So I did some investigating today as I plan on doing it this weekend and wanted to see what I'm working with and if I need to hit the store ahead of time.
I looked under the steering column, and didn't see any loose connectors. Everything plugged in. I saw on someone's pre-wired toyota instructions that I am supposed to splice into two of these cables, however it is tight, not sure I could get in there.
On the other hand, near the clutch start button, there are two floating connectors. One of which has 4 cables going into it.
The black and white connector is the one with 4 cables going into it. There is a blue with white strip, white with green strip, and a white and green.
Is this connector the pre-wired fog lights? If so, how should I connect those four wires? I do have a switch with four wires, however not sure what would go with what.
Or, am I fishing in the wrong hole and need to go back to the steering column where my light stalk is and figure out which of those wires I need to splice into?
Thanks in advance.
www.drinklowbrau.com - Beer, hiking, Rig Building, offroad, outdoors,
http://www.amsoil.com/?zo=5367568&zo=5367568 - Amsoil Dealer
www.sorrelldesign.com - Design Firm
