Old 07-13-2016, 02:07 AM #1
ShooterMcGavin's Avatar
ShooterMcGavin ShooterMcGavin is offline
ShooterMcGavin is on a distinguished road
CV boot repair - which option is right for me?
I have slightly higher than a 3" lift in the front. The inner boot for my passenger CV has ripped and grease is flung everywhere around it. The boot is old and seems weathered ...and I used the stretch technique to separate the ribs from rubbing after my lift.
I like driving off-road as much as possible, but that is usually not more than once or twice a month. There are some options I have...
1. Kit from Napa to re-boot the CV joints.
2. Aftermarket boots that are supposed to be tougher, maybe longer too?
3. Porsche longer boots. I think they are for the 930(?), but I'll need to do more research.
I have a 9" body lift.
Shooter's Build
ShooterMcGavin is offline   Reply With QuoteReply With Quote
Old 07-13-2016, 09:39 AM #2
nobb nobb is offline
nobb is on a distinguished road
I've found the Napa branded CV boots are made of a nice, sturdy, thick rubber. In contrast, the EMPI branded boots I've used were thinner and I started seeing wear in the material after a year. Napa's boots are also lifetime warranty.
My front is lifted 3" and I don't notice any rubbing. Maybe at a higher lift they begin to rub and you may need to consider stretching the boot?
Also the grease they supply with these kits is almost never enough so make sure you get extra.
nobb is offline   Reply With QuoteReply With Quote
Old 07-13-2016, 11:20 AM #3
Hesk11dog's Avatar
Hesk11dog Hesk11dog is offline
Hesk11dog is on a distinguished road
Hesk11dog's Avatar
If you are currently driving it around with a torn boot and plan on rebooting, make sure you do a thorough cleaning of the gears and joint before rebooting as dirt and water can now enter the axle. I tore a boot over the winter and decided on the NEW NAPA (lifetime warranty) half shalf. Was like $70 and did not have to submit the old one as a core. Seems legit and has not given me any problems with 2000 miles on it. I do some very light dirt and trail driving and have it lifted about 2 inches. You can then also reboot your old shaft and keep as a spare for the other side.
MINE - 97' SR5 manual (Desert Dune Metallic)
HER's - 14' limited (Altitude Black)
Hesk11dog is offline   Reply With QuoteReply With Quote
Old 07-13-2016, 11:39 AM #4
atalarico's Avatar
atalarico atalarico is offline
atalarico will become famous soon enough
atalarico's Avatar
Despite my best efforts, I have a close to 3" lift as well. I will say this after 4 years of having my lift...everything rubber related to your front suspension will wear out much faster. That's why I wanted to lower it a smidge, and I was hoping I'd drop more than .25" when I replaced my Tundra Bilstein 5100s for Tacoma ones, but it really had more to do with my Eibach spring. I digress...
1.) Rebuilding CV joints is a pretty massive pain in the ass. I did it once after my original lift using CVJ silicone inner boots and their neoprene outers. I think it was like $30-50 more if you include the core deposit to just get reman'd ones from them with the same boot setup.
I'll say that I never had any issues with those CVs function-wise, but the silicone boots busted after four years (?). They now include a rubber o-ring to put around the inner-most rib because I guess they can tear easily if stuff gets in there and rubs around.
I ended up buying reman'd CVs from CVJ this last summer, but I've experienced some issues in the front end that I didn't have prior to having those. I'm slowly eliminating other possibilities just in case, so I don't want to say it's for sure those, but my point is that I never had issues with my OEM CVs that I rebuilt.
2.) See above re: CVJ silicone boots. I'm probably going to go with something else next time around, as I don't have much faith in these holding up too well.
3.) Longer boots aren't a bad idea.
Good luck! Let us know how it works out!
2004 Sport Edition V8. 3" OME lift. 5th Gen Brakes. 285/70 Duratracs. JBA UCAs. SCS Ray10s. DT Headers.
1997 4-Runner Limited w/ factory locker. Totaled in February 2018. Still miss it.
atalarico is offline   Reply With QuoteReply With Quote
Old 07-13-2016, 12:14 PM #5
111db 111db is offline
111db is on a distinguished road
You have a 3" lift on your Prius!? Post up!
and maybe read this thread:
CV Axles - NAPA MaxDrive and A1 Cardone
111db is offline   Reply With QuoteReply With Quote
Old 07-13-2016, 01:38 PM #6
Scramble's Avatar
Scramble Scramble is offline
Real Name: Scramble
Scramble has a spectacular aura about Scramble has a spectacular aura about
Scramble's Avatar
Real Name: Scramble
I'm now running 2 new Napa Max-Drive's. I bought the Beck Arnley boot kit from Amazon for my OEM's. I haven't re-booted yet but they seem like quality boots & no bad reviews on them from anyone here, only positive.
____________
'99 4Runner - 2.7L 3RZ, 5 Speed, 4.56 Gears - Lifted, Locked & Loaded - 166k Original owner - http://www.toyota-4runner.org/3rd-ge...ld-thread.html
'99 Limited - E-Locker- Stock (for now) - 233k 2nd Owner http://www.toyota-4runner.org/3rd-ge...ted-build.html
Scramble is offline   Reply With QuoteReply With Quote
Old 07-13-2016, 01:56 PM #7
GVL's Avatar
GVL GVL is offline
GVL is on a distinguished road
GVL GVL is offline
GVL's Avatar
I just tore the same boot and went with a reman OE from CVJ and it's working great again, but the Napa's were my next option with that life-warranty. Good luck.
2000 Highlander - 3" OME 883F 890R - ARB F&R Lockers - AOR Bumper - Savage Armor - WARN M8000 - RIGID LED Floods - TRD Wheels - TBU - HID - BFG KM2
GVL is offline   Reply With QuoteReply With Quote
Old 07-13-2016, 02:00 PM #8
atalarico's Avatar
atalarico's Avatar
Oh, and if you get NAPA and need to warranty it, YOU WERE JUST DRIVING ALONG ON PAVEMENT. I don't know for certain, but generally speaking, any lifetime warranty on car parts excludes off-road use. JFYI.
Old 07-13-2016, 02:43 PM #9
90goldtsiawd's Avatar
90goldtsiawd 90goldtsiawd is offline
90goldtsiawd is on a distinguished road
Just lifted mine recently so I'm sure I'll need to look into this in the near future. Any more info on the Porsche 930 longer boots?
My '01 4Runner Sport 4x4 Build
90goldtsiawd is offline   Reply With QuoteReply With Quote
Old 07-13-2016, 07:08 PM #10
Thanks guys. Good info so far. I'm avoiding driving it while it is torn but I'll probably still drive it on the road. I need to find out what is the proper grease to use, to replace the stuff that has been flung out.
I want to avoid using non-OEM CVs. I put them through some hard use so breaking one is a possibility.
How do the Napa Max-Drives compare to OEM CVs? Any strength difference?
I'll have to do some extra research on all the options to see what I want to do.
Additional info: I am really tight on money now so I don't see myself buying reman's from CVJ. I'm trying to keep OEM quality and do this on a tiny budget. At least I am in the process of getting a new job soon
Shooter's Build
Old 07-13-2016, 07:19 PM #11
Anybody got a link for CVJ?
Old 07-13-2016, 08:21 PM #12
fourfive's Avatar
fourfive fourfive is offline
fourfive is a jewel in the rough fourfive is a jewel in the rough fourfive is a jewel in the rough fourfive is a jewel in the rough
fourfive's Avatar
Out of the three options, I would go with napa. It seems like others that went this route had good outcomes. That along with the lifetime warranty, ease of getting parts & probably being less $ is why i would lean more towards napa.
If I wasn't an oem psycho with my general parts replacements, I would have gone napa when i rebooted mine. Napa and cvj were the only aftermarket cv axles/reboot kits i considered before I went oem mainly because those were the two i found the most info on at the time.
1. Black 2002 SR5 4x4 5vz: Front Toytec Ultimate coilovers/eibach 600#, SPC UCA, durobumps Rear Bil5100/Superflex, SS adjustable panhard, PCK, durobumps Body Lift 2" 4crawler Tires 315/75/16 BFG KO2 Wheels SCS F5 Matte black 16x8 3.5bs Armor Custom bolt on rock sliders (no frame drilling)
2. Black 2001 SR5 4x4 5vz: stock
3. Black 2018 TRD Pro (wife’s): Armor Custom bolt on rock sliders (U-bolts)
Last edited by fourfive; 07-13-2016 at 08:22 PM. Reason: Edit: added cvj as the other aftermarket cv i looked into
fourfive is offline   Reply With QuoteReply With Quote
Old 07-14-2016, 08:19 AM #13
Hesk11dog's Avatar
Hesk11dog's Avatar
You can find OEM reboot kits that come with grease on ebay. It is just going to keep flinging grease out till it is sealed so I wouldn't clean it yet.
Avoiding non-OEM is most often a smart choice but I did some research before I decided and it just seemed like the NAPA maxdrives were the best budget option for me along with ease of obtaining and possibly replacing since I work 100 yards from a NAPA store. it really is not hard to replace the half shaft if the napa does break and everything is free with the lifetime warranty.
I know a lot of people on here are OEM junkies but there are decent aftermarket parts that have been tested by some of the senior members on here. Some with good things to say and some with bad, but that is how it is with everything.
here is one of the links I referenced when thinking about axles
If you have used NAPA cv axles please reply
An axle is going to break if you push it too hard, OEM, REMAN, or NEW. Doesn't matter, anything can break.
Old 07-14-2016, 08:55 AM #14
Rock_Rat's Avatar
Rock_Rat Rock_Rat is offline
Rock_Rat is on a distinguished road
Rock_Rat's Avatar
I decided to stick to OEM (matter of personal preferences) but there are a LOT of positive posts on here about the NAPA axles. Lifetime warranty is pretty good. Tear a boot, just replace. No cost other than time.
I went this route:
  • Used OEM axles from the junkyard - $40 each. (low mileage donor)
  • OEM boot kits that come with the grease already - PN# 04438-35060 - $43 ea from Camelback . Now you'll have two sets of OEM axles.
Total cost: $83 for rebuilt OEM axles.
Then all you need to buy is the inside boot kit as that's all that will probably tear from here on out. That kit is PN# 04438-35040 - $23.99 from camelback.
Of course you'll need the band clamp tools.
2001 Imperial Jade Gold Letter Sport Package - Original Owner
Rock_Rat is offline   Reply With QuoteReply With Quote
Old 03-24-2021, 06:14 PM #15
dertrommler dertrommler is offline
Real Name: Jas
dertrommler is on a distinguished road
Real Name: Jas
After scouring the internet and looking at do-it-yourself boots, aftermarket boots, OEM boots and go-to-a-dealer prices, I settled on the notion that it might cost $600 at Toyota for a pair of boots, so I went to a service center. I was quoted $635 per side! #stickershock #nothappy
dertrommler is offline   Reply With QuoteReply With Quote
Anyone ever heard of this CV boot repair solution? cantaloop Engines / Suspension / Wheels / Tires / Audio / Accessories 7 05-11-2016 02:06 PM
Rear shocks: boot up or boot down? mrlouie 3rd gen T4Rs 4 08-22-2011 10:27 AM
Toyota CV Boot repair kit Help!!! SIKHILUXSURF 3rd gen T4Rs 4 03-17-2011 04:17 PM
CV Boot repair hulk311 Problems & Warranty Issues 2 01-21-2011 09:13 PM
Woman rams repair shop after non-repair Sac State Off Topic 3 04-29-2005 06:50 PM
