Originally Posted by nobb
Thanks for the suggestions! I don't have an air compressor so was thinking of modifying a $10 garden pump sprayer with an extended nozzle. I wonder if it would be able to spray a thicker fluid like oil.
IMPO - a pump sprayer, only transfers thinner liquids / probably not oil or wax-oil effectively.
This is recommended as the DYI Fluid Film method:
Back in the 1970's - I had my car used oil sprayed, every fall.
- however, con is on the Ph level / used engine oil, has acid in it
I have sprayed Krown myself, decades ago / it seamed water soluble, and washed off too quick.
- gone from the wheel wells, in one months time
Now I stick to way-oil products / but vehicle metal has to be totally free of any moisture, for lasting protection.
