07-15-2016, 12:41 AM
4 lo in a high mileage 3rd gen
In my last vehicle I didn't mind staying in 4 lo longer because it had under 100k miles so the hard shifts didn't worry me. In my 3rd gen with 220k I find myself only using 4 lo when I need it because I feel bad for the tranny. Is 4 lo much harder on it than normal shifting? Or am I just over thinking this?
07-15-2016, 12:49 AM
what kind of driving are we walking about? anything over 25mph?
do you really need to be in 4lo, i used mine crawling around on rocks and steep hills in moab. i have never really needed it anywhere else. 4 hi works fine.
Never ask a girl if shes sick, she might not be wearing any make up. - lets just say she went storming off.
Never tell your wife she looks tired, they tend to hit and say that means she looks ugly. (weird logic i know)
07-15-2016, 01:09 AM
On my overland trip I used 4Lo a few times for hours. I did notice a spike in temperature and adjusted accordingly and kept rpm's higher which helped cool down the transmission. I do not have a direct temperature for my transfer case but I did the 'assume' of transmission at 200F - Transfers case is probably somewhere close also. I also made sure I to take breaks often when doing it to prolong its life. I know from personal experience with my fathers offroad truck that his transfer case even working it hard has done really well with oil not breaking apart.
1997 3.4l, e locker retro|OME 3" lift|LED's|Upgraded rear seat(sold)
2013 4.0l Toyota Tacoma offroad (totalled )
2014 Toyota 4Runner Trail (stripped &sold) =(
2000 4Runner Limited Truck
07-15-2016, 01:15 AM
Oh no. Speeds under 10 for 4-lo. But it shifts around 5-7 mph.
07-15-2016, 01:23 AM
Real Name: Tim
Real Name: Tim
You're overthinking. I don't think you need to worry about the hard shifts when using 4 Lo. If you need it, use it.
07-15-2016, 10:26 AM
The transmission works the same or similar whether in 2wd, 4hi or 4lo.
The change in gearing is done in the transfer case.
There might be more of a potential shock load on the driveline in 4lo but I'm not sure.
1991 4runner 4wd Auto V6
1990 4runner 4wd Auto V6
07-15-2016, 10:28 AM
The hard shifting is normal. I doubt it's harmful.
07-15-2016, 11:06 AM
It would be silly to not use what your truck has because of miles. It's like, should you not go over 50mph because you have 200k on your engine.
97 3.4 JDM/5 Speed swap/eLocker Swap/ICON CDC all around/+more.....
07-15-2016, 12:18 PM
You're misunderstanding. I use 4-lo plenty but I don't ride in it most of the day like I used to. I still use it and will continue to. It makes no difference
07-15-2016, 12:20 PM
I know the hard shifting is normal
07-15-2016, 12:30 PM
I personally use 4Lo a lot more than 4hi and my rig has 264k miles. I use 4Lo a lot to keep tranny temps down when climbing hills on Forest roads/trails.
2000 4Runner Limited 4WD Built. Totaled
2014 4Runner Trail Premium Not Built.
2017 Tacoma DBLCB TRD OR
The Builds
07-15-2016, 12:41 PM
For what it's worth mine has 312,000 miles on it and it spends at least 6 hours in low 4x4 every weekend and just keeps on ticking!
97, e-locker, OME heavy/heavy springs, OME front/rear shocks, 285/75 16 BFG AT KO2, no sway bars.
07-15-2016, 01:09 PM
Real Name: Scramble
Real Name: Scramble
I always used to use 4hi, but the last time I wheeled it I was in 4lo all day & liked it much better. Barely had to step on the gas going up hill, less brakes going downhill, less chance of stalling. (5 speed) If my rpm's got too high I just switched to second gear. The truck just felt more capable & bad ass but I only have 158,000 on the TC/Trans.
____________
'99 4Runner - 2.7L 3RZ, 5 Speed, 4.56 Gears - Lifted, Locked & Loaded - 166k Original owner - http://www.toyota-4runner.org/3rd-ge...ld-thread.html
'99 Limited - E-Locker- Stock (for now) - 233k 2nd Owner http://www.toyota-4runner.org/3rd-ge...ted-build.html
07-15-2016, 01:49 PM
Originally Posted by PWD4R
... Is 4 lo much harder on it than normal shifting? Or am I just over thinking this?
If you want to avoid the 1-2 shift in 4LO then start in 2nd gear in 4LO (assuming you don't need the lower ratio of 1 when starting off). Works for 01'-02's not sure about other years....
07-15-2016, 01:50 PM
I have an auto. Not an option.
