Here you go hope this helps.
here are the kings custom ordered. remote resi adjustable 700lbs
Old pulled out. Kings 2.5 custom set up Vs sonoran steel 1.2
Installed and mounted Resi to have access to the Adjustment
It didn't need any adjustment from factory except to check the tightening of the collar allen. its a pain to get to once mounted. It was tight but for the piece of mind double checking doesn't hurt.
Buttoned up and everything worked out well on 3 shake down runs including Hollister Hills. Full access to the adjuster even with 285's
2002 - trd s/c, header, exhaust, urd 7th...armored and expo set up
http://www.toyota-4runner.org/3rd-ge...ml#post2355344
1989 - 1UZ swap Cali Bar'd --SOLD--
http://www.toyota-4runner.org/classi...xperiment.html
