Bumping an older thread, but I never got around to my valve cover gaskets yet, probably wait until the upcoming summer when it warms up a bit first.
Anyways, I found this site and noticed an interesting (simple) alternative to using the special valve shim tool. What do you guys think?
MR2 Adjusting Valve Clearance
"The shims can be removed without using Toyota's SST (special service tool). I used an Allen wrench and a screwdriver. It is a good idea to put tape around the screwdriver tip so as to avoid scratches. The Allen wrench can be used to push the valve down - then the screw driver is placed between the camshaft and the lip on the bucket to keep the valve spring compressed. The shim can then be removed using a magnet finger and where necessary pushing it a little with another smaller screwdriver."
