Old 07-08-2016, 07:11 PM #1
salgood's Avatar
salgood salgood is offline
Real Name: J.
salgood is on a distinguished road
salgood's Avatar
Real Name: J.
Loud humming above 50mph coming from front/driver front. No vibration in wheel
No vibration in steering wheel,
3rd gen...
have a loud humming at 50mph or above. I took her in to get an alignment after new tired and shop said lower ball joint is shot and would be of no use with an alignment. I have bad wear on inner side of driver front... thought that was the culprit. I changed the lower ball joint and loud hum still present. Changing outer tie rods and other LBJ next. I read a thread where universal joint was replaced. Is this my problem or shuld should I continue with tie rod and LBJ?
Im in the unknown at this point. Any help/tips appreciated.
Sorry if I left anything out, submitting on mobile. Please feel free to ask me or point me to other theads. Much love, cheers!
EDIT: Forgot to mention as I make a turn left on bend in road above 50mph, noise is gone until I straighten wheels and bear striaght again.
LATE UPDATE: Paid for wheel bearing replacement on both front wheels and sound/vibration is non-existent. Sounds like a brand new vehicle. Thank you for advice and knowledge that got my T4R the service it needed without paying the shop to do any unnecessary added on bills. Much love.
salgood is offline   Reply With QuoteReply With Quote
Old 07-08-2016, 07:47 PM #2
Konkordmusk Konkordmusk is offline
Konkordmusk is on a distinguished road
So the noise is there even after new tires?
It could be the wheel bearing, shake the tire side to side while up in the air to check for play.
The 4Runner does not actually drive. It simply rotates the Earth to your desired position.
Konkordmusk is offline   Reply With QuoteReply With Quote
Old 07-08-2016, 08:12 PM #3
euser euser is offline
euser will become famous soon enough euser will become famous soon enough
3rd gen...
If you have any play in the U-Joints then they are bad. Just get down there and shake your drive shaft around. Could also be the bearings. If theres play when you grab the tire at the 12 and 6 and push up and down its likely the bearing.
euser is offline   Reply With QuoteReply With Quote
Old 07-08-2016, 08:28 PM #4
salgood's Avatar
Real Name: J.
salgood's Avatar
Real Name: J.
10.4 will check for play. Are U-Joints/bearings easy to do?
Old 07-08-2016, 09:25 PM #5
You need a press for bearings. The u-joints are pretty easy. I had a shop quote me 360 for a front bearing. Its probably more expensive than smaller shops, but i like going somewhere that warranties their work and has national locations. Its saved me before.
Old 07-08-2016, 10:33 PM #6
Morphyne Morphyne is offline
Morphyne will become famous soon enough
Sounds like a wheel bearing.
Morphyne is offline   Reply With QuoteReply With Quote
Old 07-10-2016, 12:52 PM #7
salgood's Avatar
Real Name: J.
salgood's Avatar
Real Name: J.
Yes. Wore inner driver front tire more than other tires. Seemed to have gotten worse after new rubber installed. I know something is worn out, not sure what. I edited my original post about left turns on highway at speed where noise is gone until straightening out.
Checking play in bearing u-joints today. Will update then.
Thanks.
Old 07-10-2016, 01:22 PM #8
Thanks.
If the noise is going away when you make turns it is not your driveshaft, but almost definitely a wheel bearing. Turning places the inner and outer race of the bearing under tension and temporarily reduces the vibration.
Old 07-10-2016, 04:30 PM #9
frodiesel's Avatar
frodiesel frodiesel is offline
frodiesel is on a distinguished road
frodiesel's Avatar
I had this problem and i swore it was in the front. Against instinct i took her to a shop, paid 20$ and found it to be the rear driver wheel bearing.
Then i changed rear seals, brakes, and both bearings. It was expensive, but i should be good for another 237k miles.
Drove 600miles to central missouri and she's super quiet in the cab, fronts barely have any noise, likely tire wear.
If the front lbj was done, did you check the lower control arm bushings? You really need to take it out and check with screwdriver.
frodiesel is offline   Reply With QuoteReply With Quote
Old 07-24-2016, 03:09 PM #10
salgood's Avatar
Real Name: J.
salgood's Avatar
Real Name: J.
Sorry for late response. There is play in wheel and a little loose. Thank you for your comment. Now I just need somebody to do less than what Toyota will charge, $690. I have called some shops but have not gotten back to me. Hence why I asked dealership for quote. Oh well.
Old 08-11-2016, 08:00 PM #11
Shane8820 Shane8820 is offline
Shane8820 is on a distinguished road
Is that for a 2wd?
Shane8820 is offline   Reply With QuoteReply With Quote
Old 08-11-2016, 08:36 PM #12
Victor_inox's Avatar
Victor_inox Victor_inox is offline
Victor_inox is on a distinguished road
wheel bearing 100%
Victor_inox is offline   Reply With QuoteReply With Quote
Old 05-10-2017, 01:59 PM #13
hurriedcoyote hurriedcoyote is offline
hurriedcoyote is on a distinguished road
I've got a similar sound. Only occurs above 50mph. It all but goes away if I take it up to that speed in 4H. ?????? Differential bearings???
hurriedcoyote is offline   Reply With QuoteReply With Quote
Old 05-10-2017, 02:58 PM #14
nevada's Avatar
nevada nevada is offline
nevada has a spectacular aura about nevada has a spectacular aura about nevada has a spectacular aura about
nevada's Avatar
the fact that it changes when you go into 4H is a bad sign. but doesn't necessarily aim at the diff.
get the front bearings checked carefully. even if there is no slop, they can still be bad. get it up in the air, and run it in 4wd. then use a stethoscope(long handled screw driver will work in a pinch) and listen at the diff, and at the wheels when its running. you should be able to pinpoint which bearing is bad by the change in pitch and volume of the sound.
I feel that I shouldn't have to say it, but stay clear of the tires! you'll likely want it running 35mph+.
1985 pickup: EFI 331/4r70W-Dana 300-42 TSL SXII's/raceline beadlocks-30spl longs-5.29's-spools-sky Hi steer-OBA/4g tank-10.5k RR winch-dual blue tops-200 amp alt-flatbed.
1985 4runner sr5: 22RE/5spd-6" pro-comp suspension-37 BFG at's-5.29 gears-Badlands Basher bumper-8.5k RR winch.
2006 4runner v8 limited: stock. Build Thread YouTube Channel
nevada is offline   Reply With QuoteReply With Quote
Old 05-10-2017, 03:18 PM #15
flipty flipty is offline
Real Name: Dave
flipty is on a distinguished road
Real Name: Dave
Seconding, thirding, and fourthing wheel bearing.
flipty is offline   Reply With QuoteReply With Quote
Intermittent Vibration Coming From Front End 911Etarga 4th Gen T4Rs 20 12-15-2023 05:36 PM
Help: Humming noise coming from front end while driving glock56534 4th Gen T4Rs 48 09-04-2023 02:14 AM
40-50mph front end humming when 4wd engaged. Is this normal for a new car? alext72888 5th gen T4Rs 2 02-16-2016 01:21 PM
Loud noise coming from front suspension. knightsfs4 4th Gen T4Rs 26 10-23-2015 08:00 PM
vibration/growl coming from front end --> help channer 4th Gen T4Rs 3 12-03-2004 07:11 PM
