Old 05-25-2016, 08:02 AM #1
oncewaspfd oncewaspfd is offline
oncewaspfd is on a distinguished road
Code P0442 showed up
Finally got the code number of P0442. It lists the following possibilities - defective fuel cap, EVAP cannister, purge or vent solenoid defective, vacuum leak at engine.
Any ideas which one? What do I look at first? I have an 02 limited. Will it hurt the vehicle if I continue driving it?
oncewaspfd is offline   Reply With QuoteReply With Quote
Old 05-25-2016, 08:25 AM #2
Hesk11dog's Avatar
Hesk11dog Hesk11dog is offline
Hesk11dog is on a distinguished road
Hesk11dog's Avatar
from the FSM as you stated some of the possible causes. I have the same code, could be a long list of things. Will not hurt the vehicle. could lose fuel mileage and be rough running.
Code P0442 showed up-p0442-png
MINE - 97' SR5 manual (Desert Dune Metallic)
HER's - 14' limited (Altitude Black)
Hesk11dog is offline   Reply With QuoteReply With Quote
Old 05-25-2016, 08:33 AM #3
HiLife HiLife is offline
Originally Posted by oncewaspfd View Post
What do I look at first? Will it hurt the vehicle if I continue driving it?
I would reseat your gas cap first.
No it won't hurt if you continue driving with this check engine code short term.
Old 05-25-2016, 08:45 AM #4
jgue467's Avatar
jgue467 jgue467 is offline
jgue467's Avatar
Finally got the code number of P0442. ...
If reset how long before the cel shows up again (miles/time)?
Once every few months mine will get a 440 but only when wheeling offroad slow and vehicle rocking back/forth on rocks/ruts/holes. Reset and won't come back for months. Despite that all works as it should. Hmmm.
Old 05-25-2016, 09:01 AM #5
TXLX1's Avatar
TXLX1 TXLX1 is offline
TXLX1 is on a distinguished road
TXLX1's Avatar
If the 442 is the small leak code, it could be a loose or bad gas cap. Absent that, visually inspect all the evap lines under the hood and around the canister on the driver side.
-2005 4Runner Limited V8 AWD - Toytec Boss Suspension, SPC UCAs, 285/70/17 Level 8 MK Wheels (17x8, -10), Tandem Rock Sliders
-1998 LX470 (Stock)
www.KeenanOffroadFab.com
TXLX1 is offline   Reply With QuoteReply With Quote
Old 05-25-2016, 09:12 AM #6
MStudt's Avatar
MStudt MStudt is offline
official vendor
MStudt is a name known to all MStudt is a name known to all MStudt is a name known to all MStudt is a name known to all MStudt is a name known to all MStudt is a name known to all
official vendor
MStudt's Avatar
Start with the gas cap, and get an OEM. I had the same thing happen about 1 month after purchasing my 4runner. I replaced it with one from Autozone, and it only lasted about a year. Put an OEM on over a year ago, and no issues since.
MStudt is offline   Reply With QuoteReply With Quote
Old 05-25-2016, 11:11 AM #7
I'll start with the gas cap. I checked it this morning and the fuel tank was pressurized. First time for this. Does it mean something?
Old 05-25-2016, 10:07 PM #8
stir_fry_boy's Avatar
stir_fry_boy stir_fry_boy is offline
stir_fry_boy is an unknown quantity at this point
Nope. Doesn't mean the Evap system is not leaking. The charcoal canister can be leaking inside itself and throw the code.
2015 T4R TRD Pro in super white, Morimoto 4300K HID kit, Auer Engineering / Toyota LED DRL/Fogs 2-in-1's, TRD drop in air filter, WeatherTech front and back liners.
2002 T4R SR5 4WD Onyx Black Sport Edition w/Leather. Gone but not forgotten.
stir_fry_boy is offline   Reply With QuoteReply With Quote
Old 05-26-2016, 01:50 AM #9
StreetCreeper's Avatar
StreetCreeper StreetCreeper is offline
Real Name: Woody
StreetCreeper will become famous soon enough StreetCreeper will become famous soon enough
Real Name: Woody
As others have stated, there is a list of things that could be your cause. In my case it was a hairline crack in the EVAP canister. I fixed it by pulling it out and using some RTV around the bottom.
Might not be your issue, but it if is, you might be able to make a cheap repair instead of replacement if your trouble shooting gets you to the EVAP canister.
And fixed...
"Variety is for your mind, not your body " —OS
StreetCreeper is offline   Reply With QuoteReply With Quote
Old 05-26-2016, 03:31 PM #10
Thanks everyone. I found a Jack in the seal for the gas cap. Ordered it from the dealership and will install tomorrow. I disconnect the battery and hope for the best.
Old 05-27-2016, 10:25 AM #11
Got my new gas cap from the dealership today. Found out I was missing the rubber O Ring. Hope this solves the problem.
Old 06-06-2020, 02:52 AM #12
t4rain t4rain is offline
t4rain is on a distinguished road
My P0442 popped up in January with 218k miles at sea level, i replaced the gas cap with an OEM one, came back again in March with 220.6k miles at 6,000 feet altitude (i cleared it without doing anything - hoping it was altitude related) then it just popped up again with 222.1k miles tonight again at sea level. I guess I'll look into the charcoal canister and troubleshoot as this guy suggests on youtube? YouTube
Sounds like that small crack on the bottom is common and RTV is a strong enough fix vs buying a new part?
2002 4runner SR5 Sport 2wd Black
t4rain is offline   Reply With QuoteReply With Quote
Old 06-06-2020, 05:44 PM #13
twitchee2's Avatar
twitchee2 twitchee2 is offline
twitchee2 is on a distinguished road
twitchee2's Avatar
Its the check valve on top of the tank. The gasket fails and the top of the valve develops a hair line crack. I just did this last week.
Video: YouTube
Parts needed:
New Genuine Toyota 4Runner Fuel Tank Valve Assembly OE 7739035010 | eBay
Toyota OEM Fuel System Check Valve Gasket 77177-33010 Factory Sold Individually | eBay
You have to drop the tank
2002 SR5 4WD
deckplate + ISR, Airlift 1000, OME 881/890, Goodyear Wrangler Duratrac 265/75/16C
Tundra 231mm Brakes - yes they DO fit the stock 5 spoke rims - Stubbs Welding HD-SKO sliders.
twitchee2 is offline   Reply With QuoteReply With Quote
Old 06-07-2020, 10:55 PM #14
Yikes, hopefully mine is just the canister! I don't have that kind of tool inventory so mine will go to the shop if i need to drop the tank or do anything that involved
Video: YouTube
Parts needed:
Old 06-08-2020, 11:22 AM #15
twitchee2's Avatar
twitchee2's Avatar
All you need a jack, 14mm, 12mm, extension, pilers screw, drivers and some patience. Its actually not that hard of a job. just kind of tedious and make sure you have the tank nearly empty.
2002 SR5 4WD
Help/Advice on Diagnosing Error Code P0442 BigRogers 3rd gen T4Rs 7 09-19-2015 03:54 PM
Code 21 showed up - O2? PabloRunner Classic T4Rs 2 07-02-2015 01:42 PM
look what showed up in the mail! kolelt 3rd gen T4Rs 7 11-22-2014 05:32 PM
Look what just showed up! :) 3rzrunner 3rd gen T4Rs 10 06-05-2014 09:04 PM
01 with P0442 evap code 01thunder 3rd gen T4Rs 1 09-05-2013 11:11 AM
