Originally Posted by Tucson4runner
You should be good with the factory hole on the driver's side. I've got roughly the same setup you plan on doing. At this point though the grommet is a pain to get anymore wires through. I'll need to remove it completely if I plan to run more... Which I do. I'll take a picture later today.
Sent from my SM-N910V using Tapatalk
Yea please do.
My set will be :
4gauge amp wire
4gauge aux fuse box going to the back seat
10 , 12 gauge wire coming back from fuse box for accessories
About 4-7 14 gauge none relay fused wires.
And possibly few little extra wires.
How do you guys run the wires inside the truck ? How many can you fit under the driver pillars ? Or is it good to run it under the carpet around the contours ? I have the whole interior and carpet out. So it doesn't get easier.
I need to run 3 seperate RCA cables from rear passenger area to the head unit, a 9-wire from that location to the head unit. And the 4 gauge power wire. Which I wanna run away from all those so I don't have alternator whine.
And the aux fuse box will be installed in where the stock jack goes. It's bussmann 10 relay fuse box.
