08-29-2019, 06:30 PM
#196
Real Name: Robert');DROP TABLE Students;
I'm running 285s with 1.25" spacers and have mine set to E if I remember correctly. I got minor rubbing at the rear of the fender until I flattened the pinch weld.
2001 SR5 - Like OEM, only worse (gears, e-locker, armor)
08-29-2019, 06:51 PM
#197
I've flattened the pinch too. I like running the 255/85 tires, but there isnt many choices for an all-terrain tire in that size so I might end up going with the 285 when my km2 wear out. I might try the E or F setting and go from there. Still trying to wrap my head around on all this.
97 Charged, lifted, armored, geared, locked SR5.
05-06-2020, 02:02 PM
#198
Real Name: chad morrison
this is my allignment sheet. i have eccentric eliminators so i only have 3 options vs a traditional eccentric. my settings are at max caster (rears pointing out, fronts pointing in) and they changed my setting from G to E i believe. i dont rub but this is my allignment sheet. should i try putting the front lobes to neutral (up/down) and putting back to setting G? id doesnt necessarily drive crappy but id like a bit more caster yet my wheel still fairly out forward.
285/70/17 +11 wheel spec no bodylift
05-06-2020, 02:12 PM
#199
going back to G would decrease your caster even more. I would leave it there on E personally.
1999 SR5 V6 manual trans 4x4 - Lifted on 35's - Build thread
09-18-2020, 04:23 AM
#200
Is this applicable to 2.5 - 3 inches of lift, stock fat-lip bumper, and 285/70R17 tires?
Thanks!
Originally Posted by TonyB66
Well, I finally got the alignment done.
This is what I did beforehand, all to the max:
- Both rear cams pushed outward as far as possible
- Both front cams pulled inward as far as possible
- SPC UCAs on "G" moved inward far as possible
With that he simply played with the tie rods...
09-21-2020, 09:52 PM
#201
Real Name: Tony (no surprise)
Thanks!
Sorry, I don't frequent much here lately. I can say that I have almost exactly that much lift in the front. I also have 17s, the same tire size...
2000 Limited, E-locker
Maintenance/Build Thread
11-19-2020, 10:21 PM
#202
Hi All,
My lift kit is about to come in this weekend and I’m going to be getting 285/70R17 KO2s. Does anyone know of a good shop in the Bay Area area closer to Solano county?
Thank you.
04-20-2021, 03:40 PM
#203
Real Name: @ NorthTahoeT4R
Setting F sweet spot
PIC IS WITH "F" ALIGNMENT
After reading all 14 pages, I first of all set my LCA cams as recommended, pushing the wheel as far forward as possible. THEN:
1. Sent it to G on the star plate for the most possible firewall clearance *running 315's*
2. Maxed SPC camber adj all the way in (toward motor for negative as possible)
3. Torqued that nut to 150lbs and and off to the alignment shop.
Castor was acceptable at 2.3 Passenger and 2.0 Driver, toe was perfect, but my wheels still sat like this: \ / I could not achieve the camber I needed.
After chatting with Tom in tech at SPC (who is amazing and drives a 3rd gen), he crunched some numbers for me. backing off to "F" would give me a full 1* neg camber back on EACH wheel and would only cost me 1/10 of an inch of clearance in the back. Not to mention would get Castor numbers up as well.
I did that, took it back in to get the toe re-adjusted, and my numbers are bad ass.
04-20-2021, 09:47 PM
#204
I have to be honest - I have no idea how to interpret this. The 4Runner seems to drive & track well - maybe it has a bit of understeer.
Thoughts on these numbers?
1999 "Highlander" V6 4WD E-Locker || TRD Supercharger, URD 7th Injector, 2.2 Pulley || Toytec Aluma Series Boss Suspension, SPC A-Arms, Durobumps, Overland Endlinks || B&M Trans Cooler || 231mm Tundra Brakes, SS Brake Lines || 17" TRD Pro Wheels || BFG KO2 265/70R17-C || TRD Exhaust || 01-02 Tail Lights || Original Owner
04-21-2021, 08:31 AM
#205
Originally Posted by TRD 4RNR
I have to be honest - I have no idea how to interpret this. The 4Runner seems to drive & track well - maybe it has a bit of oversteer.
The numbers in the "min/max specification" column is the range your caster, camber & toe should fall within. Looks like your camber & toe numbers are within that range but the left camber is slightly higher than the max range. Your caster numbers are noticeably higher than the max range. If it drives well and there's no rubbing I'd be good with that.
1. Black 2002 SR5 4x4 5vz: Front Toytec Ultimate coilovers/eibach 600#, SPC UCA, durobumps Rear Bil5100/Superflex, SS adjustable panhard, PCK, durobumps Body Lift 2" 4crawler Tires 315/75/16 BFG KO2 Wheels SCS F5 Matte black 16x8 3.5bs Armor Custom bolt on rock sliders (no frame drilling)
2. Black 2001 SR5 4x4 5vz: stock
3. Black 2018 TRD Pro (wife’s): Armor Custom bolt on rock sliders (U-bolts)
03-01-2023, 04:48 AM
#206
which ubj position pulls the tire backwards?
I have 285s. i adjusted the cams as per the pic below. then placed the UBJ at G position but there was rubbing at the bumper valance. I measured about 4" of firewall clearance and close to 2" clearance between the bumper valance & the tire. I adjusted to F then to E but there was still rubbing. also, I noticed i got about 1" of addtl lift, making it 4" of lift total.
I would like to bring the tires a bit backwards to avoid rubbing with the bumper and bring it back to 3" of lift.
Thank you, appreciate your help.
You've been most helpful hammering home the G setting, that's the least I can do man. I just went through my photos and found some, but I thought I had more...
Here's a couple before I removed rust on the cam adjusters.
After some clean-up...
Hope that helps a little...
03-01-2023, 08:45 PM
#207
Real Name: C8H18 Mike
Technically, none. The SPC adjustments influence the angle of the spindle, hence caster.
In all fairness, D is neutral, A is +4° (increasing the caster angle by moving the top pivot backwards) and G is -4° (opposite of A)
To move your wheel to clear what I understand you saying you want, you need to move both LCA and UBJ. Here's how I did it (I used cam eliminators)
Rear LCA cam, full positive (outward)
Front LCA cam, neutral (centered)
SPC UBJ, set on E
Fix your camber and toe and go
Sent from my Pixel 4 XL using Tapatalk
1999 Toyota 4Runner SR5 Un-Sported 2WD, V6 Auto -> 2WD 4runner Journal Thread
03-02-2023, 07:59 AM
#208
would you happen to have some pics of the front and rear LCA cam settings?
SPC UBJ, set on E
03-02-2023, 03:21 PM
#209
I'm not running cams, I have cam eliminators, but your rear cam would be all the way counter clockwise and your front cam centered at 12:00 to match the recommended starting point
03-03-2023, 03:52 PM
#210
so for the rear cam adjusters, i follow the pic i quoted on post #206.
for the front cam adjusters, i position the hole in the cam adjuster in the 12:00 position.
did i get it right?
Thread Tools |
Display Modes |
Rate This Thread |
Linear Mode
