Quote
Old 05-05-2016, 10:45 AM #2
tim_z tim_z is offline
tim_z is on a distinguished road
Perhaps pull the starter and see what the contacts look like. Unlikely that they have worn out in only two years but a good place to start
tim_z is offline   Reply With QuoteReply With Quote
Old 05-05-2016, 10:46 AM #3
GHARP57's Avatar
GHARP57 GHARP57 is offline
Real Name: Greg
GHARP57 is on a distinguished road
GHARP57's Avatar
Real Name: Greg
Battery can test good even if it is bad, we have that happen in the shop from time to time. Starter rebuilt. Does that mean they just put starter contacts on it? I almost bet that that is the under lying cause if they rebuilt it by putting brushes and the other guts in it then you shouldnt have an issue but the labor they would have charged would have almost made it cheaper to put the reman toyota in it. Next time it doesn't start tap your starter with a hammer and see if it starts up right after you do it.
99 Runner-TBU, 265/75/16 Nitto Terragrapplers, Limited running boards taken off. sold
been out the game for a couple years now, i miss my 4runner
GHARP57 is offline   Reply With QuoteReply With Quote
Old 05-05-2016, 10:58 AM #4
I was going to rebuild it myself so I bought all the parts from Toyota to do it and didn't have time to screw with it, so a shop did it. I can't remember exactly what I bought but it was everything that all the threads talk about getting to rebuild it.
Old 05-05-2016, 10:59 AM #5
I've had The truck for 3 years and it's the same battery that came with it....
Old 05-05-2016, 11:04 AM #6
GHARP57's Avatar
Real Name: Greg
GHARP57's Avatar
Real Name: Greg
Usually most people replace just the starter contacts. Fewer people replace brushes and internal parts on it.
The battery can easily be 3+ years old unless the P.O. showed a receipt where it was just bought. We have batteries go bad all the time that are a year or 2 old
Old 05-05-2016, 11:24 AM #7
WarpzoneQc WarpzoneQc is offline
WarpzoneQc is on a distinguished road
I had the same problem. Battery starter and alternator good. Had a broken ground. Fixed it. Then after 1 or 2 week it came back. The new ground wasnt tight enough. Take out the terminals on battery clean everything with proper tool. Like 5 bucks. Put back everytjing and make sure it is tight. Good tight. But not over torqued baboon tight.
WarpzoneQc is offline   Reply With QuoteReply With Quote
Old 05-05-2016, 11:26 AM #8
JayRolla's Avatar
JayRolla JayRolla is offline
JayRolla will become famous soon enough JayRolla will become famous soon enough
JayRolla's Avatar
What is the voltage at the battery just sitting off? What is the voltage dropping to when trying to crank?
JayRolla is offline   Reply With QuoteReply With Quote
Old 05-05-2016, 11:41 AM #9
Everything is nice and tight. It tested 12 Volts yesterday, not sure while cranking...
Old 05-05-2016, 12:40 PM #10
jeremyc74 jeremyc74 is offline
Banned
jeremyc74 is on a distinguished road
Banned
Are the lights going dim when you're trying to crank it?
If they're not dimming at all it's probably the starter contacts. If they're getting really dim it's probably something else. The later would indicate that the starter contacts are pulling in, but there's not enough voltage to turn the engine over. That could be anything from a bad ground connection to a bad battery.
jeremyc74 is offline   Reply With QuoteReply With Quote
Old 05-05-2016, 04:17 PM #11
Ok guys, just went out there I crank it and it started immediately...twice, on third try it clicked and the dome light went completely dim almost as if it was off. Turned the key again, it clicked really fast for a few seconds and as I let of the key the motor started to turn over ever so slightly, on the third try it clicked a few more times and started
Old 05-05-2016, 04:20 PM #12
Seems like a weak battery.... Don't really want to throw money at that if there's other things I can check
Old 05-05-2016, 09:59 PM #13
mtbtim's Avatar
mtbtim mtbtim is offline
Real Name: Tim
mtbtim's Avatar
Real Name: Tim
In case you decide to pull the starter and check the contacts, here's a video I made recently when I found my starter wouldn't disengage. I started my truck and the starter kept going. I turned the ignition off and it still kept going. Lucky I was home and I jammed into the garage, grabbed a pair of channel locks and twisted the negative cable off the battery to stop it. Replacing the contacts and plunger fixed the problem.
I did have a couple occasions over the past 6 months where my truck wouldn't start, but I thought maybe the gear selector wasn't all the way in park and that caused it. I never got the usual tell-tale clicking letting me the know the starter was going out. And, I never knew a starter could engage and not disengage. I'm never going to be without a pair of channel locks in my truck now that I know that could happen. Lots of nevers in that paragraph.
Here's the video:
Old 05-05-2016, 10:10 PM #14
ThorInc ThorInc is offline
ThorInc is on a distinguished road
Worth every penny. I bought this to check the batteries for my bass rig.
1997 T4R SR5 3.4L 5 speed with factory e-locker bought new with almost 1km on it
ThorInc is offline   Reply With QuoteReply With Quote
Old 05-05-2016, 10:18 PM #15
mtbtim's Avatar
Real Name: Tim
mtbtim's Avatar
Real Name: Tim
I forgot to mention O'Reilly Auto Parts will test your battery for free. I had a 72 month battery I bought from the dealer and it died in 2 years. O'Reilly will go right out into the parking lot and do a test of your battery and charging system. No need to pull the battery out.
I was technically over the time period that the dealer would replace it for free but the parts person I dealt with was very cool and let it slide. I was only over by 2 weeks for the warranty so it was the right thing to do anyway.
Intermittent starting problem BigNate 3rd gen T4Rs 18 12-16-2023 12:40 PM
Please help! Intermittent buzzing after starting. Jeradise 4th Gen T4Rs 3 08-21-2015 11:01 PM
Intermittent starting mndanielsncsu 4th Gen T4Rs 8 02-12-2014 08:36 AM
intermittent Starting Issues Brilliant 3rd gen T4Rs 4 01-11-2013 02:41 AM
intermittent starting problem splatt Classic T4Rs 4 04-16-2006 03:26 PM
