Old 08-17-2021, 04:44 PM #526
Bad Luck Bad Luck is offline
Real Name: Patrick
Real Name: Patrick
Originally Posted by Black798 View Post
Also mocked up a tire to get an idea of where things will sit. Hoping to hit a 21" frame height on 37s with 4 to 5 inches of uptravel, we will see how obtainable that is
That's gonna look impressive! How much down travel are you expecting/hoping for?
Old 08-17-2021, 07:39 PM #527
Black798's Avatar
Black798 Black798 is offline
Real Name: Phoenix
Black798 is just really nice Black798 is just really nice Black798 is just really nice Black798 is just really nice
Black798's Avatar
Real Name: Phoenix
The rear I have it planned to be strapped around 13". The front I have a set of 12 inch coil overs on order for so it should be around the 12 to 13 range depending on how I mount the coil overs.
98 Limited - Solid Axle Swapped,Turboed,And On 37s - Build
Transgo Shit Kit Writeup - Click Here
Black798 is offline   Reply With QuoteReply With Quote
Old 09-20-2021, 04:16 PM #528
Black798's Avatar
Real Name: Phoenix
Black798's Avatar
Real Name: Phoenix
Ive slowly been picking away at stuff with the truck and have made some decent progress in the last few weeks. 1st big thing was finally getting the frame stripped and the new frame plates on. I choose to plate the rear as well to hopefully reduce frame flex a little and to fill in the area where my outboard shock mounts were located.
IMG_0718
IMG_0713
Made up all the rear link mounts and I have those tacked in place now. Next step there will be figuring out all the coilover mounting to make the cantilever work. I have a rough model in solidworks of it all but making it match the truck will require some tweaks.
IMG_0709
After a crazy long wait I finally got the new wheels in last week and was able to mount them up. I wound up getting trail ready 17x8.5 beadlocks and threw a set of apex designs valve stems at them to make airing up and down a little faster and easier.
IMG_0725
IMG_0733
Old 09-21-2021, 02:44 AM #529
stevew092984 stevew092984 is offline
stevew092984 is on a distinguished road
Lookin good!!!
stevew092984 is offline   Reply With QuoteReply With Quote
Old 09-21-2021, 09:27 PM #530
busmup808's Avatar
busmup808 busmup808 is offline
busmup808 is a jewel in the rough busmup808 is a jewel in the rough busmup808 is a jewel in the rough busmup808 is a jewel in the rough
busmup808's Avatar
Looks like we doing the same thing at the same time. Nice work!
Busmup808 all day, all night!
busmup808 is offline   Reply With QuoteReply With Quote
Old 11-15-2021, 12:57 AM #531
Black798's Avatar
Real Name: Phoenix
Black798's Avatar
Real Name: Phoenix
Finally making enough progress that its worthwhile to post. Rear suspension is essentially done. There are a few more welds to make but it right there. Ended up at 12" of travel after I strapped and bumped it which I am pretty happy about. The 37s are clearing great even though I gained about an inch of uptravel over my old setup. There isnt too much else to say about it since most of this stuff is just me pending a ton of time testing and cycling stuff and just figuring out what will work best given the packaging I have to maintain and all of that. Time to start cracking on the front.
IMG_0735
IMG_0738
IMG_0739
IMG_0740
IMG_0741
IMG_0743
IMG_0747
IMG_0748
IMG_0749
IMG_0751
Old 11-15-2021, 02:30 AM #532
infamousRNR's Avatar
infamousRNR infamousRNR is offline
infamousRNR is a glorious beacon of light infamousRNR is a glorious beacon of light infamousRNR is a glorious beacon of light infamousRNR is a glorious beacon of light infamousRNR is a glorious beacon of light infamousRNR is a glorious beacon of light
sheesh!! these are some Sicmods for sure
1998 Desert Dune Toyota 4runner Limited 4x4 w/ factory e-locker
2000 BLACK Toyota 4runner Limited 4x4 w/ factory e-locker Build Thread
2002 Thundercloud Metalic Toyota 4runner Limited 4x4
Build Thread
infamousRNR is offline   Reply With QuoteReply With Quote
Old 11-15-2021, 09:33 AM #533
rdruss's Avatar
rdruss rdruss is offline
Real Name: Ron
rdruss's Avatar
Real Name: Ron
If I could weld like you (or at all) I would reinforce every inch of my frame that I could get to as you have. With all the rust I have gotten out of the inside of my frame and the hole that I had patched I'm pretty sure the frame is about half what it was when new!
Old 11-15-2021, 10:08 AM #534
Real Name: Patrick
Real Name: Patrick
I can only hit the like button once which is not nearly enough for the impressive fab work and design that you are putting into this!
Old 11-15-2021, 10:35 AM #535
busmup808's Avatar
busmup808's Avatar
Black798's 98 limited build thread
Very nice. I like how you have the shocks set up and how your 3 link is also set up. Well done brother.
Old 11-19-2021, 01:25 PM #536
Team_Jake's Avatar
Team_Jake Team_Jake is offline
Team_Jake is just really nice Team_Jake is just really nice Team_Jake is just really nice Team_Jake is just really nice
Team_Jake's Avatar
Didn't realize you were SASing, now I'm following very closely. Excited to see everything coming together! Interested in more details on the cantilever setup.
1999 4Runner Limited - 5VZ, 4wd, Factory E-Locker, Multi-Mode, 5-speed swap, Armored, Icons, 295s (thread)
2001 Tacoma Xtracab - 3RZ, 4wd, 5-speed (Daily Driver)
Team_Jake is offline   Reply With QuoteReply With Quote
Old 01-24-2022, 03:19 PM #537
Black798's Avatar
Real Name: Phoenix
Black798's Avatar
Real Name: Phoenix
I'm way behind on updates with this thing since I am scrambling so bad to get it finished. Trying to have the truck loaded up and on the road to Moab the second week in March so its a dash to the finish at this point.
A few weeks ago I went through and got the new crawlbox built and ready for install. I went with a new style crawlbox that Northwest Fabworks is making now called the eco crawler. It is based off the Toyota chain drive cases so finding donor parts is way easier than the old style Toyota gear driven stuff. It also is a more compact setup and should be stronger overall. Install was super easy and the machine work was top notch.
Donor case all ready to be split apart
IMG_0752
IMG_0757
Main shaft out
IMG_0753
Planetary gears all pulled out. This is the only part needed from the donor case.
IMG_0755
Front half of the crawl box assembled with the shift fork.
IMG_0761
Rear half of the case ready for assembly. Northwest fab sends a new input shaft for the rear case so there's no need for any adapter plates or couplers between the cases.
IMG_0760
Final assembled unit 6.5" longer than before and with double the low range. Just waiting on the shifters for it ship from NWF.
IMG_0763
Updates on the front suspension coming soon, just need to upload the pictures.
Old 01-26-2022, 12:42 AM #538
Black798's Avatar
Real Name: Phoenix
Black798's Avatar
Real Name: Phoenix
Ok so front suspension. I dont have a ton of pictures of the build process of it because it was literally just weeks of cycling things, mocking up mounts, moving them around and repeating. I finally got everything situated where it needed to go though. Burned out all the brackets on the plasma table and here is were I ended up.
Couple of things to point out. The clearance on everything is TIGHT. I knew this front end would be a packaging nightmare, especially trying to fit the front swaybar but this was something I really wanted to incorporate as well as the hydro bumps. My finished axle width is 63" wide, narrower than what most do but I wanted the whole setup to look like Toyota intended for it to be there. Having the tires as close to flush with the flares as possible was key to this
IMG_0822
Had to get a little funky with the drivers side sway bar arm to get it around the pitman arm and steering box.
IMG_0825
IMG_20220118_151803
Also had to really work to keep all the uptravel I could and have a low ride height. This took a couple of s bends in the tie rod and drag link. All I can say here is the rogue fab tube bender I bought last year kicks some serious ass. It made these bends a cake walk
IMG_0828
IMG_0832
After setting my steering stops where I knew the tires cleared and the birfs wouldnt bind I was coming up just shy of the 6" of tie rod stroke that the hydro ram I got needed. So I ended up tack welding a small dom spacer inside it to keep the ram from trying to over extend the knuckles. Ive never seen it happen to a Toyota knuckle but with the dana axles Ive seen quite a few knuckles get cracked from not doing this.
IMG_20211226_124555
I also decided to make the switch from the "tried and true" 80 series tie rod end to a full chevy 1 ton steering setup. I figure the larger ball socket will make eveything last longer and just be that much more bullet proof.
IMG_20211212_210951
IMG_20211219_154258
I have everything blow back apart now for paint but Im getting dangerously close to actually driving this thing again. Driveshafts are out getting retubed and the front rcvs are the only thing left that I am waiting on parts wise. I am hoping in the next 4 weeks itll be on the road.
Old 01-26-2022, 12:23 PM #539
cdrewferd cdrewferd is offline
Banned
cdrewferd is on a distinguished road
Banned
Awesome progress!!! I've been eyeing that Eco Crawler box. Just waiting for them to get their triple stick ready to ship and then I'm going to order.
cdrewferd is offline   Reply With QuoteReply With Quote
Old 02-16-2022, 12:14 AM #540
Black798's Avatar
Real Name: Phoenix
Black798's Avatar
Real Name: Phoenix
Its been a rough couple of weeks for this build since the last update. I have been fighting supply chain issues like crazy and found some pretty big issues that I am working through on the build.
First up was the driveshafts. The plan originally was to replace all the joints with 1310 series joints so the double cardans would be easier to service and a bit stronger than the Toyota stuff. But turns out all of that stuff is back logged out into June which doesn't work for me. This truck HAS to run and drive by march 12th... So now I am just getting the shafts retubed with whatever Toyota parts that the driveline shop could find. Those are thankfully done and I will be picking them up tomorrow.
Other huge supply chain issue I am dealing with is the front RCVs. I ordered these stupid things back in December with the guarantee from RCV that they would be here by the 23rd of this month. Long story short they're giving me the run around and the parts are a ways off. Solution there was to throw my checkbook at it and order shafts from trail gear as they have the capacity to get everything to me in time.
So with those two big issues I have been in full panic mode trying to get this thing together and find parts wherever I can and then to add insult to injury last weekend I went to bolt the rear tires on only to find out they were about half an inch shy of clearing the brake calipers.... After an afternoon of head scratching I finally figured out that trail ready shipped me 4.5" backspacing rims way back when I got them in September, they were supposed to be 4". I never thought to check and they hadn't been on the fully assembled axle until now. Thankfully they are being great about the whole deal and are rushing a set of rims out to me this week. This does also technically mean I set the front axle width 1" wider overall than it should have been but hopefully it doesnt make the tires stick out too far. Otherwise I may be redoing the front axle in a few months haha.
Setbacks aside the reassembly process has been going great. The rear suspension is all hung off the frame now, haltech ecu is installed along with the 650cc injectors, and the front suspension is about 90%together as well.
Now the part everyone actually wants to hear about, axle porn.
IMG_0836_080425
IMG_0840_080450
IMG_0835_080409
IMG_0849_072809
IMG_0848_072743
IMG_0850_072834
IMG_0852_072923
IMG_0857_072709
At this point its up in the air if I make this trip on the 12th but I am doing everything I can to make it happen. Ive been steadily working on the truck every weekend and during the week some so at this point the supply chain will either make it or break it for me.
Zak's 03 Limited Build Thread zopperman 4th Gen T4Rs 212 09-10-2020 03:05 AM
TRDTeen '99 Limited Build Thread TRDteen 3rd gen T4Rs 194 04-03-2020 10:56 PM
ZOMBRNR's 06 T4R Limited Build Thread ZOMBRNR 4th Gen T4Rs 104 07-20-2018 01:26 PM
541joseph's 96 limited build thread 541joseph 3rd gen T4Rs 3 12-08-2015 01:52 PM
Ped's 97 Limited Build Thread pedmonds0219 3rd gen T4Rs 30 01-28-2014 04:41 PM
