12-13-2019, 06:00 PM
#46
Real Name: Andy ಠ_ಠ
Real Name: Andy ಠ_ಠ
why has this build not been continued?
this build needs to be continued
02-08-2020, 11:46 PM
#47
Real Name: Nate
Real Name: Nate
It's being continued. Had to work through some deep details.
Here's the photos from fitup today.
A Pillars and B Pillars tacked together.
Made a offset mount for the dashbard's cross bar, so the front cross bar can fit.
Image of mount.
Current photo as of this afternoon.
long travel F/R, major fabrication work, shrockworks armor, whitsonmetalworks, dual-rate coilovers F/R, warn, rigid, ARB, more buttons than brains.
02-17-2020, 03:02 PM
#48
Real Name: Nate
Real Name: Nate
Since there's a cross bar in the front, now the gauge cluster needs a new home.
It's all really rough at this point, but I trimmed the black molding of the cluster, and glued on a plexiglass sheet. That way, it sits in a smaller footprint. Now onto mounts. I changed out burnt out bulbs with LED's in the meantime.
02-17-2020, 05:12 PM
#49
Real Name: Dan
Real Name: Dan
google photos don't show on the forum, you have to use imgur or another host, your build is epic btw
02-18-2020, 02:03 AM
#50
Real Name: Nate
Real Name: Nate
Fixed, and thanks!!!
02-19-2020, 11:59 PM
#51
Real Name: Nate
Real Name: Nate
02-22-2020, 01:12 AM
#52
Real Name: Nate
Real Name: Nate
Tube #8 is in position.
Over the windshield
View From the rear
Joint of #1 and #2 tubing with tubing cap and crossbar.
02-23-2020, 03:11 AM
#53
Real Name: Nate
Real Name: Nate
03-03-2020, 09:49 PM
#54
Real Name: Nate
Real Name: Nate
Front Windshield A Members are welded in.
03-04-2020, 09:42 PM
#55
Real Name: Werner
Real Name: Werner
this cage is drool worthy lol
The dunes got boring because I couldn't jump. I'm not the type to enjoy someone else's vehicle. So i'm in the process of making making the dunes no longer boring. I guess that involves jumping.... A lot.
03-05-2020, 04:06 PM
#56
Real Name: Andy ಠ_ಠ
Real Name: Andy ಠ_ಠ
thank you
@ Spunk
thank you for putting content out... I'm stuck doing a bathroom remodel and this is helping my sanity.
03-28-2020, 12:37 AM
#57
Real Name: Nate
Real Name: Nate
The COVID-19 problem has forced a break. Once the world opens back up again, I'll weld again.
Three notable things have occurred.
1. Drove it for 20-30 miles to a temporary storage place, got some good thumbs up on the highway.
2. A Tubing bender has been ordered. More tubing needs to be bent. JD2 Model 32. Everything is 6.5" CLR on this one.
3. Weldable paint has arrived--Steel-it. Yeah, this weldable paint is worth the money.
Upcoming: Sourcing more 2" tubing. The warehouse was two sticks short, so I'll buy more of them once all this blows over--I have plenty of 1-3/4 for filler though, so I'll be welding up the overhead and rear areas until I can buy the 2".
04-13-2020, 12:46 AM
#58
Real Name: Nate
Real Name: Nate
04-14-2020, 11:46 PM
#59
Real Name: Nate
Real Name: Nate
Here's some photos of the four new tubes that have been fitted.
Rolling Tubing Bender
Right lower Tube
Left Lower Tube
Center and Right Overhead Tubes
Upcoming is Left Overhead Tube and rear floor tube.
04-15-2020, 05:07 PM
#60
Real Name: Ryder
Real Name: Ryder
Where did you source the Steel-it paint? First look led me to believe it could only be purchased by the case at over $300. BTW... looking good man!
