Old 12-13-2019, 06:00 PM #46
sleepydad's Avatar
Real Name: Andy ಠ_ಠ
sleepydad's Avatar
Real Name: Andy ಠ_ಠ
why has this build not been continued?
this build needs to be continued
Old 02-08-2020, 11:46 PM #47
Spunk Spunk is offline
Real Name: Nate
Spunk will become famous soon enough
Real Name: Nate
It's being continued. Had to work through some deep details.
Here's the photos from fitup today.
A Pillars and B Pillars tacked together.
Made a offset mount for the dashbard's cross bar, so the front cross bar can fit.
Image of mount.
Current photo as of this afternoon.
long travel F/R, major fabrication work, shrockworks armor, whitsonmetalworks, dual-rate coilovers F/R, warn, rigid, ARB, more buttons than brains.
Spunk is offline   Reply With QuoteReply With Quote
Old 02-17-2020, 03:02 PM #48
Real Name: Nate
Real Name: Nate
Since there's a cross bar in the front, now the gauge cluster needs a new home.
It's all really rough at this point, but I trimmed the black molding of the cluster, and glued on a plexiglass sheet. That way, it sits in a smaller footprint. Now onto mounts. I changed out burnt out bulbs with LED's in the meantime.
Old 02-17-2020, 05:12 PM #49
dcshipwreck dcshipwreck is offline
Real Name: Dan
dcshipwreck is on a distinguished road
Real Name: Dan
google photos don't show on the forum, you have to use imgur or another host, your build is epic btw
dcshipwreck is offline   Reply With QuoteReply With Quote
Old 02-18-2020, 02:03 AM #50
Real Name: Nate
Real Name: Nate
Fixed, and thanks!!!
Old 02-19-2020, 11:59 PM #51
Real Name: Nate
Real Name: Nate
Gauge Cluster Mount. I decided to make it bolt on so I could adjust it's position.
Old 02-22-2020, 01:12 AM #52
Real Name: Nate
Real Name: Nate
Tube #8 is in position.
Over the windshield
View From the rear
Joint of #1 and #2 tubing with tubing cap and crossbar.
Old 02-23-2020, 03:11 AM #53
Real Name: Nate
Real Name: Nate
A, B, and C Pillars welded together.
Old 03-03-2020, 09:49 PM #54
Real Name: Nate
Real Name: Nate
Front Windshield A Members are welded in.
Old 03-04-2020, 09:42 PM #55
VernySanders's Avatar
VernySanders VernySanders is offline
Real Name: Werner
VernySanders will become famous soon enough VernySanders will become famous soon enough
Real Name: Werner
this cage is drool worthy lol
The dunes got boring because I couldn't jump. I'm not the type to enjoy someone else's vehicle. So i'm in the process of making making the dunes no longer boring. I guess that involves jumping.... A lot.
VernySanders is offline   Reply With QuoteReply With Quote
Old 03-05-2020, 04:06 PM #56
sleepydad's Avatar
Real Name: Andy ಠ_ಠ
sleepydad's Avatar
Real Name: Andy ಠ_ಠ
thank you
@Spunk
thank you for putting content out... I'm stuck doing a bathroom remodel and this is helping my sanity.
Old 03-28-2020, 12:37 AM #57
Real Name: Nate
Real Name: Nate
The COVID-19 problem has forced a break. Once the world opens back up again, I'll weld again.
Three notable things have occurred.
1. Drove it for 20-30 miles to a temporary storage place, got some good thumbs up on the highway.
2. A Tubing bender has been ordered. More tubing needs to be bent. JD2 Model 32. Everything is 6.5" CLR on this one.
3. Weldable paint has arrived--Steel-it. Yeah, this weldable paint is worth the money.
Upcoming: Sourcing more 2" tubing. The warehouse was two sticks short, so I'll buy more of them once all this blows over--I have plenty of 1-3/4 for filler though, so I'll be welding up the overhead and rear areas until I can buy the 2".
Old 04-13-2020, 12:46 AM #58
Real Name: Nate
Real Name: Nate
Done some floor tubing, and that’s on instagram.
Good Mayhem on Instagram: “Left floor tube fitted! Both it and the right floor tube have a slightly upswept bend in the front to facilitate two things: welding access…”
Meanwhile, here’s a vid on the upcoming overhead tubing. https://www.youtube.com/watch?v=07mJQ8lXnQQ&feature=youtu.be
Old 04-14-2020, 11:46 PM #59
Real Name: Nate
Real Name: Nate
Here's some photos of the four new tubes that have been fitted.
Rolling Tubing Bender
Right lower Tube
Left Lower Tube
Center and Right Overhead Tubes
Upcoming is Left Overhead Tube and rear floor tube.
Old 04-15-2020, 05:07 PM #60
Road Bull's Avatar
Road Bull Road Bull is online now
Real Name: Ryder
Road Bull is a jewel in the rough Road Bull is a jewel in the rough Road Bull is a jewel in the rough Road Bull is a jewel in the rough
Road Bull's Avatar
Real Name: Ryder
Where did you source the Steel-it paint? First look led me to believe it could only be purchased by the case at over $300. BTW... looking good man!
2002 SR-5 in Millennium Silver.
Timeline>> http://www.toyota-4runner.org/3rd-ge...-timeline.html DEAD
2002 SR5 Changeling Build https://www.toyota-4runner.org/3rd-g...ing-build.html
Road Bull is online now   Reply With QuoteReply With Quote
>BUILD THREAD< The4kbeast's 3rd-Gen 2000 T4R SR5 (Highlander Edition) 4x4 Build The4kbeast 3rd gen T4Rs 285 07-25-2018 09:37 PM
STRRAYNGE Build Thread! Or, I should say, After Build Thread?! Pic Heavy STRRAYNGE 3rd gen T4Rs 24 02-11-2016 10:46 AM
1998 T4R Build Thread/Rear bumper build 4running11191 4running11191 3rd gen T4Rs 3 09-19-2014 07:07 PM
loss of spunk rubbman 3rd gen T4Rs 1 02-28-2011 12:39 AM
