Originally posted by Lexusbstrdchild
when you first hit the button to get into 4wd, were you moving? you have to move a little bit before it engages.
right. if you shift into 4lo and back to 4 hi while rolling very slow and in NEUTRAL, you will feel a light grind. You should not have to force the gears together, just a light push should do it. but you should be stopped and in neutral before shifting into low range.
