08-12-2016, 01:57 PM
#16
Originally Posted by amalik
Frame rot aside, I think this is the first question I've ever seen
@ TheDurk
ask in my few years as a member here.
If you've read this forum since 2006 almost every day, you really have little need to ask questions. What I haven't already learned, I know where to find.
My Backyard Frame Swap
08-12-2016, 02:00 PM
#17
Originally Posted by kolelt
Yes please document this ( but seriously why can't I see the pic of your frame ?) if you do frame swap. Wire wheel the whole frame. Get por15 metal prep and marine cleaner. And lay the por15. Then like monstaliner it. Eastwood internal frame costing inside.
Exactly my plan.
08-12-2016, 02:11 PM
#18
Real Name: Scramble
Real Name: Scramble
Sorry to hear about your frame. It's a battle with the salt where we live & the box frame holds dirt & moisture. If you need help let me know..but lets wait until Sept because this heat efn sucks!!!: I more than anyone knows the emotional attachment to the 99.
I'd be scared to buy a junked truck from up here. These trucks rot out just from being parked on gravel, dirt & grass. Luckily I parked on cement in LI & Blacktop here in Monroe. I'd probably look to the Southwest for a truck or frame if it happens to me.
____________
'99 4Runner - 2.7L 3RZ, 5 Speed, 4.56 Gears - Lifted, Locked & Loaded - 166k Original owner - http://www.toyota-4runner.org/3rd-ge...ld-thread.html
'99 Limited - E-Locker- Stock (for now) - 233k 2nd Owner http://www.toyota-4runner.org/3rd-ge...ted-build.html
08-12-2016, 02:20 PM
#19
Real Name: Scramble
Real Name: Scramble
Originally Posted by papapoopski
Where in jersey are you? I'm just over the border in NY. I had a guy repair my frame in March.
Where in OC? My zip is Monroe but I'm closer to Greenwood Lake.
____________
08-12-2016, 03:29 PM
#20
Sorry to see this Durk, but you're acting quick. You already bought a new frame before I could suggest that.
Even just come down here to the southeast. My truck has never seen salt and the undercarriage is just about spotless. Only very slight surface rust where the paint has been chipped off.
I don't mess with rust, I cringe when I see cars from up north.
2008 Toyota 4Runner Limited 4x4 - Salsa Red, DD, Mostly Stock, 89k miles
2001 Toyota 4Runner SR5 4x4 - Not Stock, Lifted, Armored, 291k miles
1987 Toyota Supra N/A - Stock, 2nd Owner, 92k miles
08-12-2016, 05:02 PM
#21
You made me to do this
I had everything but no activation energy to get it done. Saw your post last night and ended up doing this today.
08-12-2016, 07:41 PM
#22
Real Name: Dave
Real Name: Dave
@ TheDurk
Literally the only reason I clicked on this thread was because I couldn't believe
@ TheDurk
was asking a question. I had to see what it was!
Durk, this totally sucks that your frame rot is that bad, but I am interested to see your write up!
97 4runner SR5 3.4 manual
Tundra/LC Lift with Bilstein 5100's on 285/70/17 BFG KO2
2" "Fat Pats" body lift; 1.25" All Pro wheel spacers
Turbo Build; Rear Bumper Build; Front Bumper Build
08-12-2016, 08:14 PM
#23
Don't forget that POR15 is NOT a topcoat. It is highly susceptible to breaking down when exposed to UV. It works well as a rust converter, not as a paint.
1989 FJ62 5.3 Chevy, FZJ80 Axles, 4.88's with ARB.
2000 2wd runner, 4 cylinders, yes it IS slow.
1999 4WD SR5 Desert Dune 3.4 351K and counting.
2000 4WD sport 3.4 Elocker <--My son's but I still end up paying.
2001 2WD SR5 3.4 <-- My daughter's...see preceding line.
08-12-2016, 08:30 PM
#24
Absolutely right. 4 cans Eastwick Chassis Black on order for topcoat.
08-12-2016, 09:31 PM
#25
I'm surprised the gas tank side broke off first. You didn't notice any decay on the other side? Good luck with the frame swap. I would've had a pretty good hookup on a weld job if you chose that route.
08-12-2016, 10:06 PM
#26
There is definitely decay on the passenger side once you look closely. The welds are cracking slightly and the floor of the frame is gone where it is covered by the bracket. I think the side towards the center of the road gets more salt and that's why it went first.
08-12-2016, 10:39 PM
#27
Interesting, I had some minimal rot on passenger side which is now fixed. I attributed it to the exhaust temp changes causing moisture and brine. I have inspected the gas tank side twice a year but have not found the same decay. It's difficult to really inspect the driver's side thoughly however. Up here in the GWN, I rust proof annually but it still rusts like crazy even with weekly underwashes in the winter.
Sent from my SM-N900W8 using Tapatalk
1997 T4R SR5 3.4L 5 speed with factory e-locker bought new with almost 1km on it
08-12-2016, 11:08 PM
#28
Interesting. Normally, it's the passenger side the goes first. Oil or Fluidfilm the piss out of your new frame once you're done! Nothing works as well as that. The more greasy stuff under the truck the better.
08-12-2016, 11:51 PM
#29
So exactly what is ur goal. As I. What steps and products
97 3.4 JDM/5 Speed swap/eLocker Swap/ICON CDC all around/+more.....
08-13-2016, 01:11 AM
#30
Inside the new (to me) frame, Eastwood Internal Frame Coating. On the outside of the frame, wire wheel first, then POR15 cleaner then metal prep then the POR15. Eastwood chassis black for topcoat(s). Some kind of bedliner on the underbody while the frame is out. Still thinking about the diff, which is solid but has a lot of rust. Maybe Eastwood Rust Encapsulator and then more chassis black.
