06-08-2016, 11:16 PM
Power steering leak, hose at rack
I had a small power steering leak develop around the high pressure input line at the rack. My mechanic buddy tightened up the line about a quarter turn and now I have a significant leak. He thinks the o-ring on the fitting may have torn.
Has anyone seen this before? Is it a matter of just replacing an o-ring? Thanks!
-2005 4Runner Limited V8 AWD - Toytec Boss Suspension, SPC UCAs, 285/70/17 Level 8 MK Wheels (17x8, -10), Tandem Rock Sliders
-1998 LX470 (Stock)
www.KeenanOffroadFab.com
06-09-2016, 12:26 AM
Sounds like its time for new hoses. The fittings that connect the power steering hoses into the rack are flare fittings. No o rings. The flare may have possibly cracked when tightened, resulting in a larger leak. I just replaced my rack and pinion and installed new hoses due to them being rusted in place. The Toyota hoses are expensive but come as a set and fit like a glove! Totally worth the cost in my opinion.
2002 4Runner,Tundra billies with toytec/eibach coils. LC 8 wraps. Savage front and rear bumpers, 265 75 16 BFG All Terrain KO2, LC wheels. SPC upper control arms
06-09-2016, 12:46 AM
How much did you spend?
Sent from my SM-N910V using Tapatalk
work in progress
06-09-2016, 12:55 AM
Aftermarket high pressure line is $100-200, so I would guess toyota is $400+. I'll be sure to post again with the resolution. Thanks for the info.
Update: high pressure line is about $225 online for toyota
-1998 LX470 (Stock)
06-09-2016, 01:17 AM
Wow, there must be a huge difference between a 97 and 2002. I just looked at camelback toyota and a hose set for a 1997 4runner part #4441035400 is over 400.00! The hose set for my 2002 was 273.04.
06-09-2016, 01:22 AM
For my 2002 SR5
High pressure/low pressure hose assembly #4441035570= 273.04
Return line tube/flare connection #44416-04020= 15.02
Free shipping and a 5% Tacoma World discount code also. This was for a 2002.
I also replaced the rack and pinion with a costly Toyota rack, and installed some new lower control arm bushings from Toyota. About a year ago i installed a set of moog LCA bushings and they failed with just daily driving to and from work, pretty disappointing in my eyes. Now though the 4runner rides real nice.
Real Name: Woody
Real Name: Woody
Wtf!? $400 buys a lot of ATF...
"Variety is for your mind, not your body " —OS
06-09-2016, 01:29 AM
For real! I love Toyota parts, especially something like a power-steering hose set that has rubber hose plus steel lines, so the bends and fit are crucial for easier fit and install, but damn $400+ is crazy, i felt like i took a hard hit at 273.00 for a couple hoses but at that price i might consider a good aftermarket brand.
06-09-2016, 08:14 AM
If it needs a HP line for $225 or $275 I'll probably end up buying toyota part. It's got an aftermarket rack in it (previous owner) and not sure how long all that aftermarket stuff will last.... I could be back in the same situation soon and out even more money.
-1998 LX470 (Stock)
06-09-2016, 09:14 AM
It's rare for the fitting to fail. Hit up a member parting out. Got mine hp hose for $75 on this forum.
06-09-2016, 09:37 AM
I'll look into that, thank you. What happened to your HP hose that it needed replacement?
-1998 LX470 (Stock)
06-09-2016, 10:32 AM
Told buddy to cut the hose thinking it was the low pressure. My bad!!
06-09-2016, 10:36 AM
Looks like this is one of the problems I am having as well. Looking through old threads and trying to find a decent r&p to replace it with. Reman doesn't seem good so probably ac delco with oem lines.
work in progress
06-09-2016, 10:46 AM
I'm not going to say the aftermarket rack is my problem yet. However, I'm not sure why the high pressure line would all of a sudden start leaking at the fitting.
The BBB racks on rockauto have 3 year 36k mile warranty and seem cheap with a core (but the hassle of swapping and aligning exists if it fails quick).
-1998 LX470 (Stock)
06-09-2016, 11:10 AM
Being over tq can cause it. Mine has loosened up and I lost all fluid once. Have not had an issue since last time I tightened them down.
