07-11-2016, 10:06 PM
#16
Real Name: Alex
Real Name: Alex
#1: Charcoal '98 limited 4X4; Totaled, stripped, parted out (gone!) #2: Black '98 limited 4X4; Build Thread (sold!) #3: Grey '99 SR5 2wd; 4cyl top end rebuilt (sold!) #4: Millennium Silver '01 SR5 4x4; Little bro's ride rusted out frame gonna need fixing #5: Imperial Jade '99 Limited 4x4 e-locker; Dad's, guess he had to have one too #6: Black '98 V6 2wd; Cracked head, engine swapped (sold!) #7: Black 97 4cyl 2wd; Awaiting tear down, and build... #8: Silver '00 4x4; Front end accident, partout #9: Tan '06 Tundra DCSB 2wd; Daily, tow rig #10: White 97 Taco V6 4x4 LT; Bent frame, awaiting tare down...
07-11-2016, 10:53 PM
#17
Real Name: Alex
Real Name: Alex
08-26-2016, 12:30 PM
#18
Real Name: Alex
Real Name: Alex
So I added a different reservoir that would take up a little less space in the engine bay and moved it to the other side, with that I reused the old overflow tank as a washer fluid reservoir and stuffed it in front of the air box. All I had to do was drill two holes in the plastic which was surprisingly fast and then I silicone the rubber seals in to ensure no leaks. I also plugged up the holes in the cap with some hot glue, I didn't think they'd be an issue but I didn't wanna do it twice.
I also built a panhard drop, its flat welded to the truck and its run through the original bolts. Happy with the result, the drop was about 3.25 inches but it wasn't super exact, I just got it as flat as possible.
Also discovered I'm semi-prewired for a locker while I was installing my stand alone harness...
08-27-2016, 04:08 PM
#19
Real Name: Alex
Real Name: Alex
08-27-2016, 09:18 PM
#20
Your 4runner looks good. I love those wheels on a black runner and those tires are badarse. I put Cooper ST Maxx on mine because the STT pros had not came out yet. Why did you change grilles?
1999 Toyota 4runner limited 4x4 elocker
"Not all who wander are lost"
08-27-2016, 10:36 PM
#21
Real Name: Phil
Real Name: Phil
Originally Posted by RockenAlex
Then I pulled my headliner to replace the sunroof with a spare i had so it would open again. Well once i completed that, I sound deadened and insulated the roof from the sunroof opening to the rear door frame. I can feel a massive difference in the temps inside the car. Parked with the rear window cracked in the sun the car stays at least 10 degrees cooler and driving with A/C now feels like the car has actually cooled down rather than the A/C just cranking away.
Attachment 211518
Nice. I just finished doing my floor a few weeks ago which made quite a difference in noise. I've done the entire floor, hatch and doors at this point. I was planning on doing the roof as well. I haven't seen many people who have done the roof. Did you notice any difference in noise?
267/75/17 Cooper ATs - Level 8ZX wheels matte black - EBC rotors/ pads - 99 coils/ Bilstein 5100s - deckplate - Sotashi/custom emblem - Hella micro DE fogs - Kenwood/Alpine/Infinity system - sound deadened interior - color matched bumpers - LED tails - Safari LTD rack - Husky floor liners - clear corners
08-28-2016, 12:53 AM
#22
Check out Oznium for quality USA made in house LED products. Their bolt Leds are real nice. I've been using them in a similar fashion as drls without issue for years.
Oh, love the bronze on black. I had the same bronze wheels on my Black Tundra.
Sent from my SM-G930V using Tapatalk
08-28-2016, 11:19 PM
#23
Real Name: Alex
Real Name: Alex
A combination of things, I was getting stuff painted so I wanted it to match, I was going to have to cut the statoshi grille the PO made up a bit to fit a winch where the newer style still looked good with the cuts I made, and I sold it to a friend who needed a replacement after a fender bender.
Honestly there wasn't really much of a difference in noise coming from the roof, I don't see that as much of a source for noise since I don't even have a roof rack up there to make any noise.
I would have loved to do the rest of the truck but didn't really have time this go around, I'll probably get it all done after winter but I'm not really sure.
08-29-2016, 12:01 AM
#24
Nice truck. I like those little Led in the pillars. I've been planning to do it but haven't pulled the trigger.
At 160k I'm shocked you needed new u joints and rebalanced drive shaft. What made you get all that? Bad vibration ?
I to was curious about the snorkel and the rain lol. But I can't think how rain doesn't get inside the snorkel when driving. But then again what happens if you go fast over a deep puddle? I doubt ARB didn't think of this. But I would of probably done the same, turn the head backwards lol
97 3.4 JDM/5 Speed swap/eLocker Swap/ICON CDC all around/+more.....
03-03-2017, 03:28 PM
#25
Real Name: Alex
Real Name: Alex
03-04-2017, 01:04 AM
#26
Loving this build!
1998 Desert Dune Toyota 4runner Limited 4x4 w/ factory e-locker
2000 BLACK Toyota 4runner Limited 4x4 w/ factory e-locker Build Thread
2002 Thundercloud Metalic Toyota 4runner Limited 4x4
Build Thread
