New ignition lock cylinder - won't engage ignition - 1996 base
I had my ignition lock cylinder lock up and couldn't get it to acc to remove it so I had to drill it out.
The new one slides in fine and the key turns to lock, acc, on and start but when I try to start it nothing happens.
It also does not kill the power when I turn the key to lock and remove it.
When the key is in and the door is ajar the chime sounds and when I remove it the chime stops so it recognizes the keys in.
I can manually turn the ignition thing (not sure what it's called) inside the aluminum housing and it seems to settle in acc but is this somehow misaligned?
I don't see any damage to the aluminum housing or any parts inside and everything seems to be in one piece, I just can't figure out what I am doing wrong.
