Today I was able to do a 1.5" body lift. I am not going to lie, It took a lot out of me. Only because I hit some bumps along the way. That rag joint is a PITA!! But it's done and seems like it's ok.
The only thing that I don't care is that the steering is stiff. The spacer is there. It doesn't want to return to center after a turn. Do you guys/gals think the slip yoke(bolt above the rag joint) needs to be adjusted??
Fat Pats kit:
Also need a bracket to get the bumper back to norm. I will get that little later.
I am pretty tired but I hung in!!
1998 T4R SR5 V6 2wd Evergreen Pearl OME 880 Toytec 1/4" spacer OME 906w/OME20mm(10mmx2)spacers Bilstein 5100 BFG KO2 31's Satoshi mod 1.5" BL(Fat Pats)
My 4Runner build:
http://www.toyota-4runner.org/3rd-ge...8-sr5-2wd.html
