Originally Posted by carlosbcr
I have something similiar, any clue? already replace starter, grounds, i going to replace starter relay and see. tha person who post this issue resolve it? Thanks a lot!
Battery terminals clean and tight.
battery wire to the starter clean and tight at the starter end.
ground wire starter and battery clean and tight.
Wires harness for the starter not corroded in good shape.
Have someone turn the ignition key while you have your hand on the starter. you should be able to feel the plunger move. If it moves then trouble shoot up stream. if it doesn't then it's the starter.
Next time it won't start. use override shift button see if it starts.
Tap on the starter if it starts then it's the starter contacts.
Test the starter relay.
When you turn the key in the ignition. All lights come on the dash, radio headlights wipers etc work.
When the ignition key is in crank position the warning lights dim indicating that the starter is getting energized.
If all that checks out check fuses and look at the starter and ignition circuit wiring layout in the fsm and go from there.
