Originally Posted by dmccunney
Would love some advice on the struts/shocks you used! I am looking to do the same for my 03 Limited.
agreed you should be in the 4th gen section for your 2003 4th gen 4runner.
but a quick reply is it depends on what you do with teh 4runner, if daily driver & mostly street use, got with used low mile OEM or consider KYB replacements that are priced very fair & will return the ride to as good or better than OEM & provide about 1" lift in the front over stock height.
fyi: 4runners dont have struts, just coil over shocks up front & normal shock in the rear.
