Originally Posted by mechanic80
Strong gas smell when i pull into the garage and shut down the engine. Fuel system is pressurized. It even makes a weird put put sound from the gas cap. Goes away after about half an hour. Thoughts?
Gas cap seal failing. Evap emmision lines rusted off or damaged
Fuel lines leaking, gas tank rusted on top. Filling tube rusted or damaged.
Evap canister damaged or leaking.
Gas vapor fumes can travel around. So check that rig over really good. Should be pretty easy to find.;)
Build Thread:
https://www.toyota-4runner.org/3rd-g...os-builds.html
Brillo's Bucket Fluid Ex changer:
https://www.toyota-4runner.org/3rd-g...ml#post3358086
Sparks Plugs Wire and Coil Information:
https://www.toyota-4runner.org/3rd-g...on-5vz-fe.html
