Originally Posted by jreask
Should it turn freely or not? I could feel a little resistance when I tried to spin it. Thanks for your help.
there should be a bit of resistance. but, unless you are able to spin it several 1000 rpms, that's not going to tell you much.
take it off, then do a quick test drive. you will find out right away. you can go several minutes without fear of overheating, assuming you are starting with a cold engine.
1985 pickup
: EFI 331/4r70W-Dana 300-42 TSL SXII's/raceline beadlocks-30spl longs-5.29's-spools-sky Hi steer-OBA/4g tank-10.5k RR winch-dual blue tops-200 amp alt-flatbed.
1985 4runner sr5
: 22RE/5spd-6" pro-comp suspension-37 BFG at's-5.29 gears-Badlands Basher bumper-8.5k RR winch.
2006 4runner v8 limited
: stock.
Build Thread YouTube Channel
