Old 06-26-2016, 08:13 PM #1
mckennar's Avatar
mckennar mckennar is offline
mckennar is on a distinguished road
mckennar's Avatar
98 4x4 bent frame sanity check.
As the title says, I have a '98 4Runner that my drunk brother in law ran into a ditch at ~35. Bags blew but radiator and condenser are still intact. Driver's UCA impacted wheel well, wheel arch crumpled slightly internally (see pic).
Driver's side wheel pushed about 3/4" aft (replaced UCA/LCA/knuckle, no change), driver's frame horn about 1" up (vs. passenger frame horn), all body-to-frame bolts bent, core support bent but not terminally.
Visually, I can't find where on the frame it's bent. There isn't any paint flaking or visible bends or rips in the metal of the frame. So I stuck jack stands under driver/passenger front seats (ok not directly, but right where the frame flattens out under the firewall) to do the above measurements. Rest of truck is level when the front is on jack stands, so that tells me the tweak is fore of the firewall.
All doors open and close fine, shut lines are fine, even fenders are fine (removed d-side for pics). Hood closes straight (it's popped in the pics). You can definitely tell it's swayed from the front-on shot, though.
Anyway, the thing runs and drives so I drove it onto a trailer and took it to a frame shop about a mile away. After much gnashing of teeth, they said "not enough money in the world" to make the car safe for the road again.
Is that even a thing? Far be it from me, some amateur hack, to second guess a dude with a laser frame machine and 30 years of experience, but I have a hard time believing the frame can't be pulled. Anyone have any thoughts?
Oh and no insurance payout on this because all I had was liability on the truck. Brother in law is now deployed (wreck happened last August), he has more pressing issues to worry about.
98 4x4 bent frame sanity check.-20160626_183711-jpg  98 4x4 bent frame sanity check.-20160626_183724-jpg
mckennar is offline   Reply With QuoteReply With Quote
Old 06-26-2016, 08:19 PM #2
IsaiahC's Avatar
IsaiahC IsaiahC is offline
IsaiahC is on a distinguished road
IsaiahC's Avatar
The crossmember is way bent up which means the whole end of the frame is squished. You could do a frame swap but it sounds as though your body mounts are trashed too. Might just have to part it out or scrap it. Your brother-in-law is responsible to pay damages but if he isn't willing to pay and you're not willing to go after him for it, then you're SOL
Source: Took a couple law classes in college
'96 4runner Limited - Automatic 4wd with factory E-locker - LT265/75r16 BF Goodrich KO2's - Toytech/Eibach front coils and LC 8 wraps with Bilstein 5100s all around - SPC UCAs - AOR Plate Front Bumper - 4xinnovations Rear Swingout Bumper - HD-SKO Sliders
IsaiahC is offline   Reply With QuoteReply With Quote
Old 06-26-2016, 08:45 PM #3
mckennar's Avatar
mckennar's Avatar
That crossmember was bent due to the force of the impact. Here's another picture.
Perhaps that "pinched" the frame horns together. Body shop didn't mention it (disclosure: they didn't mention *anything* except that 'it's too far off to fix')
Ref: the brother in law - once he's done not being in Syria (and definitely not in Iraq, either), I'll let him know he *is* on the hook for wrecking my used car. lol.
Until then, just wanted a sanity check that a frame can be "too bent" to be fixed.
EDIT: both drivers side tires are flat in this picture.
98 4x4 bent frame sanity check.-20150901_181248-jpg
'16 4Runner Trail 4x4 stock.
'98 4Runner Limited 4x4 not stock.
Old 06-26-2016, 08:59 PM #4
Cree's Avatar
Cree Cree is offline
Cree will become famous soon enough Cree will become famous soon enough
Cree's Avatar
Anything can be pulled straight. How much you wanna spend? Get a second opinion. Probably gonna be more than a new 4Runner would cost you though. You could always find one with a dead drive train and do a swap.
00 Limited - Stuff!
18 Audi A6 3.0T - APR Tuned, RS6 Interior
19 Audi A6 3.0T
Cree is offline   Reply With QuoteReply With Quote
Old 06-26-2016, 09:06 PM #5
mckennar's Avatar
mckennar's Avatar
I've been looking for a dead-drivetrain, rust free 4x4 3rd gen since August of last year when this wreck happened. I literally gave up after this thing sat in my yard for 9 months and hauled it to a body shop because I haven't had any luck. I figured anything less than $6k of frame work I'd be breaking even, as that's what running 4x4 3rd gens are going for around here.
You're quasi-local (Kansas). How's the rust situation up there? It seems like any trucks I look at north of the Arkansas/Missouri state line are rust buckets at 150k miles.
Old 06-26-2016, 11:39 PM #6
seank seank is offline
Real Name: SeanK
seank is on a distinguished road
Real Name: SeanK
I don't know what you like to do with your truck, so this may not appeal to you, but...
A lot of people who Solid Axle Swap their 3rd gen t4r or first gen Tacoma simply hack the front of the frame off from about the firewall and fab up a new and stronger front. It saves a lot of time and provides better clearance.
I'm guessing this is not something you are interested in doing, but maybe you could find someone who is and make a deal that would net you more than a wrecking yard.
What ever you do, good luck!
Sent from my Nexus 9 using Tapatalk
The Grocery Getter Project
1996 SR5, 3" Bilstein/OME lift, 4.88 gears, rear ARB locker, 35"s
seank is offline   Reply With QuoteReply With Quote
Old 06-27-2016, 12:19 AM #7
IBallEngineer's Avatar
IBallEngineer IBallEngineer is offline
IBallEngineer will become famous soon enough IBallEngineer will become famous soon enough
I have some thoughts, but I know it won't be what others want to hear. I only have a 35 year history in the body shop industry, 14 years as a shop owner, so I'm not an expert.
I'd totally fix that!
If I still owned my shop and you brought that to me to pull, it wouldn't be end of the world expensive, but it wouldn't be cheap.
2 hours of set up at frame labor rate. Was $55 when I sold my shop 3 years ago.
2 hours for sway
2 hours for twist
3 hours at Body labor rate to replace that cross member, plus parts.
1 hour for clean up and painting.
5 or 6 hundred dollars. Now the core support is looking rough too, that is another story, and more money.
Of course I don't know if it has mash or buckle, your pictures don't show that.
1989 FJ62 5.3 Chevy, FZJ80 Axles, 4.88's with ARB.
2000 2wd runner, 4 cylinders, yes it IS slow.
1999 4WD SR5 Desert Dune 3.4 351K and counting.
2000 4WD sport 3.4 Elocker <--My son's but I still end up paying.
2001 2WD SR5 3.4 <-- My daughter's...see preceding line.
IBallEngineer is offline   Reply With QuoteReply With Quote
Old 06-27-2016, 12:54 AM #8
T4R2014's Avatar
T4R2014 T4R2014 is offline
T4R2014 is a splendid one to behold T4R2014 is a splendid one to behold T4R2014 is a splendid one to behold T4R2014 is a splendid one to behold T4R2014 is a splendid one to behold T4R2014 is a splendid one to behold
T4R2014's Avatar
Lmao. Make the a-hole brother in law pay for what he effed up, whether it has to be a full front-end rebuild or the full value of an equivalent truck.
Old 06-27-2016, 07:17 AM #9
mckennar's Avatar
mckennar's Avatar
Thanks for the insight. People here are avoiding it like the plague for some reason.
Question for IBallEngineer- knowing what you know say you pulled it, and it was again involved in a wreck, would it be as safe as before it was originally tweaked? The shops around here keep throwing "safety" around and refuse to touch the truck.
Old 06-27-2016, 09:02 AM #10
jeremyc74 jeremyc74 is offline
Banned
jeremyc74 is on a distinguished road
Banned
It's impossible to offer a solid opinion on frame damage from a couple of pictures on the internet. The shops who have seen it in person don't want to touch it because it's more trouble than it's worth. They know there's a good chance it's going to have issues down the road no matter how much they try to make it right, and they don't want you coming back to them in a year saying it's wearing tires funny, or pulling. It's just not worth the hassle for them.
You may find someone who's having a slow week that will take it on, but it'll likely never be right. As much as you don't want to hear it, that truck is totaled. I'd part it out and cut my losses.
jeremyc74 is offline   Reply With QuoteReply With Quote
Old 06-27-2016, 09:12 AM #11
Again, based on what I see in the pictures, there is no safety issue. The cross member should be replaced. Can any of these shops be specific about the issue or are they acting like you couldn't understand? I will emphasize to you, that the pictures don't show much, can you show the area right behind the control arms? That is an inherent week spot on all frames of this style. And if you have severe mash or buckle in this area it can be hard to repair.
Also, I only have my entire life in the industry and have repaired or been involved in repairs of FAR WORSE than what I see in your pictures. I never had a problem with tires wearing funny or pulling. Anyone who does simply does NOT know what they are doing.
How far are you from Conway?
Old 06-27-2016, 09:17 AM #12
Banned
Banned
So in your expert opinion, these shops just don't want to make money?
Old 06-27-2016, 09:21 AM #13
Two things about what you are saying here. When you say ALL body to frame bolts are bent do you mean ALL of them? If so the problem is or could be much worse than it looks. Also when you measure forward and back, compare to the other side and you can isolate the damaged area pretty easily. Also measure in an X pattern at different points, this will tell you have much sway there is.
I've never subscribed to the "never be the same again" BS. No you will no longer have the original finish and parts. But that doesn't mean it can't be repaired.
Old 06-27-2016, 09:25 AM #14
MAD 69's Avatar
MAD 69 MAD 69 is offline
MAD 69 is on a distinguished road
MAD 69's Avatar
Salvage what you can from this wreck and buy another one - make your brother in law pay - just because he is in the military he gets a pass?! Not in my book, I would have him send you money every week he gets paid - military people are still getting paid correct?
98 T4R SR5 V6 4x4
23 T4R TRD OR Premium
MAD 69 is offline   Reply With QuoteReply With Quote
Old 06-27-2016, 09:29 AM #15
Very little money to be made on a $600 frame repair. Most busy DRP shops won't touch little jobs like that because in the same footprint they can do a $2000 insurance job.
I am going against my own advice responding to your post, but I will leave it at that. I'll address the questions of the OP, not going to get in to another pissing contest with you. I already know you are an electrical engineer. If you don't agree with me, I'm ok with that. As I stated in my first response, I'm not an expert.
Need a sanity check hikenbike 5th gen T4Rs 41 02-06-2016 05:15 PM
I need a sanity check: alignment joneseyyy 5th gen T4Rs 15 07-14-2015 07:59 AM
Sanity check before I buy a new compressor Canon_Bob 5th gen T4Rs 21 01-15-2015 04:52 PM
Sanity check here eds72 4th Gen T4Rs 13 06-14-2012 11:17 AM
Sanity check my choices... Vizwar Off-Roading 3 03-06-2009 03:12 PM
