06-11-2016, 09:22 AM
Today is the day finally!
I finally Get to put my engine in i have been waiting months to do. ( way to much side work to finish my own projects).I will post more pics to the thread I figure the next few days will be a lot of posting. I am pulling the engine by myself so no video's. But i will try to take lots images of the resealed motor and progress!
1998 Desert Dune Limited 4runner, E-locker, 4wd
TBU 2015 SR5 17INCH Wheels. Nittos Terra grapplers g2 265/65/R17
Pioneer double din DVD player, single alpine 12 sub.
2014 Ford Focus TI Was daily Driver Sold
06-11-2016, 09:26 AM
Real Name: Sarah Lord
Good luck! Hope it goes smoothly!
It's a Toyota. If I wanted a Hummer I'd call your sister.
2010 Toyota Tundra, 2008 Toyota Sequoia, 2003 Toyota 4Runner "MUDLORD" 1998 Toyota Tacoma, 1996 Toyota 4Runner "MAJOR DYSFUNCTION"
06-11-2016, 04:45 PM
It's so hot!
So today went slower than I wanted to. I only was able to install oil pump rear Main oil seal and clean up the oil pan. I will be bolting then heads on early in the morning before the heat of the day sets in. Tomorrow is calling for 95 I wanna cry. Why did I choose the 2 warmest days to do this.
06-12-2016, 12:08 AM
Don't tight the tensioner bolts, otherwise you won't be able to pull the pin out. I learned it the hard way. Had to remove the AC compressor and bracket once again to loosen the sensioner bolt to pull that pin!
06-12-2016, 06:45 AM
I have never had an issue with pulling the pin once torqued to spec. That is kinda how they are supposed to be set up. 13 ft-lbs with the dust boot set in the correct non pinched groove( ask me how i know ) the pin does move like it should I had to go check once torqued down.
06-12-2016, 06:50 AM
I am so lucky I work on cars for a profession! If not I would be lost since I took this engine apart months ago and bolts are everywhere! New valve cover gasket with Spark plug seals and bolt washers.
06-12-2016, 12:06 PM
New Felpro MLS headgaskets. It is so hot its not funny.
06-12-2016, 04:07 PM
And here is more!
06-12-2016, 05:35 PM
"So fresh and so clean, clean..."
2022 Toyota 4Runner Limited 4x4, Blizzard Pearl, "Farrah"
1984 AMC Jeep Grand Wagoneer 4x4, Chestnut Brown, "Geena"
2017 Toyota Land Cruiser 4x4, Attitude Black, "Lou" [Sold]
2020 Toyota Tacoma Limited 4x4, Quicksand, "Tess" [Sold]
2002 Toyota 4Runner Limited 4x4, Dorado Gold, "Faith" [Sold]
06-13-2016, 12:25 PM
Coming out with the old!
06-13-2016, 03:15 PM
congrats!
06-13-2016, 05:51 PM
Oh the pain staking process of swapping the good for the bad.
Side note perfect time to replace my work steering rack bushings. Lol
06-14-2016, 06:58 AM
lol Hot is what I was hollering Saturday when setting up an ring and pinion in a ford 8.8, i feel ya brother lol
06-14-2016, 10:11 PM
06-14-2016, 10:18 PM
I wanted to say thanks to all the forum guys and for the likes and comment's. Also i found that Lisle makes a socket that allows you to break the crank bolt loose with a regular air impact or battery operated 1/2. I used my dewalt 2 times to remove the pulley bolt no problems either time. Lisle 77080 19 mm Harmonic Balancer Socket. It does work and for 23 dollars on amazon is worth it.
